Block attachments
Block attachments
Post by percepts » 2014-03-16 15:34
Seems their are some oddities in anti virus attachment blocking mechanism so here are a couple of scripts to get around the problem. Take your pick according to how you want unwated attachments to be handled.
First provided by LesD ( topic: http://www.hmailserver.com/forum/viewto ... dd#p154541 )
This one will reject the whole email back to sender. It allows local users to send without blocking
' Ignore messages from local users
  if oClient.Username = "" then
    Dim oAttachment
    Dim oRegExp
    Set oRegExp = new RegExp
    For oAttachment = 0 to oMessage.Attachments.Count-1
    ' Test for undesirable attachments
      with oRegExp
          .Pattern = "^.*\.(bat|cmd|com|cpl|csh|docm|exe|hta|htb|inf|js|jse|lnk|msi|msp|pif|reg|scf|scr|shs|shb|vbe|vbs|wsf|wsh|zip)$"
          .IgnoreCase = True
          .Global = False
      end with
      if (oRegExp.test(oMessage.Attachments(oAttachment).Filename)) Then
       ' Log in event log
        EventLog.Write ("Email Rejected: Attachment unacceptable: " _
          & oMessage.Attachments(oAttachment).Filename & "  Size : " _
          & oMessage.Attachments(oAttachment).Size)
       ' Text to include with 550 rejection message
        Result.Message = "Email Rejected : Attachment <" _
          & oMessage.Attachments(oAttachment).Filename & "> is not acceptable"
        Result.Value = 2      ' Reject'
    Set oRegExp = nothing
  End if
Second one provided by Percepts
This one gives you two options, Firstly you can quarantine the attachment and let the email through and secondly you can just delete the attachment and let the email through. Quarantine = False provides same functionality as antivirus attachment blocking is supposed to do.
To implement add a global rules which says
message size > 0
run function DeleteAttachments
Add following code to end of your eventhandlers.vbs file.
and note the variables below that you need to set.
Quarantine
QuarantineFolder
FileExtensions
Sub DeleteAttachments(oMessage)
' this routine deletes or quarantines file attachments that have the specified
' FileExtensions. It replaces the functionality of antivirus blocked attachments panel in hmailadmin
' with optional quarantine
' un-comment following line and last End If at end of sub to only apply for external accounts
' if oClient.Username = "" then
  Dim Quarantine  ' set to True to Quarantine or False to Delete attachments
  Quarantine = False
  Dim QuarantineFolder       'where to store quarantined attachments. Must be pre created
  QuarantineFolder = "c:\path to\hmailserver\Attachment-Quarantine\"     ' trailing slash is required
  Dim QuarantineFile
  Dim FileExtensions ' set to the file attachment extensions you want to delete or quarantine
  FileExtensions = "(bat|cmd|com|cpl|csh|docm|exe|hta|htb|inf|js|jse|lnk|msi|msp|pif|reg|scf|scr|shs|shb|vbe|vbs|wsf|wsh|zip)"
 ' change anything below here at your own risk.
  Dim AttachmentDeleteNotify
  AttachmentDeleteNotify = Empty
  Dim oAttachment
  Dim oRegExp
   with oRegExp
    .Pattern = "^.*\."& FileExtensions & "$"
    .IgnoreCase = True
    .Global = False
   end with
    ' Delete Attachment
    AttachmentDeleteNotify = AttachmentDeleteNotify & oMessage.Attachments(oAttachment).Filename & "~"
    If (Quarantine) Then
     QuarantineFile = QuarantineFolder & oMessage.Attachments(oAttachment).Filename & "." _
      & Left(Right(oMessage.Filename,42),38) & ".Quarantined"
     oMessage.Attachments(oAttachment).SaveAs(QuarantineFile)
     oMessage.Attachments(oAttachment).Delete
  If Not IsEmpty(AttachmentDeleteNotify) then
   AttachmentDeleteNotify = "The following attachment/s were blocked for delivery by the e-mail server." & "~" _
   & "Please contact your system administrator if you have any questions regarding this." & "~"  & "~" _
   & AttachmentDeleteNotify _
   & "~" & "hmailserver" & "~" & "~"
   Dim htmlNotify
   htmlNotify = AttachmentDeleteNotify
   If ( Len(oMessage.Body) <> 0 ) Then
    AttachmentDeleteNotify = Replace(AttachmentDeleteNotify, "~", VbCrLf)
    oMessage.Body = oMessage.Body & VbCrLf & VbCrLf & AttachmentDeleteNotify
   If ( Len(oMessage.HTMLBody) <> 0 ) Then
    htmlNotify = Replace(htmlNotify, "~", ("<br>" & VbCrLf))
    oMessage.HTMLBody = Replace(oMessage.HTMLBody, "</body", ("<br><br>" & htmlNotify & "</BODY"), 1, 1, vbTextCompare)
' End if
Re: Block attachments
Post by jimimaseye » 2014-07-31 10:51
Having read that thread (which led to the finalised script above), I too had ONE instance of the 'oddity' where the Zip file was not completely removed just like Les reported (although it has only happened once).
My question is, how can that script be used or modified to serve those that do not use direct inbound SMTP deliveries and collect all mail via an External Download? (as the 'OnAcceptMessage' feature is not relevant in this case)
Post by mattg » 2014-07-31 12:43
You could make it another function, and call that function from a rule
Post by percepts » 2014-07-31 14:32
OR
use the second script which is run from global rules and not OnAcceptMessage
Post by jimimaseye » 2014-07-31 14:48
oh yeah. :oops:
oneday
Post by oneday » 2014-08-29 20:58
Percepts,
I am trying to use your script, but when I comment out the line:
and the subsequent End if, I get the following error:
"ERROR" 896 "2014-08-29 12:38:13.896" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01A8 - Description: Object required: 'oClient' - Line: 7 Column: 2 - Code: (null)"
am I missing something?
Post by percepts » 2014-08-29 21:08
Probably but I have no idea since I can't see what you've done.
oneday
Post by oneday » 2014-08-29 21:52
This is my script. It works fine as long as I don't uncomment out that line
Quarantine = True
QuarantineFolder = "C:\Attachment-Quarantine\" ' trailing slash is required
Dim QuarantineFile
AttachmentDeleteNotify = Null
Dim oAttachment
Dim oRegExp
Dim oWho
oWho = Null
Dim oRecipients
For oRecipients = 0 to oMessage.Recipients.Count-1
oWho = oWho & oMessage.Recipients(oRecipients).Address
with oRegExp
.IgnoreCase = True
.Global = False
end with
' Delete Attachment
& Left(Right(oMessage.Filename,42),38) & oWho(-1) & ".Quarantined"
If Not IsNull(AttachmentDeleteNotify) then
AttachmentDeleteNotify = " - Attachment/s blocked: " & AttachmentDeleteNotify & " contact quarantine@data-rx.com if you need this."
oMessage.Subject = oMessage.Subject & AttachmentDeleteNotify
' End if
Post by percepts » 2014-08-29 22:11
OK, the reason it doesn't work is because oClient is not passed to the sub when calling it from a rule.
So you need to delete the rule that calls it and then edit eventhandlers.vbs and put following line in OnAcceptMessage
DeleteAttachments oClient,oMessage
and then change
to
Sub DeleteAttachments(oClient,oMessage)
and then you can uncomment those two lines and it should work only deleting attachments for NON Authenticated users.
Post by percepts » 2014-09-01 15:03
**** Version 2. ****
Some mods specifically for those using the quarantine option to make it easier to find quarantined files
by adding "Notice ID" to mail which is also used as start of quarantine file names. Also quarantined files for a mail have attachment number added to stop duplicates if same filename is attached to mail twice.
Seems their are some oddities in anti virus attachment blocking mechanism so here is a script to get around the problem.
This script gives you two options, Firstly you can quarantine the attachment and let the email through and secondly you can just delete the attachment and let the email through. Quarantine = False provides same functionality as antivirus attachment blocking is supposed to do.
message size > 0
Quarantine
QuarantineFolder
FileExtensions
' and also has a selectable quarantine option
  Quarantine = True
  Dim QuarantineFolder   'where to store quarantined attachments. This folder must already exist.
  QuarantineFolder = "c:\path to quarantine folder\"     ' trailing slash is required
  Dim QuarantineFile
  FileExtensions = "(bat|cmd|com|cpl|csh|docm|exe|pif|hta|htb|inf|js|jse|lnk|msi|msp|pif|reg|scf|scr|shs|shb|vbe|vbs|wsf|wsh)"
  Dim oAttachment
  Dim oRegExp
   with oRegExp
    .IgnoreCase = True
    .Global = False
   end with
    ' Delete Attachment
     QuarantineFile = QuarantineFolder & Left(Right(oMessage.Filename,42),38) _
      & "." & oAttachment & "." & oMessage.Attachments(oAttachment).Filename & "." & ".Quarantined"
   & "Notice ID: " & Left(Right(oMessage.Filename,42),38) & "~" & "~" _
   & "~" & "Mail Server Admin" & "~" & "~"
   Dim htmlNotify
