HOW TO: Spam Report of spam folder contents
Post by jimimaseye » 2015-04-07 16:34
The following script will cycle through all active accounts and emails a report detailing the the current messages stored in the nominated spam folders. There is an option to also send a copy of the report to admin. (BEWARE: Use this option with care. If you set this to TRUE and you have MANY accounts then MANY emails will land in the admin inbox - 1 for each user).
See screen shot as example:
The script can be called by Task Scheduler to run daily or whatever suits. Note: this script does NOT delete anything - it is report only.
Ensure you review and change ALL variables within the CONFIG section. Note: If there is more than one named Spam folder then it can be entered whilst separated with the PIPE | symbol.
eg,
Const MESSAGES_FOLDER = "SPAM|Bulk"
This allows to cover all accounts that may have different spam folder names.
SpamReport.vbs
Option Explicit
'   #### CONFIG START ####
    Const MESSAGES_FOLDER = "SPAM"               	' Folder to delete from, case insensitive. Multiple folders can be separated by PIPE | symbol
    Const IMAP_DELIMITER = "."                      ' This needs to be same as what u used above for subfodlers based on delimiter
                                                    ' setting in hmailserver
    Const HMSADMINUSER = "Administrator"            ' Admin username
    Const HMSADMINPWD = "yoursecretpassword"        ' Admin password
    Const HMSSERVER = "localhost"                   ' hMailServer Server (DCOM)
    Const FROM_EMAIL = "system@yourdomain.com"      ' Replace this with the email address you want the Spam Report to come FROM
    Const REPORT_TO_ADMIN = TRUE                    ' Admin receives copy of all users Spam Reports (TRUE or FALSE)
    Const REPORT_TO_EMAIL = "admin@yourdomain.com"  ' Replace this with the ADMIN email address you want the Spam Report to be sent a copy to
	'   #### CONFIG END ####
'   Objects
    Dim oApp, oDomains, oDomain, oAccounts, oAccount, oMessages, oMessage
'   Numeric
    Dim NumMsgs, NumChecked, x, y, z, MessageID
'   Strings / arrays
    Dim SearchFolders, FindFolders, FoundFolder, AtLeastFound, FolderList, aFolder, SpamFolder
    Dim Message, CreateGUIDval, OutputMsg, OutputMsgList, w, FolderArray, SplitCount, xFolder
'   Flags
    Dim ReturnValue : ReturnValue = 0
'    On Error Resume Next
    SearchFolders = Split(MESSAGES_FOLDER, "|")
    Set oApp = CreateObject("hMailServer.Application", HMSSERVER)
    For x = 0 To oApp.Domains.Count - 1
        Set oDomain = oApp.Domains.Item(x)
        If oDomain.Active Then
            For y = 0 To oDomain.Accounts.Count - 1
                Set oAccount = oDomain.Accounts.Item(y)
                If oAccount.Active Then
                    AtLeastFound = False
                    Set Message = CreateObject("hMailServer.Message", HMSSERVER)
                    OutputMsgList = ""
                    NumChecked = 0
                    For Each SpamFolder in SearchFolders
                        NumMsgs = 0
                        NumChecked = 0
                        Set FindFolders = oAccount.IMAPFolders
                        FoundFolder = False
                        FolderList = ListFolders(FindFolders, 0, "")
                        aFolder = Split(Left(FolderList, Len(FolderList) - 1), "|")
                        For Each z in aFolder
                            If UCase(z) = UCase(Trim(SpamFolder)) Then
                                AtleastFound = True
                                FoundFolder = True
                                SpamFolder = z
                                Exit For
                        If FoundFolder Then
                            Set oMessages  = GetInsideFolders(oAccount.IMAPFolders, SpamFolder)
                            Do While oMessages.Count > (NumChecked)
                                Set oMessage = oMessages.Item(NumChecked)
                                NumMsgs = oMessages.Count
                                NumChecked = NumChecked + 1
                                If CLng(oMessage.ID) > 0 Then
                                   OutputMsgList = OutputMsgList & "<tr><td>" & oMessage.FromAddress & "</td>"
                                   OutputMsgList = OutputMsgList & "<td>" & mid(oMessage.Date,6,20) & "</td>"
                                   OutputMsgList = OutputMsgList & "<td>" & oMessage.Subject & "</td></tr>" & vbcrlf
                            Loop
                    If AtLeastFound then
                        OutputMsg = "<font face=""Calibri"">Account: " & oAccount.Address & "<br><br>The following " & NumChecked & _
                        " messages are currently held in your Spam mail folder """ & MESSAGES_FOLDER & """.<br><br>"
                        If NumChecked > 0 then
                            OutputMsg = OutputMsg & "<table><tr><td width=350><b>From</b></td><td><b>Date</b></td><td><b>Subject</b></td></tr>" & vbCrLf & OutputMsgList & vbcrlf
                            OutputMsg = OutputMsg & "</table>" & vbCrLf
                        OutputMsg = "<tr>""" & MESSAGES_FOLDER & """ folder Not Found in account " & oAccount.Address   & "</tr>"
                    Message.HeaderValue("Message-ID") = "<" & CreateGUID & ">"
                    Message.FromAddress = FROM_EMAIL
                    Message.From = "Spam Report Daemon <"& FROM_EMAIL & ">"
                    If REPORT_TO_ADMIN then
                        Message.AddRecipient "System Administrator", REPORT_TO_EMAIL
                    Message.AddRecipient oAccount.Address , oAccount.Address
                    Message.Subject = "Spam Report - " & oAccount.Address
                    Message.HTMLBody = OutputMsg
                    Message.Save
    Wscript.Quit ReturnValue
    Function ShowError(strMessage)
        WScript.Echo strMessage
        WScript.Echo Err.Number & " Srce: " & Err.Source & " Desc: " &  Err.Description
        ReturnValue = Err.Number
      Err.Clear
    Function ListFolders(obFolders, iRecursion, rootFolder)
        iRecursion = iRecursion + 1
        Dim sMessage
        Dim i
        For i = 0 To obFolders.Count -1
            Dim obFolder
            Set obFolder = obFolders.Item(i)
            If iRecursion > 1 Then
                FolderArray = Split(rootFolder, IMAP_DELIMITER)
                SplitCount=0
                for each xFolder in FolderArray
                   SplitCount=SplitCount+1
                   if SplitCount < iRecursion then
                      if SplitCount = 1 then
                         rootFolder = xFolder
                      else
                         rootFolder = rootFolder & IMAP_DELIMITER & xFolder
                      end if
                   else
                      if SplitCount = iRecursion then
                         Exit for
                      End if
                   end if
                next
                sMessage = sMessage & rootFolder & IMAP_DELIMITER & obFolder.Name & "|"
                sMessage = sMessage & obFolder.Name & "|"
            If iRecursion = 1 Then
                rootfolder =obFolder.Name
                rootFolder = rootFolder & IMAP_DELIMITER & obFolder.Name
            sMessage = sMessage & ListFolders(obFolder.SubFolders, iRecursion, rootFolder )
        iRecursion = iRecursion -1
        ListFolders = sMessage
    Function GetInsideFolders(obFolders2, subFolders)
        Dim iRecursion2
        iRecursion2 = 1
        Dim SeprateFodlers
        SeprateFodlers = Split(subFolders, IMAP_DELIMITER)
        For Each w in SeprateFodlers
            If iRecursion2 = 1 Then
                Set obFolders2 = obFolders2.ItemByName(w)
                iRecursion2 = iRecursion2 + 1
                Set obFolders2 = obFolders2.SubFolders.ItemByName(w)
        Set GetInsideFolders = obFolders2.Messages
    Function CreateGUID()
        ' Generate a random string.
        With CreateObject("hMailServer.Utilities", HMSSERVER)
            CreateGUID = Mid(.GenerateGUID, 2, 36) & "@randommail"
