why this mail goes to gmail spam folder? What else can I do?
kdiamond
Post by kdiamond » 2014-10-10 01:11
Why would this mail go to Gmail spam folder?
I've been struggling with this for whole day. I'm loosing my mind already :)
Reverse DNS = Matches
spf=pass
dkim=pass
dmarc=pass
http://mxtoolbox.com/ = all pass except TLS
Thank you very much.
Br,
kd
Delivered-To: dbrectest1@gmail.com
Received: by 10.60.56.14 with SMTP id w14csp256874oep;
        Thu, 9 Oct 2014 16:04:50 -0700 (PDT)
X-Received: by 10.194.177.226 with SMTP id ct2mr756858wjc.20.1412895890112;
        Thu, 09 Oct 2014 16:04:50 -0700 (PDT)
Return-Path: <dali@dbstudio.si>
Received: from dbstudio.si (dbstudio.si. [93.103.7.222])
        by mx.google.com with SMTP id o1si756350wix.50.2014.10.09.16.04.49
        for <dbrectest1@gmail.com>;
Received-SPF: pass (google.com: domain of dali@dbstudio.si designates 93.103.7.222 as permitted sender) client-ip=93.103.7.222;
Authentication-Results: mx.google.com;
       spf=pass (google.com: domain of dali@dbstudio.si designates 93.103.7.222 as permitted sender) smtp.mail=dali@dbstudio.si;
       dkim=pass header.i=@dbstudio.si;
       dmarc=pass (p=QUARANTINE dis=NONE) header.from=dbstudio.si
dkim-signature: v=1; a=rsa-sha256; d=dbstudio.si; s=mail;
	c=relaxed/relaxed; q=dns/txt; h=From:Subject:Date:Message-ID:To:MIME-Version:Content-Type:Content-Transfer-Encoding;
	bh=i8QWRtIzUU/t1yFsrmll7X70oZRRCR8XnoaFAyH/TXo=;
	b=BbfLtVFovRNFIinGU9So5P6AqoFGEjvzmtQ6sXLVYEFQ/Yy4gD/Sf0LKx7lzpTBk3fl9LIrrKklUQ5c3/ns/aUkRV5FVlCsFrMq+mW9Bzy0MG8omedJe7wswZqCC0bOi3iDarwDnofz6txlnwlDMSp+UteN6DEI/tmxZZOOHxLI=
Received: from mail.dbstudio.si (93-103-51-200.dynamic.t-2.net [93.103.51.200])
	by mail.dbstudio.si
	; Fri, 10 Oct 2014 01:04:54 +0200
Message-ID: <5437149D.6080506@dbstudio.si>
Date: Fri, 10 Oct 2014 01:05:01 +0200
User-Agent: Mozilla/5.0 (Windows NT 6.3; WOW64; rv:31.0) Gecko/20100101 Thunderbird/31.1.2
MIME-Version: 1.0
Subject: test mail
Content-Type: text/plain; charset=utf-8; format=flowed
This is just a test mail.
Re: why this mail goes to gmail spam folder? What else can I
Post by SorenR » 2014-10-10 01:27
oops...
Post by percepts » 2014-10-10 01:32
PTR record says
dbstudio.si
it normally should say
mail.dbstudio.si
whether thats enough to get you into spam I don't know. Ask gmail why they do what they do.
Post by SorenR » 2014-10-10 01:38
Was the first post edited ??
I could have sworn that the first Received header was..
Received: from mail.dbstudio.si (dbstudio.si. [93.103.7.222])
kdiamond
Post by kdiamond » 2014-10-10 01:39
Thank you SorenR !!
I have changed back to mail.dbstudio.si.
This line below is my current home ip, which is dynamic yes.
Br,
kd
Received: by 10.60.56.14 with SMTP id w14csp258736oep;
        Thu, 9 Oct 2014 16:34:25 -0700 (PDT)
X-Received: by 10.180.186.4 with SMTP id fg4mr928032wic.73.1412897665444;
        Thu, 09 Oct 2014 16:34:25 -0700 (PDT)
        by mx.google.com with SMTP id v9si827210wib.49.2014.10.09.16.34.24
	b=ZUQL/Z1jJFCi/nH3xF0BYCKwTqI2V2hxLoPLzNBFfrfClqQZ9xKZfvlplPmSA77INyJ34pgpWdaCk+y9YQsx68Hw3HiPC1sr9NDLx0UtxeQU38rDJm/XjCIWxLMsW6CekaZ0j7u+IwMSSdjFUvwgDjIibrq3nnvYiiRWVxv0DMs=
	by mail.dbstudio.si
	; Fri, 10 Oct 2014 01:34:30 +0200
Message-ID: <54371B8D.7050203@dbstudio.si>
Date: Fri, 10 Oct 2014 01:34:37 +0200
MIME-Version: 1.0
Subject: test mail 2
kdiamond
Post by kdiamond » 2014-10-10 01:40
Yes it was. I was trying with different settings. I'm sorry.
Post by SorenR » 2014-10-10 01:44
Hmm... Well, I'll change the previous "oops" to a real reply again ;-)
EHLO = mail.dbstudio.si
mail.dbstudio.si resolves to 93.103.7.222
93.103.7.222 resolves to dbstudio.si <-- should be mail.dbstudio.si
And this one is suspicious..
   by mail.dbstudio.si
kdiamond
Post by kdiamond » 2014-10-10 01:49
percepts wrote:PTR record says
dbstudio.si
mail.dbstudio.si
my other domains have PTR like this, without mail. prefix and mail won't go into spam. But I use mdaemon mail server for other domains. All domains using hmailserver will end up in spam folder. Strange. I guess it can not be HMS's fault, but I'm running out of options :(
Who can I ask there. Is there a contact? I've been filling out some bulk mailer forms but no response so far.
Thank you
Br,
kd
kdiamond
Post by kdiamond » 2014-10-10 01:54
So I can contact ma ISP and ask to change PTR from dbstudio.si to mail.dbstudio.si
Would this make it a better practice for PTR record?
   by mail.dbstudio.si
This one is my current local IP. If I go to a local pub or other networks it will be always different. I can not affect that I guess.
kdiamond
Post by kdiamond » 2014-10-10 01:59
This is the email send from another domain using mdeamon mail server. This one does not go to SPAM folder. It works OK.
Can anyone spot the problem, of why this mail is OK but all HMS mails go to spam.
Thank you very much!
Received: by 10.60.56.14 with SMTP id w14csp259888oep;
        Thu, 9 Oct 2014 16:56:24 -0700 (PDT)
X-Received: by 10.194.120.101 with SMTP id lb5mr828949wjb.84.1412898983632;
        Thu, 09 Oct 2014 16:56:23 -0700 (PDT)
Return-Path: <dali@recepcija-polis.com>
Received: from recepcija-polis.com (recepcija-polis.com. [93.103.7.212])
        by mx.google.com with ESMTPS id ck2si942529wib.24.2014.10.09.16.56.22
        (version=TLSv1 cipher=RC4-SHA bits=128/128);
Received-SPF: pass (google.com: domain of dali@recepcija-polis.com designates 93.103.7.212 as permitted sender) client-ip=93.103.7.212;
       spf=pass (google.com: domain of dali@recepcija-polis.com designates 93.103.7.212 as permitted sender) smtp.mail=dali@recepcija-polis.com;
       dkim=pass header.i=@recepcija-polis.com
DKIM-Signature: v=1; a=rsa-sha256; c=simple;
	d=recepcija-polis.com; s=MDaemon; t=1412896994; x=1413501794;
	q=dns/txt; h=Received:Received:Date:From:To:Subject:MIME-Version:
	Content-Type:Message-ID:Reply-To; bh=EtPGSIyOJsxVRi7CeNRxyvQ0YCn
	4mcrOBgeiEsKrhlQ=; b=zgR9Vs+bG0DPgqF6aOJFCNGnulwEjUkglQCM8WDECt9
	geY+1RhoExCBzgOq0+SiqxJio4XNZO75eb9JJpnkecVlZWK5/KJb+Se4Rx8DeiIb
	Rp0AYMvXOqBrt/z1Kz2UY+YQ6JOhSNy5FWoWPuAe8wkHaV2MVKzNfTe8E7yh41iQ
Received: from WorldClient by recepcija-polis.com (MDaemon PRO v10.1.0)
	with ESMTP id md50001725355.msg
	for <dbrectest1@gmail.com>; Fri, 10 Oct 2014 01:23:13 +0200
X-Spam-Processed: dbrecordings.com, Fri, 10 Oct 2014 01:23:13 +0200
	(not processed: message from trusted or authenticated source)
X-Authenticated-Sender: dali@recepcija-polis.com
X-Return-Path: dali@recepcija-polis.com
X-Envelope-From: dali@recepcija-polis.com
X-MDaemon-Deliver-To: dbrectest1@gmail.com
Received: from [93.103.51.200] by recepcija-polis.com via WorldClient with HTTP;
	Fri, 10 Oct 2014 01:23:10 +0200
Date: Fri, 10 Oct 2014 01:23:10 +0200
To: "dbrectest1@gmail.com" <dbrectest1@gmail.com>
Subject: this is a mdeamon mail test
MIME-Version: 1.0
Content-Type: multipart/alternative; boundary="1009_2323_10_PART-BREAK"
Message-ID: <WC20141009232310.240003@recepcija-polis.com>
X-Mailer: WorldClient 10.1.1
Reply-To: dali@recepcija-polis.com
--1009_2323_10_PART-BREAK
Content-Type: text/plain; charset="us-ascii"
Content-Type: text/html; charset="us-ascii"
<HTML>
<div><font>
<div style="">this is a mdeamon mail test<br />
<font size="2">&nbsp;</font></div>
</font></div>
</HTML>
--1009_2323_10_PART-BREAK--
Post by SorenR » 2014-10-10 02:03
No dmarc ??
They match...
Btw... This is equal to the EHLO SPAM test in hMailServer ;-)
Post by percepts » 2014-10-10 02:07
you are using dynamic IP. That is a big problem.
goto browser on your hmail machine google "what is my IP".
If it doesn't say 93.103.7.222 then that is a problem.
kdiamond
Post by kdiamond » 2014-10-10 02:07
SorenR wrote:No dmarc ??
They match...
Yes they match. But so can I change HMS/Settings/Protocols/SMTP/Delivery of e-mail/ local host name from mail.dbstudio.si to dbstudio.si. They too then match, but mail still gets in SPAM folder.
Br,
kd
kdiamond
Post by kdiamond » 2014-10-10 02:10
They match now too, but mail still hist SPAM.
Received: by 10.60.56.14 with SMTP id w14csp260576oep;
        Thu, 9 Oct 2014 17:08:48 -0700 (PDT)
X-Received: by 10.195.13.114 with SMTP id ex18mr762102wjd.89.1412899727903;
        Thu, 09 Oct 2014 17:08:47 -0700 (PDT)
        by mx.google.com with SMTP id td12si840559wic.93.2014.10.09.17.08.46
	bh=mmw0X7jm5YgP32wHBaDFqGjQHWGKOS1POru3ohsuF6c=;
	b=SUvddsNuCagj3zjSJ9HHx9KrAWwpZgNkU4JFlCVfT7ipiwuXhFlHwtAPpobezjqzUtZ9MT2JuBuUgWbIjfqI2Zy9xf1MlgHVuG1+o0qM7X3qxbqlRatj1RGIwKax4tCkmMTH3fwAZvp/rysJfM25YDgk4JvNzoisIdJqPgkBMTc=
	by dbstudio.si
	; Fri, 10 Oct 2014 02:08:52 +0200
Message-ID: <5437239A.2080308@dbstudio.si>
Date: Fri, 10 Oct 2014 02:08:58 +0200
MIME-Version: 1.0
Subject: test mail 4
test mail 4
Post by SorenR » 2014-10-10 02:11
They match...
Br,
kd
No, it has to match your MX record (mail.dbstudio.si) !
A = MX = EHLO = rDNS --> FCrDNS :wink:
Post by percepts » 2014-10-10 02:15
also you have used a cidr address (93.103.7.222/32) in your spf records and I think its not doing what you think it is.
it resolves to a single ip address which is 93.103.7.222
try using 93.103.0.0/19 instead. I don't know if that will work but its better than what you have now considering you are using a dynamic IP
kdiamond
Post by kdiamond » 2014-10-10 02:17
So the solution would be to ask my ISP to change PTR records from dbstudio.si to mail.dbstudio.si? Would that be correct?
Thank you
Post by SorenR » 2014-10-10 02:20
Thank you
Yes...
And... Change the hostname of your mailclient on your home IP... It is confusing that mail.dbstudio.si send mail to mail.dbstudio.si on a different IP address.
Post by percepts » 2014-10-10 02:21
what is your current IP of hmailserver machine ???????
Post by mattg » 2014-10-10 02:21
kdiamond wrote:So the solution would be to ask my ISP to change PTR records...
That MAY be a solution.
Really the only people that can tell you why your mail is sent to SPAM is the people who send it to SPAM, ie the admins at gmail
kdiamond
Post by kdiamond » 2014-10-10 02:28
percepts wrote:what is your current IP of hmailserver machine ???????
There are more IPs. The result will be the same if I remove all but 222.
Ethernet adapter Ethernet 3:
Connection-specific DNS Suffix . :
IPv4 Address. . . . . . . . . . . : 93.103.7.214
Subnet Mask . . . . . . . . . . . : 255.255.255.240
IPv4 Address. . . . . . . . . . . : 93.103.7.218
IPv4 Address. . . . . . . . . . . : 93.103.7.222
Default Gateway . . . . . . . . . : 93.103.7.209
Post by percepts » 2014-10-10 02:29
percepts wrote:also you have used a cidr address (93.103.7.222/32) in your spf records and I think its not doing what you think it is.
kdiamond
Post by kdiamond » 2014-10-10 02:31
I suppose I can not just call and ask them :) Well, PTR for recepcija-polis is also withou mail. prefix and it works great. I can say to ISP to change PTR, but if that would really be the problem, I guess recepcija-polis will also go to spam directly too.
Br,
kd
kdiamond
Post by kdiamond » 2014-10-10 02:34
For recepcija-polis domain (the one that works good) there are also spf records like this.
"spf2.0/mfrom mx ip4:93.103.7.212/32 -all"
"v=spf1 mx ip4:93.103.7.212/32 -all"
Post by SorenR » 2014-10-10 02:40
kdiamond wrote:I suppose I can not just call and ask them :) Well, PTR for recepcija-polis is also withou mail. prefix and it works great. I can say to ISP to change PTR, but if that would really be the problem, I guess recepcija-polis will also go to spam directly too.
Br,
kd
I had a re-read of the RFC... the EHLO <host name> must resolve to an A or MX record with an associated rDNS, so changing the hostname in hMailServer to dbstudio.si should work...
My own server is fully FCrDNS so my spf record only contains "a mx ptr -all"
kdiamond
Post by kdiamond » 2014-10-10 02:52
Does not, tried many times.
Should I delete my both spf records and use this?
TXT "v=spf1 a mx ptr -all"
Would that be correct? How long it takes for changes to take effect?
kdiamond
Post by kdiamond » 2014-10-10 03:12
SorenR wrote:My own server is fully FCrDNS so my spf record only contains "a mx ptr -all"
This can not be the case. recepcija-polis (working domain, mdeamon mail server) also has the same SPF records. Works fine.
Oh this is a nightmare!
This is one difference comparing it to mdaemon. But where to turn this off? Sending it from Thunderbird client or Web Roundcube the string is always there.
Thank you all for helping!
Br,
kd
Post by SorenR » 2014-10-10 03:14
SPF2.0 you don't really need when you have DKIM, it's sort of the same thing as far as I can read from the 'net.
According to this... http://www.kitterman.com/spf/validate.html?
Domain: dbstudio.si
SPF Record: v=spf1 a mx ptr -all
should pass validation...
kdiamond
Post by kdiamond » 2014-10-10 03:20
SorenR wrote: Would that be correct? How long it takes for changes to take effect?
Domain: dbstudio.si
should pass validation...[/quote]
Let's try it.
Thank you
kdiamond
Post by kdiamond » 2014-10-10 03:21
What makes you think it's SPF? It says SPF = pass
SPF record lookup and validation for: dbstudio.si
SPF records are published in DNS as TXT records.
The TXT records found for your domain are:
spf2.0/mfrom mx ip4:93.103.7.222/32 -all
v=spf1 a ip4:93.103.7.222/32 -all
Checking to see if there is a valid SPF record.
Found v=spf1 record for dbstudio.si:
evaluating...
SPF record passed validation test with pySPF (Python SPF library)!
Post by SorenR » 2014-10-10 03:40
kdiamond wrote:What makes you think it's SPF? It says SPF = pass
evaluating...
If they pass then no need to change them.
The only difference left between the two servers is DMARC... And this also passes the test...
I think you need to mail Gmail admin and have them explain since everything else has been tried now.. Maybe the ip address is on some sort of internal list...
kdiamond
Post by kdiamond » 2014-10-10 03:44
SorenR wrote:I think you need to mail Gmail admin and have them explain since everything else has been tried now.. Maybe the ip address is on some sort of internal list...
Well that's the hard part. I would have done that, if any contact would exist. There are some forms without any response.
I might temporarily stop other (working) domain on 93.103.7.212 and put dbstudio.si there for a while, just to see if it's blacklisted IP. Running out of options here.
Thank you all very much for all your help.
Br,
kd
kdiamond
Post by kdiamond » 2014-10-10 10:19
Dammit, I'm stuck!
Domain recepcija-polis (using Mdeamon) without dmarc works like a charm. Mail goes to inbox. Other domains dbstudio.si, globevoices.com, dspsound.si (using HMS) will always go to spam folder. I must be crazy
Recepcija-polis Mdeamon- Inbox OK
Delivered-To: tom.sternisa@gmail.com
Received: by 10.96.91.10 with SMTP id ca10csp803356qdb;
        Fri, 10 Oct 2014 01:07:59 -0700 (PDT)
X-Received: by 10.194.89.67 with SMTP id bm3mr2977850wjb.80.1412928478825;
        Fri, 10 Oct 2014 01:07:58 -0700 (PDT)
Return-Path: <podpora@recepcija-polis.com>
        by mx.google.com with ESMTPS id xx3si7015109wjc.127.2014.10.10.01.07.58
        for <tom.sternisa@gmail.com>
Received-SPF: pass (google.com: domain of podpora@recepcija-polis.com designates 93.103.7.212 as permitted sender) client-ip=93.103.7.212;
       spf=pass (google.com: domain of podpora@recepcija-polis.com designates 93.103.7.212 as permitted sender) smtp.mail=podpora@recepcija-polis.com;
	d=recepcija-polis.com; s=MDaemon; t=1412926410; x=1413531210;
	q=dns/txt; h=Received:Message-ID:Date:From:User-Agent:
	MIME-Version:To:Subject:Content-Type:Content-Transfer-Encoding:
	Reply-To; bh=bF1s21tQYCmEiY4fl5nKayI1D0oKOnCuzalMr+pymqo=; b=mkZ
	gquSmvmUb6ZaB/httj+Mwjp2npN935m8A023IvVBuS/ACMRUyC75U7hZqNIXcy2r
	qg3PhmYMNiDfY0AUTHXqsYUDqPrp1VWq4vGcoJ9j3bSzsUtj/aT1LhjBbtmmueXg
	y6a/0QTUWDdKwIfXHNJslXxhKvzVTBSQLTCNHhMc=
Received: from [192.168.3.113] by recepcija-polis.com (Cipher TLSv1:RC4-MD5:128) (MDaemon PRO v10.1.0)
	with ESMTP id md50001725368.msg
	for <tom.sternisa@gmail.com>; Fri, 10 Oct 2014 09:33:30 +0200
X-Spam-Processed: dbrecordings.com, Fri, 10 Oct 2014 09:33:30 +0200
X-Authenticated-Sender: podpora@recepcija-polis.com
X-MDRemoteIP: 192.168.3.113
X-Return-Path: podpora@recepcija-polis.com
X-Envelope-From: podpora@recepcija-polis.com
X-MDaemon-Deliver-To: tom.sternisa@gmail.com
Message-ID: <543793E9.7090803@recepcija-polis.com>
Date: Fri, 10 Oct 2014 10:08:09 +0200
MIME-Version: 1.0
Subject: test 1
Reply-To: podpora@recepcija-polis.com
test 1
dbstudio.si HMS - SPAM
Received: by 10.96.91.10 with SMTP id ca10csp805145qdb;
        Fri, 10 Oct 2014 01:24:54 -0700 (PDT)
X-Received: by 10.180.108.9 with SMTP id hg9mr3135762wib.1.1412929494205;
        by mx.google.com with SMTP id m13si2161623wiv.32.2014.10.10.01.24.52
        Fri, 10 Oct 2014 01:24:53 -0700 (PDT)
	b=KTz/e4DfVsjGKSDFdGaS2gy48vv0/P14R32F7B4sYDqTTP+XO4l6tGRtGYZGDrmOXe9SBEWcWMCdMgL096Ax0A9B+eem6z2Td0fzJwL80Ur75Iq27bX4N2eSztweHhBQCIlPiPSfc0b3nScBCe6zlNada+fsUt1pSN2ZQYToSYQ=
Received: from mail.dbstudio.si (Dali-lpt [192.168.3.113])
	by dbstudio.si
	; Fri, 10 Oct 2014 10:24:58 +0200
Message-ID: <543797E0.1080109@dbstudio.si>
Date: Fri, 10 Oct 2014 10:25:04 +0200
MIME-Version: 1.0
Subject: test 1
test 1
globevoices.com HMS - SPAM
Received: by 10.96.91.10 with SMTP id ca10csp803565qdb;
        Fri, 10 Oct 2014 01:10:07 -0700 (PDT)
X-Received: by 10.180.102.41 with SMTP id fl9mr3054577wib.52.1412928606858;
        Fri, 10 Oct 2014 01:10:06 -0700 (PDT)
Return-Path: <dali@globevoices.com>
Received: from globevoices.com (globevoices.com. [93.103.7.218])
        by mx.google.com with SMTP id cd8si7055322wjc.103.2014.10.10.01.10.06
Received-SPF: pass (google.com: domain of dali@globevoices.com designates 93.103.7.218 as permitted sender) client-ip=93.103.7.218;
       spf=pass (google.com: domain of dali@globevoices.com designates 93.103.7.218 as permitted sender) smtp.mail=dali@globevoices.com;
       dkim=pass header.i=@globevoices.com;
       dmarc=pass (p=QUARANTINE dis=NONE) header.from=globevoices.com
dkim-signature: v=1; a=rsa-sha256; d=globevoices.com; s=key1;
	b=hB/YtzvBZ1eJVyw+rdM7g98tY+D/tYHKAKGBdlR3ovvPJNBuShKWUdJ52zBengNRH7TL8kh2mulziXB67BvjFk32F7MzdBgf17oyE5NdCdbKYfgDIQXxjOwuXOL4IfunaAx6NXGdDXegSQSmum6tvOWjx2u2gqgrRRkMs/weD4M=
Received: from [192.168.3.113] (Dali-lpt [192.168.3.113])
	by globevoices.com
	; Fri, 10 Oct 2014 10:10:12 +0200
Message-ID: <5437946A.4020809@globevoices.com>
Date: Fri, 10 Oct 2014 10:10:18 +0200
MIME-Version: 1.0
Subject: test 1
test 1
dspsound.si HMS - SPAM
Received: by 10.96.91.10 with SMTP id ca10csp805721qdb;
        Fri, 10 Oct 2014 01:30:59 -0700 (PDT)
X-Received: by 10.180.75.229 with SMTP id f5mr2985899wiw.81.1412929859150;
Return-Path: <dali@dspsound.si>
Received: from dspsound.si (dbstudio.si. [93.103.7.222])
        by mx.google.com with SMTP id dz13si7127228wjb.100.2014.10.10.01.30.58
        Fri, 10 Oct 2014 01:30:58 -0700 (PDT)
Received-SPF: pass (google.com: domain of dali@dspsound.si designates 93.103.7.222 as permitted sender) client-ip=93.103.7.222;
       spf=pass (google.com: domain of dali@dspsound.si designates 93.103.7.222 as permitted sender) smtp.mail=dali@dspsound.si;
       dkim=pass header.i=@dspsound.si
dkim-signature: v=1; a=rsa-sha256; d=dspsound.si; s=mail;
	b=Snh2QDjNh0+hONtyYn5CmeWMWvFaCqSC0vVn74pnzPVMZvrzFjvB4BVYDPx5Seo5benN9FtzsnbmMMRWD0JZpq/KYyc304Gf2omFnWLKzdKRhjhopSLDxADyTxUcipvbDzYis+uasTMCM41lZPkzt1rvLe/duwq63lflpssuq18=
Received: from mail.dbrecordings.com (Dali-lpt [192.168.3.113])
	by dspsound.si
	; Fri, 10 Oct 2014 10:31:03 +0200
Message-ID: <5437994E.3000104@dspsound.si>
Date: Fri, 10 Oct 2014 10:31:10 +0200
MIME-Version: 1.0
Subject: test 1
test 1
LesD
Post by LesD » 2014-10-13 14:02
Do not the headers of the email give any clue as to why gmail is routing it to spam?
It would be the obvious place for them to log it.
