Message.Copy trouble
ras07
Post by ras07 » 2014-08-26 05:20
I'm having trouble with the Message.Copy method.
First off, I'm trying to call it in OnAcceptMessage, and I'm not positive this is legit (but I can't find any documentation that it isn't). If the message has to already exist in one IMAP folder before you copy it to another, then that's my problem, and this isn't going to work. Can somebody confirm or deny this?
Assuming that it is legit, here's the code that I can't get to work:
Dim oApp, oAcct
Call oApp.Authenticate(hMSAuthUser, hMSAuthPass)
Set oAcct = oApp.Domains.ItemByName(myDomain).Accounts.ItemByAddress(myAccount)
oMsg.Copy(oAcct.IMAPFolders.ItemByName(myFolder).ID)
I'm pretty sure I'm identifying the right folder ID and I don't think I have any authorization issues. oAcct.IMAPFolders.ItemByName(myFolder).Name gives me the expected folder name, and oAcct.IMAPFolders.ItemByName(myFolder).Messages.Count gives me the expected number of messages that are in that folder. So I think I'm on the right track.
Am I getting IDs mixed up? The docs for Message.Copy are pretty sparse - I'm not positive that iDestinationFolderID is the same database identifier as IMAPFolder.ID (but if it isn't, then I don't know what it is).
Any ideas appreciated
ras
Re: Message.Copy trouble
Post by mattg » 2014-08-26 06:25
OnAcceptMessage is before it is sent to the account
Try OnDeliverMessage
is oMsg what is in the brackets of the sub??
ras07
Post by ras07 » 2014-08-26 07:01
It's not working on OnDeliverMessage either.
mattg wrote:is oMsg what is in the brackets of the sub??
Sorry, oMsg should be oMessage (the parameter for, in this case, OnDeliverMessage).
Post by mattg » 2014-08-26 07:47
Just thinking that this is a permissions issue.
Authenticate as your account and see it that works, or even try authenticating with 'Administrator' and the relevant password
Oh, and are there any errors logged?
ras07
Post by ras07 » 2014-08-26 08:16
I don't think it's permissions - I'm authenticating with the Administrator account.
For clarity I restructured it as follows - no errors are logged:
	Dim oApp, oDom, oAcct, oFldr
	Set oDom = oApp.Domains.ItemByName(myDomain)
		LogStr("Domain ID: " & oDom.ID)
	Set oAcct = oDom.Accounts.ItemByAddress(myAcct)
		LogStr("Account ID: " & oAcct.ID)
		LogStr("Folder count: " & oAcct.IMAPFolders.Count)
	Set oFldr = oAcct.IMAPFolders.ItemByName(myFolder)
		LogStr("Folder ID: " & oFldr.ID)
		LogStr("Folder name: " & oFldr.Name)
		LogStr("Folder count: " & oFldr.Messages.Count)
	oMessage.Copy(oFldr.ID)
		LogStr("Message UID: " & oMessage.UID)
'               LogStr("Message ID: " & oMessage.ID)    ' This will throw an error
		LogStr("DONE")
'	oFldr.Save      ' I've tried it with and without this; it doesn't seem to matter
LogStr is just a simple subroutine to write a string to a file. The output of the file is as follows:
Domain ID: 2
Account ID: 23
Folder count: 5
Folder ID: 299
Folder name: tst
Folder count: 4
Message UID: 0
All this is as expected, except that I don't understand why the message UID is zero. Also, trying to access oMessage.ID results in a "Variable uses an Automation type not supported in VBScript" error.
Are you sure the message exists in an IMAP folder when OnDeliverMessage is called? (The way I read the docs it seems like it certainly should be, but the oMessage.UID and oMessage.ID results make me wonder.)
Thanks for looking at this
ras
Post by mattg » 2014-08-26 08:43
I do something similar with a set of rules
1. Global rule
If from contains "@domain.com" AND
recipient list Not contains sent@domain.com
THEN
Forward to sent@domain.com
2. account level rule for Sent
If message size > 0 THEN
move to IMAP folder (public folder)
It requires setting up public folders and permissions for them, but then say the entire reception team can see all mail sent by anyone from the domain
I'll have a closer look at your script later when I get a few minutes...
ras07 wrote:Are you sure the message exists in an IMAP folder when OnDeliverMessage is called?
No not sure, but that's what I'll check
Post by mattg » 2014-08-26 08:47
ALSO, you could to run function from a global rule
That should be almost last thing in the process. Only account rules after global rules I think.
Post by SorenR » 2014-08-26 13:33
Well....
3280	"2014-08-26 13:24:40.021"	"OnAcceptMessage(oClient, oMessage) - oMessage.ID = 0"
1188	"2014-08-26 13:24:40.083"	"OnDeliveryStart(oMessage) - oMessage.ID = 827748"
1188	"2014-08-26 13:24:40.115"	"OnDeliverMessage(oMessage) - oMessage.ID = 827748"
      On Error Resume Next
      EventLog.Write ("OnAcceptMessage(oClient, oMessage) - oMessage.ID = " & CStr(oMessage.ID))
      On Error GoTo 0
   Sub OnDeliveryStart(oMessage)
      EventLog.Write ("OnDeliveryStart(oMessage) - oMessage.ID = " & CStr(oMessage.ID))
      On Error GoTo 0
      EventLog.Write ("OnDeliverMessage(oMessage) - oMessage.ID = " & CStr(oMessage.ID))
      On Error GoTo 0
Looking into the database, table 'hm_messages' I can find the oMessage.ID so it keeps the .ID when delivered to the user.
I found this piece of code by Martin a while back, it may give you some inspiration on what to do...
   Dim obApp
   ' Authenticate. Without doing this, we won't have permission
   ' to change any server settings or add any objects to the
   ' installation.
   Call obApp.Authenticate("Administrator", "secret")
   ' Locate the domain we want to add the account to
   Dim obDomain
   Set obDomain = obApp.Domains.ItemByName("example.com")
   Dim obAccount
   Set obAccount = obDomain.Accounts.ItemByAddress("test@example.com")
   Dim obInboxFolder
   Set obInboxFolder = obAccount.IMAPFolders.ItemByName("Inbox")
   ' Assume that the backup folder already exists. This may
   ' not be the case.
   Dim obBackupFolder
   Set obBackupFolder = obAccount.IMAPFolders.ItemByName("Backup")
   ' Copy all messages in Inbox to the backup folder
   Dim obMessages
   Set obMessages = obInboxFolder.Messages
   For i = 0 to obMessages.Count - 1
      Call obMessages.Item(i).Copy(obBackupFolder.ID)
Post by SorenR » 2014-08-26 16:02
Hmm... I made it come up with an error..
"DEBUG"	1188	"2014-08-26 15:56:37.708"	"Applying rule CopyMessage"
"DEBUG"	1188	"2014-08-26 15:56:37.708"	"Performing rule action"
"DEBUG"	1188	"2014-08-26 15:56:37.708"	"ScriptServer::FireEvent-Unknown"
"ERROR"	1188	"2014-08-26 15:56:37.724"	"Script Error: Source: hMailServer COM library - Error: 800403E9 - Description: Unable to copy message. - Line: 264 Column: 6 - Code: (null)"
"DEBUG"	1188	"2014-08-26 15:56:37.724"	"ScriptServer:~FireEvent"
None of the triggers gave any errors like OP also concluded... Global Rule -> Run function gave no error, however on Account Rule -> Run function I managed to get an error...
Perhaps we are not supposed use ".Copy" in that way :wink:
