Add Users and Aliases from CSV
JasonMcFeetors
Post by JasonMcFeetors » 2005-09-21 18:34
While I was setting up my new mail server, I wrote this script to create the users and aliases. You simply put all of the users and the aliases into a CSV file and run the script. Once it finishes, all of your users and aliases should be created for you.
Option Explicit
Dim obBaseApp
Dim objFSO
Dim objTextFile
Dim strNewAlias,i
Const ForReading = 1
Set objTextFile = objFSO.OpenTextFile("Objects.csv", ForReading) 'Change the name of Objects.csv to the name of your CSV file that you put in the same directory as the script.
Do While objTextFile.AtEndOfStream <> True
    strNewAlias = split(objTextFile.Readline, ",")
    Select Case strNewAlias(0)
    	Case "User"
		    AddUser strNewAlias(1), strNewAlias(2), strNewAlias(3)
    	Case "Alias"
		    AddAlias strNewAlias(1), strNewAlias(2), strNewAlias(3)
    End Select
    i = i + 1
Loop
Sub AddAlias(strAlias,strEmailAddress,strDomain)
	Dim obDomain
	Dim obAliases
	Dim obNewAlias
	Set obDomain = obBaseApp.Domains.ItemByName(strDomain)
	Set obAliases = obDomain.Aliases
	Set obNewAlias = obAliases.Add()
	obNewAlias.Name = strAlias & "@" & strDomain 'username
	obNewAlias.Value = strEmailAddress 'password
	obNewAlias.Active = 1 'activates user
	obNewAlias.Save() 'saves account
	Set obNewAlias = Nothing
	Set obAliases = Nothing
	Set obDomain = Nothing
Sub AddUser(strUsername, strPassword, strDomain)
	Dim obDomain
	Dim obAccounts
	Dim obNewAccount
	Set obAccounts = obDomain.Accounts
	Set obNewAccount = obAccounts.Add()
	obNewAccount.Address = strUsername & "@" & strDomain 'username
	obNewAccount.Password = strPassword 'password
	obNewAccount.Active = 1 'activates user
	obNewAccount.Maxsize = 0 'sets mailbox size, 0=unlimited
	obNewAccount.Save() 'saves account
	Set obNewAccount = Nothing
	Set obAccounts = Nothing
Make sure that the CSV file you create is in the same directory as the sccript otherwise the script will fail. Also, the CSV file needs to be in the following format:
EntryType,Field1,Field2
The EntryType can be one of two options, User or Alias. If the EntryType is User, then:
Field1 - Username
Field2 - Password
Field3 - DomainName
If the EntryType is Alias, then:
Field1 - AliasName
Field2 - ForwardingEmail
Field3 - DomainName
So, for example, if you had the following CSV file:
User,tjones,mypassword,jones.com
Alias,tommy,tjones@jones.com,jones.com
This would create a user names tjones@jones.com in the jones.com domain and an alias tommy@jones.com which will forward all e-mail to tjones@jones.com in the jones.com domain.
Hope you find this to be helpful.
lusitano
Post by lusitano » 2005-12-20 15:40
How to use this script??
Thank you :oops:
hodown
Post by hodown » 2006-01-19 01:44
to use the script copy the code and save it as import.vbs. You then need to create the Objects.csv as explained above.
does anyone have a version of this script that adds domains in on the fly also? This script doesn't cater for this.
pjcarmen
Post by pjcarmen » 2006-01-27 17:51
Great work, thanks! You saved quite a bit of time today. I had to add 60 users as well as an alias for each. Granted it's not that many users, but I tend to "fat finger" :shock: things, so this was a huge help.
It worked perfectly, once I realized that "alias" had to be "Alias", I guess it expects capitalization.
Any way to add to or modify this to help to create distribution lists?
-PJC
Jimi_l
Post by Jimi_l » 2006-02-19 01:19
What if it needed to be modified to import a CSV into the distribution list?
Apparently there are also three fields in that DB. The first is a numerical id (1,2,3, etc) the second field all have a 5 and the third is the actual E-mail address that would be imported from a CSV text file.
If this could work it would really save my bacon.
Jim
hodown
Post by hodown » 2006-04-06 21:29
hodown wrote:to use the script copy the code and save it as import.vbs. You then need to create the Objects.csv as explained above.
This script adds domains to hmailserver. Usage is: scriptname.vbs domainname.com
Therefore if you copied the following code into a file and called it 'scriptname.vbs', executed the script from the command line as above usage it would add a domain called 'domainname.com' to hmailserver:
Set oArgs = WScript.Arguments
If oArgs.count <> 1 Then
   WScript.Quit
Dim obBaseApp
Dim obNewDomain
Set obNewDomain = obBaseApp.Domains.Add()
obNewDomain.Name = oArgs(0)
obNewDomain.Active = True
obNewDomain.Save()
obBaseApp.Domains.Refresh()
mputnam
csv for distribution lists
Post by mputnam » 2006-07-19 14:39
Jimi_l wrote:What if it needed to be modified to import a CSV into the distribution list?
Jim
Hello All,
I understand in theory what the script is doing, but being a novice in this sort of thing, am a bit afraid to attempt to modify and possibly "muck up" the dbase. Can someone help me with the changing the script to upload a csv file to the dbase, for a distribution list. I have a hefty list to move over and would rather not manage with manual inserts to the dbase. :wink:
Thanx in advance
Marie
CraigHarris
Re: csv for distribution lists
Post by CraigHarris » 2006-07-19 23:30
Hello All,
Thanx in advance
Try
<?php
  //Note: This code has not been properly tested and is provided without warranties of any kind - use at your own risk.
  //Assumes perfect settings & file format as there is no proper error checking.
  $Filename = 'W:\Emails.csv';
  $FileType = 'csv'; // 'csv' expects comma's between fields, and new lines between records | ',' means comma seperated addresses with no new lines.
  $EmailField = 0; //0=first field, 1=2nd field ... (only applies if $FileType is csv)
  $DistributionList = 'List@Example.com';
  $DomainName = substr($DistributionList, strpos($DistributionList, '@')+1);
  $hMail = new COM('hMailServer.Application');
  $hMail->Connect();
  $Domain = $hMail->Domains->ItemByName($DomainName);
  $DistLists = $Domain->DistributionLists();
  $DistList = $DistLists->ItemByAddress($DistributionList);
  $Recipients = $DistList->Recipients();
  function AddEmailToList($EmailAddress) {
    global $Recipients;
    $Recipient = $Recipients->Add();
    $Recipient->RecipientAddress = trim($EmailAddress, ' ,');
    $Recipient->Save();
  $LinesRead = 0;
  $EmailCount = 0;
  $fh = fopen($Filename, 'r');
  if(!$fh) {
    die("Cannot open '{$Filename}'");
  if($FileType == ',') {
    $Addresses = explode(',', file_get_contents($Filename));
    while(list(,$Address) = each($Addresses)) {
      $EmailCount++;
      AddEmailToList($Address);
  } elseif($FileType == 'csv') {
    while(($Line = fgetcsv($fh, 1200, ',')) !== false) {
      $LinesRead++;
      if($Email = strpos($Line[$EmailField], '@') !== false) {
        $EmailCount++;
        AddEmailToList($Line[$EmailField]);
    $ListMembers = $Recipients->Count();
  } else {
    die('Upsupported file type');
  echo <<< EOR
<html>
  <head>
    <title>hMail Distribution List: load report</title>
  </head>
  <body>
    <ul>
      <li>Lines: {$LinesRead}</li>
      <li>Email Addresses: {$EmailCount}</li>
      <li>List members: {$ListMembers}</li>
    </ul>
  </body>
</html>
EOR;
This only makes changes to the specified distribution list - nothing else will be affected.
Windows Server 2003 Std ::: hMailServer 4.3 B248 ::: 99% of email rejected as spam ;)
DJP
Post by DJP » 2006-08-07 04:02
Just by copied the previous vbs and make transformed it to handle creation of distribution list. I made this very quickly so there probably are errors when distribution list already exist, etc... but worked for me since i was in a hurry to add about 200 mails in 5 distributions list and worked well :P
File format is :
Domain,yourdomain.com,distributionlistname
Mail,myuser1@domain.com
Mail,myuser2@domain.com
Mail,myuser3@domain.com
Domain,yourotherdomain.com,distributionlistname2
Option Explicit
Dim obBaseApp
Dim objFSO
Dim objTextFile
Dim strNewAlias,i
Dim strDomain, strList
Set objTextFile = objFSO.OpenTextFile("mylist.csv", ForReading) 'Change the name of Objects.csv to the name of your CSV file that you put in the same directory as the script.
       Case "Domain"
          strDomain = strNewAlias(1)
          strList = strNewAlias(2)
          AddListe strList, strDomain
       Case "Mail"
          AddMail strNewAlias(1), strList, strDomain
    End Select
    i = i + 1
Loop
Sub AddListe(strList, strDomain)
   Dim obDomain
   Dim obDistributionList
   Set obDistributionList = obDomain.DistributionLists.Add()
   obDistributionList.Address = strList & "@" & strDomain
   obDistributionList.Active = True
   obDistributionList.Save()
Sub AddMail(strEmailAddress, strList, strDomain)
   Dim obDomain
   Dim obDistributionLists
   Dim obNewMail
   Dim obRecipients
   Set obDistributionLists = obDomain.DistributionLists
   Set obDistributionList = obDistributionLists.ItemByAddress(strList & "@" & strDomain)
   Set obRecipients = obDistributionList.Recipients
   Set obNewMail = obRecipients.Add()
   obNewMail.RecipientAddress = strEmailAddress
   obNewMail.Save() 'saves account
   Set obNewMail = Nothing
   Set obDistributionLists = Nothing
   Set obDistributionList = Nothing
   Set obRecipients = Nothing
mputnam
Post by mputnam » 2006-08-23 19:28
DJP wrote:Just by copied the previous vbs and make transformed it to handle creation of distribution list. I made this very quickly so there probably are errors when distribution list already exist, etc... but worked for me since i was in a hurry to add about 200 mails in 5 distributions list and worked well :P
File format is :
Option Explicit
Dim obBaseApp
Dim objFSO
Dim objTextFile
Dim strNewAlias,i
       Case "Domain"
       Case "Mail"
    End Select
    i = i + 1
Loop
   Dim obDomain
   Dim obDomain
   Dim obNewMail
   Dim obRecipients
This could be moved to HOW TO
Adding Distribution Lists for Dummies
1) Copy and paste the code into notepad. name the file Dlist.vbs. Place this file on your mailserver in the directory /hmailserver/dbscripts
2) create your file format as shown;
REMEMBER: the first word of each line is critical to the script. Domain (first letter uppercase) will create a new distribution list for that domain. Mail (first letter uppercase) will create a new member address in that domain. You can create multiple distribution lists in one file.
3) After creating the distribution list open it in Hmail and configure the options that allow it to function.
craig@ccilegal.co.uk
Add addresses to Routes - script
Post by craig@ccilegal.co.uk » 2006-09-06 15:08
Hi
Anyone got a script to add addresses to the Routes "deliver to these addresses below"
Craig
PS thanks for the import.vbs script
SFM
Script broken in new version?
Post by SFM » 2006-12-01 20:10
I am using hmailserver 4.3 and this script dosn't seem to work.
I saw in the forum where another script had to be updated to work in 4.3.
Post by martin » 2006-12-01 20:12
Correct. After the line:
You need to add:
Call obBaseApp.Authenticate("Administrator","your-hmailserver-password")
Otherwise the script won't have access to do what it's supposed to do.
SFM
Post by SFM » 2006-12-01 20:15
Martin,
Thanks for the reply and developing a great mail server.
barcajunior
Post by barcajunior » 2008-01-05 17:14
It did save many time for me.Thank you very much.
powerful green laser pointers
Red_Scorpion
Post by Red_Scorpion » 2008-01-10 15:46
Hello Everybody,
I want to add 1500 person's email to distribition list.when I run Script I got this error,
script : c:\programfiles\hMailserver\DBScripts\Dlist.vbs
line :35
Char :4
Error :Subscript out of range
code :800A0009
Source :microsoft VBSript runtime error
how can I do? I need help quickly...
Bilgehan
Red_Scorpion
Post by Red_Scorpion » 2008-01-10 17:36
HHOOOAAAREEEEEYYYYY....
it is working...
I'm so happy,
so many thanks everyone...
Red_Scorpion
plobby
Re: Add Users and Aliases from CSV
Post by plobby » 2008-09-18 06:06
Can anyone help me out with getting this working with the current hmailserver?
Basically I need a line in there or something so it can authenticate...
Post by ^DooM^ » 2008-09-18 10:05
This should do what you need. Find the first line, add the second line.
Call obBaseApp.Authenticate ("Administrator", "YourHmailPassword")
plobby
Post by plobby » 2008-09-18 14:18
Thank you very much Doom -- I will try this later.
plobby
Post by plobby » 2008-09-19 02:07
I keep getting the same error -- would it make a difference if I am running an external MySQL database?
Script: C:\Program Files\hMailServer\DBScripts\Dlist.vbs
Line: 35
Char: 4
Error: "You do not have access to this property / method. Ensure that hMailServer.Application.Authentication() is called with proper login credentials."
Code: 800403E9
Source: hMailServer COM Library
Re:
Post by ^DooM^ » 2008-09-19 02:29
martin wrote:Correct. After the line:
You need to add:
Martin replied above with the correct code and it looks the same as mine. Are you sure the password is correct?
plobby
Post by plobby » 2008-09-19 03:01
I somehow ran over that and saw it right after you posted your reply -- Yeah I am positive it is the right password. Am I connecting to hmailserver or the mysql database for hmail?
Post by ^DooM^ » 2008-09-19 09:10
You are connected to the COM API not the database.
plobby
Post by plobby » 2008-09-19 14:57
^DooM^ wrote:You are connected to the COM API not the database.
Sorry for all the questions, I just dont feel like entering the mailing list 1 by 1...we have about 200 people on it.
One more, is there a way to test out the password besides through a script or change it? I am positive it is the right password but just to try something different.
Post by ^DooM^ » 2008-09-19 19:09
Easy way to test it is to change the hmail admin password temporarily.
Goto the hMailServer.ini file and find AdministratorPassword. Copy and paste the string of random letters and numbers into another text file. Replace that string with this one
cc03e747a6afbbcbf8be7668acfebee5
Restart the hMail service from windows.
Test your script using the following password test123
If it works with this new password then you have misremembered your old password that you were using in the script. Replace the old code, save it and restart the service again to go back to the original password.
Read this to change the admin password to something more secure if you have forgotten your original password.
http://www.hmailserver.com/documentatio ... r_password
plobby
Post by plobby » 2008-09-20 01:51
Thanks for your help yet again, and patience. I guess I wasn't so positive on it being the correct password.
Post by ^DooM^ » 2008-09-20 02:12
Did you sort it out then mate?
plobby
Post by plobby » 2008-09-20 02:20
Yes I did, thanks a lot!
desiredforsome
Post by desiredforsome » 2009-02-06 04:47
Hey i have 5.0 Does this script work wth that, When i run it it gives me.
Error
line:52
Char:4
Error: You do not have access to this property / method. Ensure that hmailServer.Application.Authticate() is called with proper login cridentals.
What do i do. Im trying to basicaly make a free user signup for email onlien, ANd i figured i can just have them fill out a form that converts it to .csv and then every 5 seconds this script runs on that .csv
gaganuiit
Post by gaganuiit » 2009-07-03 15:49
Well i have succeeded with the script.
But i would really want to have one little enhancement be done.
When i am trying to add more members to an existing distribution list, i am getting this error
Failed to save object. Another object with the same name already exists in this domain.
This is because the same distribution list already exists.
Suggestions please.
Melibokus73
Post by Melibokus73 » 2009-07-24 10:58
Hi ...
Does this original "ADD-Users"script also work with 5.x (5.2) :?:
Post by ^DooM^ » 2009-07-24 11:23
Try it ;)
Melibokus73
Post by Melibokus73 » 2009-08-19 19:43
^DooM^ wrote:Try it ;)
It seems to run ... 8)
(after adding the Line with the Password) .... :!:
jujb.cn
Post by jujb.cn » 2013-05-23 11:14
JasonMcFeetors wrote:While I was setting up my new mail server, I wrote this script to create the users and aliases. You simply put all of the users and the aliases into a CSV file and run the script. Once it finishes, all of your users and aliases should be created for you.
Option Explicit
Dim obBaseApp
Dim objFSO
Dim objTextFile
Dim strNewAlias,i
    	Case "User"
    	Case "Alias"
    End Select
    i = i + 1
Loop
	Dim obDomain
	Dim obAliases
	Dim obNewAlias
	Dim obDomain
	Dim obAccounts
	Dim obNewAccount
Field1 - Username
Field2 - Password
Field3 - DomainName
Field1 - AliasName
Field3 - DomainName
Using the code above, I had made a file of import.vbs, after excuting the import.vbs, screen tip is following:
Script: E:\hMailServer\hMailServer\import.vbs
Line: 52
Char: 4
Error: You do not have access to this property / method. Ensure that hMailServer. Applicaton. Authenticate ( ) is called whth proper login credentials.
Code: 800403E9
Source: hMailServer COM library
I have upload the file of import.vbs.
Would you give me a file of import.vbs without any error?
Thanks!
Post by mattg » 2013-05-23 11:32
This was probably written for an earlier version.
You will need to authenticate.
Add this line after 'set' lines and before the 'do while'
Call obBaseApp.Authenticate("Administrator", "SecretPassword")    ' change me
Change to your password, and then run.
Post back if that works (or if it doesn't), and I'll update the script as shown in your post.
jujb.cn
Post by jujb.cn » 2013-05-23 17:10
After added the code(Call obBaseApp.Authenticate("Administrator", "SecretPassword") ' change me),and excuting the import.vbs, screen tip is following as:
Line: 62
Char: 4
Error: Failed to save object. Another object with the same name already exists in this domain.
Code: 800403E9
Post by percepts » 2013-05-23 17:36
you are trying to add an account which already exists in hms.
The script doesn't trap save errors so there is no logging of which account it is. You can either modify script to trap save errors and report which account is already in hms or analyse your input file for duplicates and against what is already in hms.
N.B. if your script failed half way through then half of the accounts in your input file will be now be in hms.
You really need to modify script to check if account or alias already exists before trying to add it. Or modify to trap failed save(and report because fail may not be due to duplicate) and continue processing input file.
jujb.cn
Post by jujb.cn » 2013-05-23 18:09
Dear Mattg and percepts,
Yours is excellent !
After I deleted accounts which already exist in hMailServer in the objects.csv, I made it.
Thanks!
Jujb.cn
Post by mattg » 2013-05-24 01:03
percepts has created a ver 5 of this script
http://www.hmailserver.com/forum/viewto ... 20&t=24810
jr3151006
Post by jr3151006 » 2014-12-09 14:53
Can someone tell me if this script also creates the DOMAIN before create users???
Post by percepts » 2014-12-09 15:13
this version does not. The version I pointed you to does.
Use this one viewtopic.php?f=20&t=24810#p151855
It only adds domains if they are not already there.
