Global rule to catch all incoming mail
Hazark
Post by Hazark » 2015-03-20 10:58
I need a copy of e-mails which originated from an external server. Anyone have an idea on that?
If this is not possible (within hmailserver), I need to catch all incoming mail to server and forward (or save a copy) to another address. I can manually filter it against my users addresses later.
Global rules and mirror function triggers from inbound AND outbound traffic so it's not usable for my scenerio.
If I hit the language barrier on my post above; here is a visualization
Sender          | Receiver          | Do I need a copy of that
*@external.com  | *@dtroms.com      | YES
*@dtroms.com    | *@dtroms.com      | NO
*@dtroms.com    | *@external.com    | NO
dtroms = domain that resides on my server
Thanks.
Re: Global rule to catch all incoming mail
Post by jimimaseye » 2015-03-20 11:28
Hazark wrote:Global rules and mirror function triggers from inbound AND outbound traffic so it's not usable for my scenerio.
Not true.
GLOBAL RULE
if
FROM ....not contain.... DTROMS.COM
then
forward....
Make sure you code the rule for LOOPS
Hazark
Post by Hazark » 2015-03-20 11:45
The problem is dtroms.com actually a placeholder that means "domain that resides on my server" and there are many of them.
If I choose that way, I must list every domain I have on the rule definition and update it when a new domain added/removed on the server.
Doable, maybe I can automate the rule definition update process with mysql triggers. If anyone thinks another way to do this, please post it; thanks.
Post by SorenR » 2015-03-20 14:19
Hazark wrote:I need a copy of e-mails which originated from an external server. Anyone have an idea on that?
Thanks.
How is your VBScript ?
Following assume authentication is active for local accounts..
EventHandlers.vbs
      If (oClient.Username = "") Then
         oMessage.HeaderValue("X-dtroms-True") = "YES"
Global Rule
   Criteria (AND):
      If Custom header field "X-hMailServer-LoopCount" < 1
      If Custom header field "X-dtroms-True" = "YES"
   Action:
      Forward email "dtroms@acme.inc"
Hazark
Post by Hazark » 2015-03-20 14:50
SorenR wrote: Following assume authentication is active for local accounts..
..code..
Authentication is enabled and your solution seems working well (based on my 2 minute test). Will try for longer periods.
Thanks and have a nice day.
