Hmail and Websitepanel
simonegiusti
Post by simonegiusti » 2014-09-02 23:13
I have HmailServer installed (latest beta 2058 5.5).
I don't know if this happen after upgrading but I receive this message when trying to access mail services (domains, mailboxes, lists and groups)
System.Web.Services.Protocols.SoapException: System.Web.Services.Protocols.SoapException: Server was unable to process request. ---> System.NullReferenceException: Object reference not set to an instance of an object.
 at WebsitePanel.EnterpriseServer.MailServerController.GetMailDomain(Int32 itemId)
 --- End of inner exception stack trace ---
 at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
 at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
 at WebsitePanel.EnterpriseServer.esMailServers.GetMailDomain(Int32 itemId)
 at WebsitePanel.Portal.MailDomainsEditDomain.BindItem()
I don't have a backup to restore.
What shall I do now ???
Re: Hmail and Websitepanel
Post by percepts » 2014-09-02 23:24
That doesn't look like an hmail message to me. Where exactly are you seeing that message and which program is generating it.
Post by SorenR » 2014-09-02 23:51
simonegiusti wrote:I have HmailServer installed (latest beta 2058 5.5).
WebsitePanel.net...
Under System Requirements it says "hMailServer 4.x"
http://www.websitepanel.net/documentati ... uirements/
Ask your question here...
http://www.websitepanel.net/support/
But... As 5.5 is still Beta... Don't hope for too much :roll:
I'm sure one of the DB guys here can tell you what tables to alter to revert the changes in 5.5..
