Well, SquirrelMAil works great ! the same with HTML_mail plugin except the spell checker option that uses ASpell.
I know that this question should have it place on ASpell forum, but here, people are a lot more reactive...
Anyway. the installation worked well and ASpell detects the spell mistakes well too, but as soon as it had to replace a letter, it uses stuff like é (this is his é).
For example, when I write "ecole" (that means school in French), it should replace it with "école" (that still means school, but this is the correct forme!). But it replaces with école. I tried to change the configuration (ASCII, iso 1, 15...) the same with the encoding of html_mail plugin... but I still can't get éçà...
If somebody has an idea!!!!
Thank's a lot.
SquirrelMail, HTML_mail and ASpell
After hours & hours searching what is the page that decide of the encoding type of ASpell, I found it, and now everything works great.
If you have this problem, this means your dictionary does not include utf-8 encode.
But FCKeditor use it...
So you have to go to :
www\Squirellmail\plugins\html_mail\fckeditor\editor\dialog\fck_spellerpages\spellerpages\server-scripts\ ,
Then you edit the spellchecker.php page :
line 22, replace
with
And now, everything work well!!!!
line 22, replace
$aspell_opts = "-a --lang=$lang --encoding=utf-8 -H";
with
$aspell_opts = "-a --lang=$lang --encoding=iso8859-1 -H";
Well, the way I look for solving my problems is always the same :
1) try to understand the cause
2) go to different forum (here, for example, HM, SM, ASpell forums)
3) try to find by myself
4) post my problem
5) go to bed
6) after one hour, I was not able to sleep because of it
7) search by myself again and again
It is 5 - 6 am, I can see the sun, I go to bed
9) I wake up
10) go to forum to see if I got answers
11) Search
12) Published the solution!!!!!!!!!
13) Feel proud
4) post my problem
5) go to bed
9) I wake up
11) Search
13) Feel proud
Hi there,
I using hMailServer 4.0 B125, apache 2.0.54, PHP 5.0.3, Aspell-0-50-3-3 on Windows 2003 Server.
When I want to perform spell check, it display found the error but with error message:
Line 25
Char 201
Error Unterminated string constant
Code 0
URL http://localhost/plugins/squirrelspell/ ... erface.php
Line 29
Char 31
Error 'misses' is undefined
Code 0
Any ideas?
Thanks.
Line 25
Char 201
Code 0
Line 29
Char 31
Code 0
Any ideas?
Thanks.
Regards,
Chai Kam Weng
Chai Kam Weng
