Winsock Error : No buffer space available
- New user
I'm getting "No buffer space available" error. Can anyone tell me what this might be caused by?
Sent: Wed, 10 Aug 2005 13:25:41 -0500
Subject: Announcement
okbdurlin@sencom.net
Error type: Winsock
Error Description: No buffer space available.
Tried 5 time(s)
MailDaemon
hMailServer
Error type: Winsock
Tried 5 time(s)
MailDaemon
hMailServer
I wish people would give at least some background when reporting these kinds of error. Without having any clue on the background, you would have to be an oracle to say why you got that message
1) Has this problem occured recently? Or has it "always" been this way?
2) Have you tried sending to other addresses?
3) What operating system are you using?
4) Are you using any bandwidth limiters or monitors, such as NetLimiter?
5) Are you running any "live" anti virus scanner on the computer that monitors network traffic?
- New user
Ha!, yes that's what I usually complain about too. Sorry.
1) This occurred during a large send of about 2000 emails via smtp from a client website located on the same server running IIS v6.0.
The server has 768MB RAM, is 2.6GHZ.
2) Yes, other addresses were sent successfully (about 1600 of the 2k) - about 400 emails came back this way.
3) Windows Server 2003
4) No bandwidth limiters.
5) No anti virus scanners
No problem. I'm really used to it here.
What hMailServer version are you using?
Open up a command prompt and run netstat -a and paste the output here.
In 4.0, some users have had problems that outgoing sockets aren't always properly closed. This may have give the problem you're experiencing if you do large sendouts. I've not been able to reproduce it myself but I've located and fixed the problem in 4.1.
I think it's also possible to get this error if you have defined a huge number of delivery threads and don't have a fast internet connection. Have you modified the delivery threads setting?
- New user
- New user
- New user
- New user
This time I was logging everything and here are the results...
(do these help to tell you anything?)
The reply 'bounced' message came back as this:
Sent: Thu, 18 Aug 2005 09:34:06 -0500
Subject: convention registration
esidders@smps.k12.ok.us
Error type: Winsock
Tried 5 time(s)
This is what was in the log file: "hmailserver_2005-08-18.log"
"DEBUG" 3060 "2005-08-18 13:44:27.026" "MessageCreator::~CreateMessage()"
"DEBUG" 3244 "2005-08-18 13:44:27.026" "SD:_DeliverToExternalAccounts"
"DEBUG" 2308 "2005-08-18 13:44:27.026" "ClientConnection::Connect() - Failed to connect."
"DEBUG" 3904 "2005-08-18 13:44:27.042" "PersistentMessage::~ReadObject()"
"DEBUG" 2892 "2005-08-18 13:44:27.042" "PMADO:~AddObject()"
"DEBUG" 3060 "2005-08-18 13:44:27.042" "PersistentMessage::DeleteObject()"
"DEBUG" 3472 "2005-08-18 13:44:27.042" "PMADO:~SaveObject()"
"TCPIP" 3244 "2005-08-18 13:44:27.042" "DNS - MX Lookup: seiling.k12.ok.us"
"DEBUG" 2308 "2005-08-18 13:44:27.042" "SD:~_InitiatzeExternalConnection-4"
"DEBUG" 3904 "2005-08-18 13:44:27.058" "PersistentMessage::ReadObject()"
"DEBUG" 2532 "2005-08-18 13:44:27.058" "SD:DeliverMessage"
"DEBUG" 3472 "2005-08-18 13:44:27.058" "MessageCreator::~CreateMessage()"
"TCPIP" 3244 "2005-08-18 13:44:27.058" "DNS - MX Result: 2 servers"
"DEBUG" 2308 "2005-08-18 13:44:27.058" "SocketConnection::~SocketConnection()"
"APPLICATION" 2532 "2005-08-18 13:44:27.073" "SMTPDeliverer - Message 5972: Delivering message from bounced@thebestportals.com to esidders@smps.k12.ok.us. File: C:\Program Files\hMailServer\Data\{5D10164E-CA43-42B7-B7B8-E516FF7A1E88}.eml"
This is what was in the error log file from the day before:
(filename: "ERROR_hmailserver_2005-08-17.log")
"ERROR" 2328 "2005-08-17 10:42:34.542" "Source: SMTPConnection::_OnPreAcceptTransfer(), Code: HM10013, Description: Rejected message because not mail data has been saved in file C:\Program Files\hMailServer\Data\{28C1497B-269E-4F68-82F5-F783975A8E90}.eml"
Error type: Winsock
Tried 5 time(s)
- New user
- New user
Okay, it happened again, and this time I went in and did the netstat -a, and here's what it showed:
basically it was line after line of these:
TCP englishwebserve:3282 beholder.wilnet1.com:smtp CLOSE_WAIT
TCP englishwebserve:3284 okcps.org:smtp CLOSE_WAIT
TCP englishwebserve:3285 mta-v26.level3.mail.yahoo.com:smtp CLOSE_WAIT
TCP englishwebserve:3288 70.129.69.15:smtp CLOSE_WAIT
TCP englishwebserve:3297 mx2.pldi.net:smtp CLOSE_WAIT
TCP englishwebserve:3298 wilson.k12.ok.us:smtp CLOSE_WAIT
here is the undeliverable message:
Sent: Fri, 19 Aug 2005 16:24:15 -0500
Subject: Meeting
jmaciel@hps.k12.ok.us
Error type: Winsock
Tried 5 time(s)
Subject: Meeting
Error type: Winsock
Tried 5 time(s)
- New user
Oh, and the netstat ended with:
TCP englishwebserve:netbios-ssn englishwebserve:0 LISTENING
UDP englishwebserve:snmp *:*
UDP englishwebserve:microsoft-ds *:*
UDP englishwebserve:isakmp *:*
UDP englishwebserve:ms-sql-m *:*
UDP englishwebserve:l2tp *:*
UDP englishwebserve:3008 *:*
UDP englishwebserve:3009 *:*
UDP englishwebserve:3081 *:*
UDP englishwebserve:3123 *:*
UDP englishwebserve:3124 *:*
UDP englishwebserve:3147 *:*
UDP englishwebserve:3456 *:*
UDP englishwebserve:3508 *:*
UDP englishwebserve:3514 *:*
UDP englishwebserve:3753 *:*
UDP englishwebserve:3756 *:*
UDP englishwebserve:4500 *:*
UDP englishwebserve:ntp *:*
UDP englishwebserve:netbios-ns *:*
UDP englishwebserve:netbios-dgm *:*
UDP englishwebserve:3006 *:*
UDP englishwebserve:3007 *:*
UDP englishwebserve:bootps *:*
- New user
- New user
Oh, you're right, sorry.
This happens about 1-2 times every week. In this case, I can only restart the server to restart the smtp queue.
This happens for every address, every user.
Windows 2003 SBS
No.
Not at all, only ClamWin.
Tell me if you need some other thing.
Thanks a lot.
Windows 2003 SBS
No.
Thanks a lot.
When the problem occurs, can you do other network related things, such as browsing the web using your web browser? Is it only hMailServer which stops to work or is it all applications?
Can you download LSP-Fix and check which LSP's you have installed?
http://cexx.org/lspfix.htm
(Whatever you do, don't remove any of the installed ones)
- New user
- New user
Tipo evento: Errore
Origine evento: Userenv
Categoria evento: Nessuno
ID evento: 1053
Data: 06/12/2006
Ora: 15.19.26
Utente: NT AUTHORITY\SYSTEM
Computer: MAIL2
Descrizione:
Impossibile determinare il ruolo del computer. (Memoria disponibile insufficiente per completare l'operazione. ). Elaborazione Criteri di gruppo interrotta.
Per ulteriori informazioni, consultare la Guida in linea e supporto tecnico all'indirizzo http://go.microsoft.com/fwlink/events.asp.
ID evento: 1053
Data: 06/12/2006
Ora: 15.19.26
Computer: MAIL2
Descrizione:
- New user
- New user
Did the two problems appear exactly the same time? Was the message reported to the event log the previous time hMailServer SMTP stopped as well? The next time the problem occurs, run TCPview and give us the output from it:
http://www.microsoft.com/technet/sysint ... pView.mspx
Also, it would be good if you opened up the task manager, and check how many handles hMailServer are using.Did
- New user
I've got the same problem with Winsock buffers... I have it in 4.3 version, but had it also in the previous..
It happens in not equal intervals, but at least once per week. I recognize it, because sudently i'm receiving less mails than normal (less spam
So mail server stops receiving email. I can see also, that RoundCube stops working because of mysql conection problem. Finally some of the network services stop working, because of "no buffer space available".
The server doesn't take more ram this time, hmailserver.exe doesn't have more handles than normal.. And it happens while normal day, not while send some massive mailing... My servers gets around 1k mails a day so it's not overloaded.
To remove the problem i have to restart hMailServer service, and then I have few days of great working server. I think problem is somewhere in hMail and connection closing.
Server OS is Win 2k3 Web Edition
I have been using Win 2k3 Web edition with no such issues. Are you running any anti virus on your server that could be intercepting emails to scan them? How much memory do you have in your machine (I know you said it wasn't an issue but if its less than 1 gig it could well be that it's just running out of memory ) You could try increasing your swap file size although windows should do that anyway when it needs it.
1. I suppose that it's not OS problem
2. Memory isn't a problem.. I've only 380MB of total memory usage !
Today i did my first mass mailing (newstletter to my website users). Around 16k emails and hMail stopped suddenly sending it's queue. I had to restars service and it now sends them again.. But that's not solution for me restarting hmail few days..
I really suppose that there is some problem with connections handling...
Adek,
1) are you running any anti virus scanner on the server?
2) When the problem occurs, how many handles does hMailServer have open? (It's viewable in the task manager)
3) Can you run Microsofts TCPView the next time the problem occurs to check how many sockets hMailServer has open?
I'm far from sure that this is an issue in hMailServer. There's lots of other software and driver issues which can have this effect on hMailServer. I'm not saying that it isn't an hMailServer issue, I'm far from sure. The TCP/IP implementation in hMailServer 4.3 has been rewritten from scratch and now uses a completely different model than before. The fact that you had the problem both in the old version and in the new indicates that the problem is actually outside hMailServer. But as I said, I'm assuming nothing.
I've still got some problems to send my Newsletter... So what i'm doing...
1. hMailServer stopped sending it's queue. I don't know why, but stopped.
2. I'm restarting hMailServer service:
As you can see, the service doesnt stop normally.. Something goes wrong there, but finally it's stopped so I can run it again.
3. hMailServer starts sending its mail queue... I can see CPU usage, and network usage.. This time hmail Server has 760 - 900 Handles and around 80 threads... As I can see in logs, hMail sent around 1000 emails..
4. After while hmail seems to be stopped.. Resources usage goes down, handles are at 760-800 and Threads at 79... And no mail are send from queue..
CPU Usage:
Net Usage [1%=1Mbps]:
I tried some changes in sending Threading options but it does not solve the problam in any way.
>net stop hmailserver
The service is not responding to the control function.
More help is available by typing NET HELPMSG 2186.
>net start hmailserver
The hMailServer service was started successfully.
CPU Usage:
I've set hMail performance to use 50 command threads, and 50 delivery threads (there is no difference beetwen this setting and original).
I disabled antivirus spam. IP range of web server has "no spam scan". There are still 10k mails in hmail's output queue but hmail isn't sending them. TCPView looks like that:
My Error_log show mostly DNSResolver problems... here are some other wntries (they occured few times today):
"ERROR" 3996 "2006-12-14 19:08:56.937" "Source: DNSResolver::_Resolve, Code: HM10081, Description: DNS query failure. Treating as temporary failure. Query: 69.157.63.62.relays.ordb.org, Type: 1, DnsQuery return value: 1460."
"ERROR" 3796 "2006-12-14 19:14:48.468" "Source: IOCPServer::AssignSocketToIOCP, Code: HM4319, Description: CreateIoCompletionPort() failed. Error: 6"
"ERROR" 1356 "2006-12-14 19:16:47.062" "Source: DNSResolver::_Resolve, Code: HM10081, Description: DNS query failure. Treating as temporary failure. Query: ty.pl, Type: 15, DnsQuery return value: 1460."
"ERROR" 1356 "2006-12-14 19:16:47.062" "Source: DNSResolver::GetEmailServers, Code: HM10082, Description: Failed to resolve email servers."
1. I can telnet it
2. I can connect via POP3 and check for new mails
3. I can connect via SMTP and send mail.. (but it wont be delivered by hMail, even to local account).
I stopped and started it from hMailServer Administrator and hMail delivery started.. but it delivery stopped after 2-3 mins with similar effect as previous.
Below you can see Performance Chart for some counters that can be usefull.. I recorded it since service start till stop delivering... Interval is 5 sec...
As you can see everything goes down sudently (Except Connections Active)
No. I MUST restart service to have delivery working.. And afer restart i't working for 2-3 mins (you can see it on begginign of chart) and then stops.. and the only solution to get it working again is to restart service..martin wrote:So even though you did not restart the hMailServer service, the delivery started again for some time? Before, did it run for 2-3 minutes before it stopped as well?
I was trying to wait even a few hours to see if it start delivert by itself.. but it doesnt...
My web server sends all emails to this hMail server.. And it has to send them directly to recipients (I have no SMTP routes specified. I have no SMTP Relayer defined).martin wrote: Are you routing all outgoing email through the same server, or do you send it directly to the recipients server?
When you click stop and start in hMailServer Administrator, you don't restart the hMailServer service. You restart the TCP/IP server which runs inside the hMailServer service. The hMailServer service continues to run even if you click "Stop" in hMailServer Administrator.
Is it possible for me to log on the server remotely (using rdp) and check for myself? I'm not really sure what to look after but sometimes a new pair of eyes find new things to look into? If so, you can send me login info in a PM.
PROBLEM SOLVED
I found the reason of this problem... It's silly stupid...
I recognized that every time i restart hMailServer it sends around 1k of email and suddently stops. I've just connected it to some option in hMailServer.... "Send statistics do hMailServer.com every 1000 message"
I disabled this option, and now hMailServer works GREAT. It already sent 4k emails since restart and is still sending
So there was problem to send statisctics to hmailsrver.com and it was reason of stopping the serwer (i think it shouldn't happen).
I've set security policy on server, that doesn't allow any other traffic than pop3, smtp and http to go in/out from server. To browse web pages on server i'm using other proxy server.
So hMail couldn't connect any way to hmailserver.com and was stopping delivery threads.
That sounds good. I'm going to wait a few days before I say "great news" though.
Glad to be able to add another 'perfect-example-of-why-one-should-never-assume-anything-during-troubleshooting' to my already long list.
Would appreciate if you could give feedback in a couple of days if it still works. If so, I'll look into why the failure of sending statistics stops the delivery. (There should be a timeout mechanism preventing this)
- New user
Hi all,
this is the result of tcpview when my mailserver stop sending mail:
[System Process]:0 TCP mail2.filmmastergroup:smtp e182066079.adsl.alicedsl.de:2612 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:smtp 192.168.0.7:3118 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 1.26.219.177:2389 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 1.26.219.177:ms-olap1 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 1.31.104.82:50228 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 1.31.104.82:50229 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 1.36.45.75:22424 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 net84-253-152-152.mclink.it:13503 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 fmsg-mi1.gag.it:61409 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 85-18-175-242.ip.fastwebnet.it:50889 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 85-18-175-242.ip.fastwebnet.it:62679 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 85-18-175-242.ip.fastwebnet.it:1705 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 fmsg-mi1.gag.it:61407 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 fmsg-mi1.gag.it:61400 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 85-18-175-242.ip.fastwebnet.it:50886 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 85-18-175-242.ip.fastwebnet.it:52793 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 85-18-175-242.ip.fastwebnet.it:4055 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 85-18-175-242.ip.fastwebnet.it:52792 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 fmsg-mi1.gag.it:61401 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 85-18-175-242.ip.fastwebnet.it:50576 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 85-18-175-242.ip.fastwebnet.it:2200 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 85-18-175-242.ip.fastwebnet.it:50575 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.159:50177 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.159:50176 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 host146-41-static.35-85-b.business.telecomitalia.it:51870 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.162:49555 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.20:2839 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.66:49534 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.162:49554 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.219:4210 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.240:49217 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.149:3158 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.163:50003 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.240:49218 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.61:50795 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.240:49219 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.127:3433 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.62:3697 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.127:3437 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.127:3439 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.127:3441 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.127:3443 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.141:3416 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.180:3435 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.72:49586 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.240:49220 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.7:3169 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.175:1817 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.167:53468 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 fmsg-mi1.gag.it:61412 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.163:50004 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.127:3457 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.129:50903 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 host146-41-static.35-85-b.business.telecomitalia.it:51877 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 85-18-175-242.ip.fastwebnet.it:50890 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 85-18-175-242.ip.fastwebnet.it:62680 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 85-18-175-242.ip.fastwebnet.it:50530 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 85-18-175-242.ip.fastwebnet.it:49356 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 85-18-175-242.ip.fastwebnet.it:52796 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 85-18-175-242.ip.fastwebnet.it:52795 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 85-18-175-242.ip.fastwebnet.it:50577 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 net84-253-152-152.mclink.it:13505 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:smtp 17.254.6.151:35731 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:smtp 91.76.81.143:remote-winsock TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.129:50905 TIME_WAIT
[System Process]:0 TCP mail2.filmmastergroup:pop3 192.168.0.162:49560 TIME_WAIT
alg.exe:1644 TCP mail2:1049 mail2:0 LISTENING
dfssvc.exe:1788 UDP mail2:1163 *:*
hMailServer.exe:372 TCP mail2:smtp mail2:0 LISTENING
hMailServer.exe:372 TCP mail2:pop3 mail2:0 LISTENING
hMailServer.exe:372 TCP mail2:imap mail2:0 LISTENING
hMailServer.exe:372 TCP mail2:1038 localhost:3307 ESTABLISHED
hMailServer.exe:372 TCP mail2:1040 localhost:3307 ESTABLISHED
hMailServer.exe:372 TCP mail2:1041 localhost:3307 ESTABLISHED
ismserv.exe:1908 TCP mail2:activesync localhost:ldap ESTABLISHED
ismserv.exe:1908 TCP mail2:1036 localhost:ldap ESTABLISHED
ismserv.exe:1908 TCP mail2:1037 localhost:ldap ESTABLISHED
ismserv.exe:1908 UDP mail2:1033 *:*
llssrv.exe:1928 UDP mail2:1173 *:*
lsass.exe:708 TCP mail2:kerberos-sec mail2:0 LISTENING
lsass.exe:708 TCP mail2:ldap mail2:0 LISTENING
lsass.exe:708 TCP mail2:464 mail2:0 LISTENING
lsass.exe:708 TCP mail2:ldaps mail2:0 LISTENING
lsass.exe:708 TCP mail2:1025 mail2:0 LISTENING
lsass.exe:708 TCP mail2:1028 mail2:0 LISTENING
lsass.exe:708 TCP mail2:msft-gc mail2:0 LISTENING
lsass.exe:708 TCP mail2:msft-gc-ssl mail2:0 LISTENING
lsass.exe:708 TCP mail2.filmmastergroup:ldap mail2.filmmastergroup:4764 ESTABLISHED
lsass.exe:708 TCP mail2.filmmastergroup:1025 mail2.filmmastergroup:1091 ESTABLISHED
lsass.exe:708 TCP mail2.filmmastergroup:1025 mail2.filmmastergroup:1172 ESTABLISHED
lsass.exe:708 TCP mail2.filmmastergroup:1172 mail2.filmmastergroup:1025 ESTABLISHED
lsass.exe:708 TCP mail2:ldap localhost:1036 ESTABLISHED
lsass.exe:708 TCP mail2:ldap localhost:1037 ESTABLISHED
lsass.exe:708 TCP mail2:ldap localhost:activesync ESTABLISHED
lsass.exe:708 UDP mail2:isakmp *:*
lsass.exe:708 UDP mail2:ipsec-msft *:*
lsass.exe:708 UDP mail2.filmmastergroup:389 *:*
lsass.exe:708 UDP mail2.filmmastergroup:kerberos-sec *:*
lsass.exe:708 UDP mail2.filmmastergroup:464 *:*
mysqld-nt.exe:1896 TCP mail2:3307 mail2:0 LISTENING
mysqld-nt.exe:1896 TCP mail2:3307 localhost:1040 ESTABLISHED
mysqld-nt.exe:1896 TCP mail2:3307 localhost:1041 ESTABLISHED
mysqld-nt.exe:1896 TCP mail2:3307 localhost:1038 ESTABLISHED
ntfrs.exe:1952 TCP mail2:1046 mail2:0 LISTENING
ntfrs.exe:1952 TCP mail2.filmmastergroup:1091 mail2.filmmastergroup:1025 ESTABLISHED
ntfrs.exe:1952 TCP mail2.filmmastergroup:4764 mail2.filmmastergroup:ldap ESTABLISHED
ntfrs.exe:1952 UDP mail2:1047 *:*
sbscrexe.exe:216 UDP mail2:1659 *:*
spoolsv.exe:1680 UDP mail2:1318 *:*
svchost.exe:1084 TCP mail2:epmap mail2:0 LISTENING
svchost.exe:1084 TCP mail2:http-rpc-epmap mail2:0 LISTENING
svchost.exe:1140 UDP mail2:1056 *:*
svchost.exe:1140 UDP mail2:1029 *:*
svchost.exe:1140 UDP mail2:1075 *:*
svchost.exe:1140 UDP mail2:1794 *:*
svchost.exe:1140 UDP mail2:1793 *:*
svchost.exe:1140 UDP mail2:1364 *:*
svchost.exe:1140 UDP mail2:1670 *:*
svchost.exe:1140 UDP mail2:1649 *:*
svchost.exe:1224 UDP mail2.filmmastergroup:ntp *:*
svchost.exe:1224 UDP mail2:ntp *:*
System:4 TCP mail2:microsoft-ds mail2:0 LISTENING
System:4 TCP mail2.filmmastergroup:netbios-ssn mail2:0 LISTENING
System:4 UDP mail2:microsoft-ds *:*
System:4 UDP mail2.filmmastergroup:netbios-dgm *:*
System:4 UDP mail2.filmmastergroup:netbios-ns *:*
winlogon.exe:644 UDP mail2:1108 *:*
winvnc4.exe:316 TCP mail2:5800 mail2:0 LISTENING
winvnc4.exe:316 TCP mail2:5900 mail2:0 LISTENING
winvnc4.exe:316 TCP mail2.filmmastergroup:5900 192.168.0.7:2406 ESTABLISHED
- New user
- New user
- New user
