External email to multiple local email addresses fails
tutone1234
Post by tutone1234 » 2011-01-05 18:51
I have a situation where someone from an externally hosted email address can successfully send to any individual email account on my hmailserver but if they send to multiple accounts on my hmailserver they never get delivered. For example:
If xxxx@yahoo.com sends to yyyy@myserver.com, it goes through. But if xxxx@yahoo.com sends to yyyy@myserver.com, xxxx@myserver.com, and zzzz@myserver.com it never gets delivered.
I can see the smtp connection in the logs from the external email account, but i don't see any other action taking place in the logs to deliver the email beyond that point. It doesn't seem to matter if its 2, 3, 4, 5, etc email addresses on my server either. However, if I send an email to all those same users from another local email address it goes through and I can see the delivery in the logs.
Please help - i'm at a loss and have a couple very disgruntled users.
Thanks in advance.
Tommy
Re: External email to multiple local email addresses fails
Post by ^DooM^ » 2011-01-05 20:34
What version of hmail?
Are you running AV?
Are you running Antispam?
tutone1234
Post by tutone1234 » 2011-01-05 20:44
5.3.3-B1879
No antivirus. Running spam assassin, spf and mx/dns record checks, and the DNSBL (spamhaus and spamcop) and SURBL checks.
tutone1234
Post by tutone1234 » 2011-01-05 20:45
FYI - I did completely disable spam assassin and it made absolutely no difference.
Post by martin » 2011-01-05 20:46
Can you post the log? Do you have debug logging enabled?
tutone1234
Post by tutone1234 » 2011-01-05 21:00
I do have pop3, smtp, application, debug, tcp/ip enabled. This was a test done from gmail and this is the only thing in the log entry:
"TCPIP" 5868 "2010-12-29 15:00:21.675" "TCPConnection - Posting AcceptEx on 0.0.0.0:25"
"TCPIP" 5868 "2010-12-29 15:00:21.893" "DNS lookup: 49.213.85.209.zen.spamhaus.org, 0 addresses found: (none), Match: False"
"TCPIP" 5868 "2010-12-29 15:00:21.972" "DNS lookup: 49.213.85.209.bl.spamcop.net, 0 addresses found: (none), Match: False"
"TCPIP" 5868 "2010-12-29 15:00:22.175" "DNS - MX Lookup: gmail.com"
"TCPIP" 5868 "2010-12-29 15:00:22.597" "DNS - MX Result: 9 IP addresses were found."
"TCPIP" 5868 "2010-12-29 15:00:22.612" "DNS - MX Lookup: gmail.com"
"TCPIP" 5868 "2010-12-29 15:00:22.612" "DNS - MX Result: 9 IP addresses were found."
"TCPIP" 5868 "2010-12-29 15:00:22.643" "DNS - MX Lookup: gmail.com"
"TCPIP" 5868 "2010-12-29 15:00:22.643" "DNS - MX Result: 9 IP addresses were found."
There isn't anything else about mail being delivered from gmail to the intended recipients or anything. All I know is that when mail is sent to multiple users on my server in a single email from an external email that the senders email is never delivered and they typically get a 451 4.4.1 reply (such as the one from aol below) ... but if they send email to just a single user it goes straight through to that user.
*** ATTENTION ***
Your e-mail is being returned to you because there was a problem with its
delivery. The address which was undeliverable is listed in the section
labeled: "----- The following addresses had permanent fatal errors -----".
The reason your mail is being returned to you is listed in the section
labeled: "----- Transcript of Session Follows -----".
The line beginning with "<<<" describes the specific reason your e-mail could
not be delivered. The next line contains a second error message which is a
general translation for other e-mail servers.
Please direct further questions regarding this message to the e-mail
administrator or Postmaster at that destination.
--AOL Postmaster
<todd@aimattachments.com>
(reason: 451 4.4.1 reply: read error from mail.aimattachments.com.)
<liz@aimattachments.com>
<jamie@aimattachments.com>
(reason: )
<j.duda@aimattachments.com>
<chriss@aimattachments.com>
<chris@aimattachments.com>
----- Transcript of session follows -----
<jamie@aimattachments.com>... Deferred: Connection timed out with mail.aimattachments.com.
<liz@aimattachments.com>... Deferred: Connection timed out with mail.aimattachments.com.
<todd@aimattachments.com>... Deferred: Connection timed out with mail.aimattachments.com.
<chris@aimattachments.com>,<chriss@aimattachments.com>,<j.duda@aimattachments.com>... Deferred: Connection timed out with mail.aimattachments.com.
Message could not be delivered for 3 hours
Message will be deleted from queue
Final-Recipient: RFC822; todd@aimattachments.com
Action: failed
Status: 4.4.7
Diagnostic-Code: SMTP; 451 4.4.1 reply: read error from mail.aimattachments.com.
Last-Attempt-Date: Mon, 27 Dec 2010 18:21:51 -0500
Final-Recipient: RFC822; liz@aimattachments.com
Action: failed
Status: 4.4.7
Final-Recipient: RFC822; jamie@aimattachments.com
Action: failed
Status: 4.4.7
Remote-MTA: DNS; mail.aimattachments.com
Final-Recipient: RFC822; j.duda@aimattachments.com
Action: failed
Status: 4.4.7
Final-Recipient: RFC822; chriss@aimattachments.com
Action: failed
Status: 4.4.7
Final-Recipient: RFC822; chris@aimattachments.com
Action: failed
Status: 4.4.7
Return-Path: Received: from imo-ma04.mx.aol.com (imo-ma04.mx.aol.com [64.12.78.139]) by imr-ma01.mx.aol.com (8.14.1/8.14.1) with ESMTP id oBRKDA5Y002862; Mon, 27 Dec 2010 15:13:11 -0500 Received: from MLH43085@aol.com by imo-ma04.mx.aol.com (mail_out_v42.9.) id f.ebe.245cc35 (37046); Mon, 27 Dec 2010 15:13:08 -0500 (EST) Received: from magic-m21.mail.aol.com (magic-m21.mail.aol.com [172.20.22.194]) by cia-db03.mx.aol.com (v129.7) with ESMTP id MAILCIADB034-90b64d18f3541eb; Mon, 27 Dec 2010 15:13:08 -0500 From: MLH43085@aol.com Message-ID: <3c9b9.5c3800d.3a4a4d54@aol.com> Date: Mon, 27 Dec 2010 15:13:08 EST Subject: Tuesday-Thurs Schedule To: jamie@aimattachments.com, chriss@aimattachments.com, todd@aimattachments.com, liz@aimattachments.com, chris@aimattachments.com, j.duda@aimattachments.com MIME-Version: 1.0 Content-Type: multipart/alternative; boundary="part1_3c9b9.5c3800d.3a4a4d54_boundary" X-Mailer: AOL 9.5 sub 5401 X-AOL-IP: 63.131.75.10 X-Spam-Flag:NO X-AOL-SENDER: MLH43085@aol.com
Post by martin » 2011-01-05 21:03
Can you try disabling all the spam tests?
tutone1234
Post by tutone1234 » 2011-01-06 18:14
I disabled all the Spam Tests (SPF, HELO, DNS/MX, DKIM). Tested again and same result. I'm making sure all greylisting is turned off. It was not enabled on the domains, but was enabled as a server setting. It seems that if I include other email addresses from other domain names on the server, those go through - but the multiples to the other domain name fail.
Any more ideas are welcome. Thanks.
Post by martin » 2011-01-06 19:59
Okay, enable full logging and post the snippet from the log here. You write that you have smtp and debug logging enabled, which is weird, because your log does not contain any smtp or debug entries.. Recheck that you actually have that enabled and confirm that when you send a message to yourself, you see SMTP log entries.
tutone1234
Post by tutone1234 » 2011-01-07 15:31
Ok - here's the full log of another test run starting with session 158341. Notice that it never appears to save the message to the aimattachments.com accounts. Just to the ccecorp.com accounts. Those domains are set up identically on the server.
"DEBUG" 5936 "2011-01-06 16:17:09.081" "Creating session 158341"
"SMTPD" 5936 158341 "2011-01-06 16:17:09.081" "209.85.160.177" "SENT: 220 Welcome to mail.ccecorp.com SMTP"
"SMTPD" 5936 158341 "2011-01-06 16:17:09.097" "209.85.160.177" "RECEIVED: EHLO mail-gy0-f177.google.com"
"SMTPD" 5936 158341 "2011-01-06 16:17:09.097" "209.85.160.177" "SENT: 250-mail.ccecorp.com[nl]250-SIZE 20480000[nl]250 AUTH LOGIN"
"SMTPD" 5936 158341 "2011-01-06 16:17:09.112" "209.85.160.177" "RECEIVED: MAIL FROM:<shibdon@gmail.com>"
"TCPIP" 5936 "2011-01-06 16:17:09.440" "DNS lookup: 177.160.85.209.zen.spamhaus.org, 0 addresses found: (none), Match: False"
"TCPIP" 5936 "2011-01-06 16:17:09.487" "DNS lookup: 177.160.85.209.bl.spamcop.net, 0 addresses found: (none), Match: False"
"DEBUG" 5936 "2011-01-06 16:17:09.487" "Spam test: SpamTestDNSBlackLists, Score: 0"
"DEBUG" 5936 "2011-01-06 16:17:09.487" "Spam test: SpamTestHeloHost, Score: 0"
"DEBUG" 5936 "2011-01-06 16:17:09.565" "Spam test: SpamTestMXRecords, Score: 0"
"DEBUG" 5936 "2011-01-06 16:17:09.565" "Total spam score: 0"
"SMTPD" 5936 158341 "2011-01-06 16:17:09.581" "209.85.160.177" "SENT: 250 OK"
"SMTPD" 5936 158341 "2011-01-06 16:17:09.597" "209.85.160.177" "RECEIVED: RCPT TO:<chriss@aimattachments.com>"
"SMTPD" 5936 158341 "2011-01-06 16:17:09.597" "209.85.160.177" "SENT: 250 OK"
"SMTPD" 5936 158341 "2011-01-06 16:17:09.612" "209.85.160.177" "RECEIVED: RCPT TO:<leona@aimattachments.com>"
"SMTPD" 5936 158341 "2011-01-06 16:17:09.612" "209.85.160.177" "SENT: 250 OK"
"SMTPD" 5936 158341 "2011-01-06 16:17:09.628" "209.85.160.177" "RECEIVED: RCPT TO:<melissa@aimattachments.com>"
"SMTPD" 5936 158341 "2011-01-06 16:17:09.628" "209.85.160.177" "SENT: 250 OK"
"SMTPD" 5936 158341 "2011-01-06 16:17:09.643" "209.85.160.177" "RECEIVED: RCPT TO:<j.duda@aimattachments.com>"
"SMTPD" 5936 158341 "2011-01-06 16:17:09.643" "209.85.160.177" "SENT: 250 OK"
"SMTPD" 5936 158341 "2011-01-06 16:17:09.659" "209.85.160.177" "RECEIVED: RCPT TO:<jamie@aimattachments.com>"
"SMTPD" 5936 158341 "2011-01-06 16:17:09.659" "209.85.160.177" "SENT: 250 OK"
"SMTPD" 5936 158341 "2011-01-06 16:17:09.675" "209.85.160.177" "RECEIVED: RCPT TO:<liz@aimattachments.com>"
"SMTPD" 5936 158341 "2011-01-06 16:17:09.675" "209.85.160.177" "SENT: 250 OK"
"SMTPD" 5936 158341 "2011-01-06 16:17:09.690" "209.85.160.177" "RECEIVED: RCPT TO:<davet@aimattachments.com>"
"TCPIP" 5868 "2011-01-06 16:17:09.831" "TCPConnection - Posting AcceptEx on 0.0.0.0:25"
"DEBUG" 5868 "2011-01-06 16:17:09.831" "Creating session 158342"
"SMTPD" 5868 158342 "2011-01-06 16:17:09.831" "209.85.213.53" "SENT: 220 Welcome to mail.ccecorp.com SMTP"
"SMTPD" 5868 158342 "2011-01-06 16:17:09.847" "209.85.213.53" "RECEIVED: EHLO mail-yw0-f53.google.com"
"SMTPD" 5868 158342 "2011-01-06 16:17:09.862" "209.85.213.53" "SENT: 250-mail.ccecorp.com[nl]250-SIZE 20480000[nl]250 AUTH LOGIN"
"SMTPD" 5868 158342 "2011-01-06 16:17:09.878" "209.85.213.53" "RECEIVED: MAIL FROM:<shibdon@gmail.com>"
"TCPIP" 5868 "2011-01-06 16:17:10.175" "DNS lookup: 53.213.85.209.zen.spamhaus.org, 0 addresses found: (none), Match: False"
"TCPIP" 5868 "2011-01-06 16:17:10.253" "DNS lookup: 53.213.85.209.bl.spamcop.net, 0 addresses found: (none), Match: False"
"DEBUG" 5868 "2011-01-06 16:17:10.253" "Spam test: SpamTestDNSBlackLists, Score: 0"
"DEBUG" 5868 "2011-01-06 16:17:10.362" "Spam test: SpamTestHeloHost, Score: 0"
"DEBUG" 5868 "2011-01-06 16:17:10.362" "Spam test: SpamTestMXRecords, Score: 0"
"DEBUG" 5868 "2011-01-06 16:17:10.362" "Total spam score: 0"
"SMTPD" 5868 158342 "2011-01-06 16:17:10.378" "209.85.213.53" "SENT: 250 OK"
"SMTPD" 5868 158342 "2011-01-06 16:17:10.393" "209.85.213.53" "RECEIVED: RCPT TO:<noahc@ccecorp.com>"
"SMTPD" 5868 158342 "2011-01-06 16:17:10.393" "209.85.213.53" "SENT: 250 OK"
"SMTPD" 5868 158342 "2011-01-06 16:17:10.409" "209.85.213.53" "RECEIVED: RCPT TO:<support@ccecorp.com>"
"SMTPD" 5868 158342 "2011-01-06 16:17:10.409" "209.85.213.53" "SENT: 250 OK"
"SMTPD" 5868 158342 "2011-01-06 16:17:10.425" "209.85.213.53" "RECEIVED: DATA"
"SMTPD" 5868 158342 "2011-01-06 16:17:10.425" "209.85.213.53" "SENT: 354 OK, send."
"DEBUG" 1396 "2011-01-06 16:17:10.440" "SURBL::Run"
"DEBUG" 1396 "2011-01-06 16:17:10.706" "SURBL::~Run"
"DEBUG" 1396 "2011-01-06 16:17:10.706" "Spam test: SpamTestSURBL, Score: 0"
"DEBUG" 1396 "2011-01-06 16:17:10.706" "Total spam score: 0"
"DEBUG" 1396 "2011-01-06 16:17:10.706" "Saving message: E:\hMailServer\Data\{2E7B1084-D667-4DC6-BE64-F23AC4B3357A}.eml"
"DEBUG" 1396 "2011-01-06 16:17:10.706" "Requesting SMTPDeliveryManager to start message delivery"
"SMTPD" 1396 158342 "2011-01-06 16:17:10.706" "209.85.213.53" "SENT: 250 Queued (0.281 seconds)"
"DEBUG" 392 "2011-01-06 16:17:10.722" "Delivering message..."
"APPLICATION" 392 "2011-01-06 16:17:10.722" "SMTPDeliverer - Message 73094: Delivering message from shibdon@gmail.com to noahc@ccecorp.com, support@ccecorp.com. File: E:\hMailServer\Data\{2E7B1084-D667-4DC6-BE64-F23AC4B3357A}.eml"
"DEBUG" 392 "2011-01-06 16:17:10.722" "Applying rules"
"DEBUG" 392 "2011-01-06 16:17:10.722" "Performing local delivery"
"DEBUG" 392 "2011-01-06 16:17:10.722" "Copying mail contents"
"DEBUG" 392 "2011-01-06 16:17:10.722" "Saving message: E:\hMailServer\Data\ccecorp.com\noahc\8E\{8E39E324-409B-4B97-86AC-BC43120F7762}.eml"
"DEBUG" 392 "2011-01-06 16:17:10.831" "Applying rules"
"DEBUG" 392 "2011-01-06 16:17:10.831" "Saving message: E:\hMailServer\Data\ccecorp.com\support\2E\{2E7B1084-D667-4DC6-BE64-F23AC4B3357A}.eml"
"DEBUG" 392 "2011-01-06 16:17:10.847" "Local delivery completed"
"APPLICATION" 392 "2011-01-06 16:17:10.847" "SMTPDeliverer - Message 73094: Message delivery thread completed."
"TCPIP" 5428 "2011-01-06 16:17:13.018" "TCPConnection - Posting AcceptEx on 0.0.0.0:110"
"DEBUG" 5428 "2011-01-06 16:17:13.018" "Creating session 158343"
"POP3D" 5428 158343 "2011-01-06 16:17:13.018" "68.153.49.146" "SENT: +OK Welcome to mail.ccecorp.com POP3"
"POP3D" 5428 158343 "2011-01-06 16:17:13.081" "68.153.49.146" "RECEIVED: USER rmtest@cmsaevents.com"
"POP3D" 5428 158343 "2011-01-06 16:17:13.081" "68.153.49.146" "SENT: +OK Send your password"
"POP3D" 5428 158343 "2011-01-06 16:17:13.128" "68.153.49.146" "RECEIVED: PASS ***"
"POP3D" 5428 158343 "2011-01-06 16:17:13.143" "68.153.49.146" "SENT: +OK Mailbox locked and ready"
"POP3D" 5428 158343 "2011-01-06 16:17:13.206" "68.153.49.146" "RECEIVED: STAT"
"POP3D" 5428 158343 "2011-01-06 16:17:13.206" "68.153.49.146" "SENT: +OK 0 0"
"POP3D" 5428 158343 "2011-01-06 16:17:13.268" "68.153.49.146" "RECEIVED: QUIT"
"POP3D" 5428 158343 "2011-01-06 16:17:13.268" "68.153.49.146" "SENT: +OK POP3 server saying goodbye..."
"DEBUG" 2824 "2011-01-06 16:17:13.268" "Closing TCP/IP socket"
"DEBUG" 2824 "2011-01-06 16:17:13.268" "Ending session 158343"
"TCPIP" 5428 "2011-01-06 16:17:13.378" "TCPConnection - Posting AcceptEx on 0.0.0.0:110"
"DEBUG" 5428 "2011-01-06 16:17:13.378" "Creating session 158344"
"POP3D" 5428 158344 "2011-01-06 16:17:13.378" "68.153.49.146" "SENT: +OK Welcome to mail.ccecorp.com POP3"
"POP3D" 5428 158344 "2011-01-06 16:17:13.440" "68.153.49.146" "RECEIVED: USER results@cmsaevents.com"
"POP3D" 5428 158344 "2011-01-06 16:17:13.440" "68.153.49.146" "SENT: +OK Send your password"
"POP3D" 5428 158344 "2011-01-06 16:17:13.487" "68.153.49.146" "RECEIVED: PASS ***"
"POP3D" 5428 158344 "2011-01-06 16:17:13.503" "68.153.49.146" "SENT: +OK Mailbox locked and ready"
"POP3D" 5428 158344 "2011-01-06 16:17:13.550" "68.153.49.146" "RECEIVED: STAT"
"POP3D" 5428 158344 "2011-01-06 16:17:13.550" "68.153.49.146" "SENT: +OK 0 0"
"POP3D" 5428 158344 "2011-01-06 16:17:13.612" "68.153.49.146" "RECEIVED: QUIT"
"POP3D" 5428 158344 "2011-01-06 16:17:13.612" "68.153.49.146" "SENT: +OK POP3 server saying goodbye..."
"DEBUG" 4828 "2011-01-06 16:17:13.612" "Closing TCP/IP socket"
"DEBUG" 4828 "2011-01-06 16:17:13.612" "Ending session 158344"
"TCPIP" 5428 "2011-01-06 16:17:13.722" "TCPConnection - Posting AcceptEx on 0.0.0.0:110"
"DEBUG" 5428 "2011-01-06 16:17:13.722" "Creating session 158345"
"POP3D" 5428 158345 "2011-01-06 16:17:13.722" "68.153.49.146" "SENT: +OK Welcome to mail.ccecorp.com POP3"
"POP3D" 5428 158345 "2011-01-06 16:17:13.768" "68.153.49.146" "RECEIVED: USER gregf@lumbermenonline.com"
"POP3D" 5428 158345 "2011-01-06 16:17:13.768" "68.153.49.146" "SENT: +OK Send your password"
"POP3D" 5428 158345 "2011-01-06 16:17:13.831" "68.153.49.146" "RECEIVED: PASS ***"
"POP3D" 5428 158345 "2011-01-06 16:17:13.831" "68.153.49.146" "SENT: +OK Mailbox locked and ready"
"POP3D" 5428 158345 "2011-01-06 16:17:13.893" "68.153.49.146" "RECEIVED: STAT"
"POP3D" 5428 158345 "2011-01-06 16:17:13.893" "68.153.49.146" "SENT: +OK 0 0"
"POP3D" 5428 158345 "2011-01-06 16:17:13.940" "68.153.49.146" "RECEIVED: QUIT"
"POP3D" 5428 158345 "2011-01-06 16:17:13.940" "68.153.49.146" "SENT: +OK POP3 server saying goodbye..."
"DEBUG" 656 "2011-01-06 16:17:13.940" "Closing TCP/IP socket"
"DEBUG" 656 "2011-01-06 16:17:13.940" "Ending session 158345"
"TCPIP" 5428 "2011-01-06 16:17:18.128" "TCPConnection - Posting AcceptEx on 0.0.0.0:110"
"DEBUG" 5428 "2011-01-06 16:17:18.128" "Creating session 158346"
"POP3D" 5428 158346 "2011-01-06 16:17:18.128" "68.153.49.146" "SENT: +OK Welcome to mail.ccecorp.com POP3"
"POP3D" 5428 158346 "2011-01-06 16:17:18.190" "68.153.49.146" "RECEIVED: USER office@cmsaevents.com"
"POP3D" 5428 158346 "2011-01-06 16:17:18.190" "68.153.49.146" "SENT: +OK Send your password"
"POP3D" 5428 158346 "2011-01-06 16:17:18.237" "68.153.49.146" "RECEIVED: PASS ***"
"POP3D" 5428 158346 "2011-01-06 16:17:18.253" "68.153.49.146" "SENT: +OK Mailbox locked and ready"
"POP3D" 5428 158346 "2011-01-06 16:17:18.300" "68.153.49.146" "RECEIVED: STAT"
"POP3D" 5428 158346 "2011-01-06 16:17:18.300" "68.153.49.146" "SENT: +OK 0 0"
"POP3D" 5428 158346 "2011-01-06 16:17:18.362" "68.153.49.146" "RECEIVED: QUIT"
"POP3D" 5428 158346 "2011-01-06 16:17:18.362" "68.153.49.146" "SENT: +OK POP3 server saying goodbye..."
"DEBUG" 2192 "2011-01-06 16:17:18.362" "Closing TCP/IP socket"
"DEBUG" 2192 "2011-01-06 16:17:18.362" "Ending session 158346"
"TCPIP" 5428 "2011-01-06 16:17:28.456" "TCPConnection - Posting AcceptEx on 0.0.0.0:110"
"DEBUG" 5428 "2011-01-06 16:17:28.456" "Creating session 158347"
"POP3D" 5428 158347 "2011-01-06 16:17:28.456" "74.115.244.218" "SENT: +OK Welcome to mail.ccecorp.com POP3"
"POP3D" 5428 158347 "2011-01-06 16:17:28.487" "74.115.244.218" "RECEIVED: USER shanah@ccecorp.com"
"POP3D" 5428 158347 "2011-01-06 16:17:28.503" "74.115.244.218" "SENT: +OK Send your password"
"POP3D" 5428 158347 "2011-01-06 16:17:28.534" "74.115.244.218" "RECEIVED: PASS ***"
"POP3D" 5428 158347 "2011-01-06 16:17:28.565" "74.115.244.218" "SENT: +OK Mailbox locked and ready"
"POP3D" 5428 158347 "2011-01-06 16:17:28.597" "74.115.244.218" "RECEIVED: STAT"
"POP3D" 5428 158347 "2011-01-06 16:17:28.597" "74.115.244.218" "SENT: +OK 0 0"
"POP3D" 5428 158347 "2011-01-06 16:17:28.628" "74.115.244.218" "RECEIVED: QUIT"
"POP3D" 5428 158347 "2011-01-06 16:17:28.628" "74.115.244.218" "SENT: +OK POP3 server saying goodbye..."
"DEBUG" 5392 "2011-01-06 16:17:28.628" "Closing TCP/IP socket"
"DEBUG" 5392 "2011-01-06 16:17:28.628" "Ending session 158347"
"TCPIP" 5428 "2011-01-06 16:17:28.706" "TCPConnection - Posting AcceptEx on 0.0.0.0:110"
"DEBUG" 5428 "2011-01-06 16:17:28.706" "Creating session 158348"
"POP3D" 5428 158348 "2011-01-06 16:17:28.706" "74.115.244.218" "SENT: +OK Welcome to mail.ccecorp.com POP3"
"POP3D" 5428 158348 "2011-01-06 16:17:28.753" "74.115.244.218" "RECEIVED: USER support@ccecorp.com"
"POP3D" 5428 158348 "2011-01-06 16:17:28.753" "74.115.244.218" "SENT: +OK Send your password"
"POP3D" 5428 158348 "2011-01-06 16:17:28.784" "74.115.244.218" "RECEIVED: PASS ***"
"DEBUG" 5428 "2011-01-06 16:17:28.784" "Reading message from database"
"POP3D" 5428 158348 "2011-01-06 16:17:28.784" "74.115.244.218" "SENT: +OK Mailbox locked and ready"
"POP3D" 5428 158348 "2011-01-06 16:17:28.815" "74.115.244.218" "RECEIVED: STAT"
"POP3D" 5428 158348 "2011-01-06 16:17:28.815" "74.115.244.218" "SENT: +OK 1 5183"
"POP3D" 5428 158348 "2011-01-06 16:17:28.862" "74.115.244.218" "RECEIVED: LIST"
"POP3D" 5428 158348 "2011-01-06 16:17:28.862" "74.115.244.218" "SENT: +OK 1 messages (5183 octets)"
"POP3D" 5428 158348 "2011-01-06 16:17:28.862" "74.115.244.218" "SENT: 1 5183[nl]."
"POP3D" 5428 158348 "2011-01-06 16:17:29.081" "74.115.244.218" "RECEIVED: RETR 1"
"POP3D" 5428 158348 "2011-01-06 16:17:29.081" "74.115.244.218" "SENT: ."
"POP3D" 5428 158348 "2011-01-06 16:17:29.206" "74.115.244.218" "RECEIVED: DELE 1"
"POP3D" 5428 158348 "2011-01-06 16:17:29.206" "74.115.244.218" "SENT: +OK msg deleted"
"POP3D" 5428 158348 "2011-01-06 16:17:29.253" "74.115.244.218" "RECEIVED: QUIT"
"DEBUG" 5428 "2011-01-06 16:17:29.253" "Deleting message"
"DEBUG" 5428 "2011-01-06 16:17:29.268" "Deleting message file"
"POP3D" 5428 158348 "2011-01-06 16:17:29.284" "74.115.244.218" "SENT: +OK POP3 server saying goodbye..."
"DEBUG" 3244 "2011-01-06 16:17:29.284" "Closing TCP/IP socket"
"DEBUG" 3244 "2011-01-06 16:17:29.284" "Ending session 158348"
"TCPIP" 5428 "2011-01-06 16:17:29.362" "TCPConnection - Posting AcceptEx on 0.0.0.0:110"
"DEBUG" 5428 "2011-01-06 16:17:29.362" "Creating session 158349"
"POP3D" 5428 158349 "2011-01-06 16:17:29.362" "74.115.244.218" "SENT: +OK Welcome to mail.ccecorp.com POP3"
"POP3D" 5428 158349 "2011-01-06 16:17:29.393" "74.115.244.218" "RECEIVED: USER webmaster@cmsaevents.com"
"POP3D" 5428 158349 "2011-01-06 16:17:29.393" "74.115.244.218" "SENT: +OK Send your password"
"POP3D" 5428 158349 "2011-01-06 16:17:29.425" "74.115.244.218" "RECEIVED: PASS ***"
"POP3D" 5428 158349 "2011-01-06 16:17:29.472" "74.115.244.218" "SENT: +OK Mailbox locked and ready"
"POP3D" 5428 158349 "2011-01-06 16:17:29.518" "74.115.244.218" "RECEIVED: STAT"
"POP3D" 5428 158349 "2011-01-06 16:17:29.518" "74.115.244.218" "SENT: +OK 0 0"
"POP3D" 5428 158349 "2011-01-06 16:17:29.550" "74.115.244.218" "RECEIVED: QUIT"
"POP3D" 5428 158349 "2011-01-06 16:17:29.550" "74.115.244.218" "SENT: +OK POP3 server saying goodbye..."
"DEBUG" 4300 "2011-01-06 16:17:29.550" "Closing TCP/IP socket"
"DEBUG" 4300 "2011-01-06 16:17:29.550" "Ending session 158349"
"TCPIP" 5428 "2011-01-06 16:17:29.628" "TCPConnection - Posting AcceptEx on 0.0.0.0:110"
"DEBUG" 5428 "2011-01-06 16:17:29.628" "Creating session 158350"
"POP3D" 5428 158350 "2011-01-06 16:17:29.628" "74.115.244.218" "SENT: +OK Welcome to mail.ccecorp.com POP3"
"POP3D" 5428 158350 "2011-01-06 16:17:29.659" "74.115.244.218" "RECEIVED: USER shanah@lumbermenonline.com"
"POP3D" 5428 158350 "2011-01-06 16:17:29.659" "74.115.244.218" "SENT: +OK Send your password"
"POP3D" 5428 158350 "2011-01-06 16:17:29.690" "74.115.244.218" "RECEIVED: PASS ***"
"POP3D" 5428 158350 "2011-01-06 16:17:29.706" "74.115.244.218" "SENT: +OK Mailbox locked and ready"
"POP3D" 5428 158350 "2011-01-06 16:17:29.737" "74.115.244.218" "RECEIVED: STAT"
"POP3D" 5428 158350 "2011-01-06 16:17:29.737" "74.115.244.218" "SENT: +OK 0 0"
"POP3D" 5428 158350 "2011-01-06 16:17:29.768" "74.115.244.218" "RECEIVED: QUIT"
"POP3D" 5428 158350 "2011-01-06 16:17:29.768" "74.115.244.218" "SENT: +OK POP3 server saying goodbye..."
"DEBUG" 656 "2011-01-06 16:17:29.768" "Closing TCP/IP socket"
"DEBUG" 656 "2011-01-06 16:17:29.768" "Ending session 158350"
"TCPIP" 5868 "2011-01-06 16:17:31.440" "TCPConnection - Posting AcceptEx on 0.0.0.0:25"
"DEBUG" 5868 "2011-01-06 16:17:31.456" "Creating session 158351"
"SMTPD" 5868 158351 "2011-01-06 16:17:31.456" "190.178.241.119" "SENT: 220 Welcome to mail.ccecorp.com SMTP"
"SMTPD" 5868 158351 "2011-01-06 16:17:31.893" "190.178.241.119" "RECEIVED: HELO vx8vi63"
"SMTPD" 5868 158351 "2011-01-06 16:17:31.893" "190.178.241.119" "SENT: 250 Hello."
"SMTPD" 5868 158351 "2011-01-06 16:17:32.300" "190.178.241.119" "RECEIVED: MAIL FROM: <dwayne.barton_gt@jbiab.se>"
"TCPIP" 5868 "2011-01-06 16:17:32.472" "DNS lookup: 119.241.178.190.zen.spamhaus.org, 0 addresses found: (none), Match: False"
"TCPIP" 5868 "2011-01-06 16:17:32.706" "DNS lookup: 119.241.178.190.bl.spamcop.net, 0 addresses found: (none), Match: False"
"DEBUG" 5868 "2011-01-06 16:17:32.706" "Spam test: SpamTestDNSBlackLists, Score: 0"
"DEBUG" 5868 "2011-01-06 16:17:34.956" "Spam test: SpamTestHeloHost, Score: 2"
"DEBUG" 5868 "2011-01-06 16:17:36.315" "Spam test: SpamTestMXRecords, Score: 0"
"DEBUG" 5868 "2011-01-06 16:17:36.315" "Total spam score: 2"
"SMTPD" 5868 158351 "2011-01-06 16:17:36.331" "190.178.241.119" "SENT: 250 OK"
"SMTPD" 5868 158351 "2011-01-06 16:17:36.940" "190.178.241.119" "RECEIVED: RCPT TO: <jamie@aimattachments.com>"
"SMTPD" 5868 158351 "2011-01-06 16:17:36.940" "190.178.241.119" "SENT: 250 OK"
"SMTPD" 5868 158351 "2011-01-06 16:17:37.378" "190.178.241.119" "RECEIVED: DATA"
"SMTPD" 5868 158351 "2011-01-06 16:17:37.378" "190.178.241.119" "SENT: 354 OK, send."
"DEBUG" 1396 "2011-01-06 16:17:37.878" "SURBL::Run"
"DEBUG" 1396 "2011-01-06 16:17:38.018" "SURBL::~Run"
"DEBUG" 1396 "2011-01-06 16:17:38.018" "Spam test: SpamTestSURBL, Score: 5"
"DEBUG" 1396 "2011-01-06 16:17:38.018" "Total spam score: 5"
"DEBUG" 1396 "2011-01-06 16:17:38.018" "Saving message: E:\hMailServer\Data\{F4BE8B9E-9782-4A7A-AEA1-4B62867C343A}.eml"
"DEBUG" 1396 "2011-01-06 16:17:38.018" "Requesting SMTPDeliveryManager to start message delivery"
"SMTPD" 1396 158351 "2011-01-06 16:17:38.018" "190.178.241.119" "SENT: 250 Queued (0.641 seconds)"
"DEBUG" 392 "2011-01-06 16:17:38.034" "Delivering message..."
"APPLICATION" 392 "2011-01-06 16:17:38.034" "SMTPDeliverer - Message 73096: Delivering message from dwayne.barton_gt@jbiab.se to jamie@aimattachments.com. File: E:\hMailServer\Data\{F4BE8B9E-9782-4A7A-AEA1-4B62867C343A}.eml"
"DEBUG" 392 "2011-01-06 16:17:38.034" "Applying rules"
"DEBUG" 392 "2011-01-06 16:17:38.034" "Performing local delivery"
"DEBUG" 392 "2011-01-06 16:17:38.034" "Saving message: E:\hMailServer\Data\aimattachments.com\jamie\F4\{F4BE8B9E-9782-4A7A-AEA1-4B62867C343A}.eml"
"DEBUG" 392 "2011-01-06 16:17:38.034" "Local delivery completed"
"APPLICATION" 392 "2011-01-06 16:17:38.034" "SMTPDeliverer - Message 73096: Message delivery thread completed."
"SMTPD" 5428 158351 "2011-01-06 16:17:38.425" "190.178.241.119" "RECEIVED: QUIT"
"SMTPD" 5428 158351 "2011-01-06 16:17:38.425" "190.178.241.119" "SENT: 221 goodbye"
"DEBUG" 5044 "2011-01-06 16:17:38.425" "Closing TCP/IP socket"
"DEBUG" 5044 "2011-01-06 16:17:38.425" "Ending session 158351"
"SMTPD" 3852 158342 "2011-01-06 16:17:40.722" "209.85.213.53" "RECEIVED: QUIT"
"SMTPD" 3852 158342 "2011-01-06 16:17:40.722" "209.85.213.53" "SENT: 221 goodbye"
"DEBUG" 2824 "2011-01-06 16:17:40.737" "Closing TCP/IP socket"
"DEBUG" 2824 "2011-01-06 16:17:40.737" "Ending session 158342"
THEN MUCH LATER SESSION 158341 FINALLY WRAPS UP
"SMTPD" 5936 158341 "2011-01-06 17:57:09.690" "209.85.160.177" "SENT: 250 OK"
"SMTPD" 4916 158341 "2011-01-06 17:57:09.690" "209.85.160.177" "RECEIVED: QUIT"
"DEBUG" 4916 "2011-01-06 17:57:09.690" "Deleting message file"
"SMTPD" 4916 158341 "2011-01-06 17:57:09.690" "209.85.160.177" "SENT: 221 goodbye"
Post by ^DooM^ » 2011-01-07 17:10
What's even more weird, look at the timestamps on the accept
100 Minutes exactly between the two.
tutone1234
Post by tutone1234 » 2011-01-07 19:13
I believe I may have found the issue, which would explain the 100 minute delay ... but not sure why the message still isn't being delivered. Tarpitting was set to a limit of 3 for a 6000 second delay. My previous experiences with tarpitting always involved sending to invalid users - not valid ones. The hmailserver documentation doesn't specify if it tarpitting is just controlling bulk email sent to existing or non-existing users. Other mail servers i have experience with used tarpitting to identify and control spam to non-existing users.
Post by ^DooM^ » 2011-01-07 19:21
I believe trapitting is applied to all non authed inbound connections. tarpitting applied to non existent addresses only would make more sense.
Disable it and see if it helps any.
tutone1234
Post by tutone1234 » 2011-01-07 19:22
I'm not clear on how i'd disable it other than making the limit really high. The help documentation isn't that helpful unfortunately.
Post by ^DooM^ » 2011-01-07 23:19
To disable set Count and Delay both to 0
tutone1234
Post by tutone1234 » 2011-01-07 23:48
Good to know - thanks. So should I post in another forum to suggest that tarpitting work by identifying spammers based upon the volume of invalid email accounts they are trying to send to rather than just sending to a bunch of valid addresses on the server?
Post by ^DooM^ » 2011-01-07 23:56
Yes please post a feature request in the so named feature request section :)
