Number of messages sent per-domain
maggiore81
Post by maggiore81 » 2012-05-29 15:03
Hello
It is possibile to achieve the number of total messages sent on a domain-basis?
A monthly number, etc.
thank you
Mr. Spadoni
Network Administrator
Spadhausen ISP
admin (at) spadhausen . com
Re: Number of messages sent per-domain
Post by Bill48105 » 2012-05-29 15:57
If AWSTATS logging is enabled should be pretty easy from there otherwise you'd need to script something which you'd check cuz someone else might have done something useful.
maggiore81
Post by maggiore81 » 2012-07-01 12:50
I have the logging via AWSTATS for the mail server, but I cannot see the email sents per-domain
Mr. Spadoni
Spadhausen ISP
Post by mattg » 2012-07-01 14:13
Have you set up AWstats?
maggiore81
Post by maggiore81 » 2012-07-01 14:17
Of Course.
I have made a conf file and I can get some stats
Mr. Spadoni
Spadhausen ISP
Post by mattg » 2012-07-02 14:38
Thanks for the PM with the link to your AWStats page.
From the AWStats documentation here >> http://awstats.sourceforge.net/docs/aws ... .html#MAIL
There is a config file entry
ShowDomainsStats=
What happens if you set that to 0 rather than letters?
I'm only guessing, but I've just googled a few blogs on how to generate stats per domain with AWStats
maggiore81
Post by maggiore81 » 2012-07-02 18:02
I updated the awstats with your value
nothing changed.
you can browse the link and now it is with domainstats=0
Mr. Spadoni
Spadhausen ISP
