Block certain domain
bernikm
Post by bernikm » 2013-02-21 14:35
Hi
Is it possible and how to block certain domain so that mail received from this domain will be rejected?
Regards
Mike
Re: Block certain domain
Post by mattg » 2013-02-21 14:59
sure
Use a global rule
bernikm
Post by bernikm » 2013-02-21 17:31
Hi
We tried but it seems it doesn't work. Mail send from added domains still comes into user mailbox.
We created the followin rule (under Rules)
Criteria Use OR
Field: From
Comparison: @io.ocn.ne.jp
Actions: Delete e-mail
Field: From
Comparison: @m3.myzamanamail.com
Post by Bill48105 » 2013-02-21 18:46
did you do "contains" for criteria? Or wildcard & *@thedomain.com
bernikm
Post by bernikm » 2013-02-22 10:29
Hi
I tried both it none of the seems to work.
Please look at the attached picture from my rules in hmailserver.
Regards,
Mike
Post by Bill48105 » 2013-02-22 16:08
Did you check SMTP logs to make sure sender isn't spoofed?
bernikm
Post by bernikm » 2013-02-22 16:40
Yes.
I have also tried to add google domain block rule list but mail isn't deleted based on a defining rule.
So is looks like general rule doesn't work in some way?
Post by Bill48105 » 2013-02-22 16:49
We all use rules & know they work including what you're trying to do. From what I can tell your rule looks ok so the only explanation is the from is not what you think. We'd need to see log lines from the message coming in and/or headers.
