Client won't update to reflect message deletion on server
duhpuck
Post by duhpuck » 2010-11-03 04:53
I run a script which calls message.Copy and messages.DeleteByDBID(message.ID) to move messages on the server from one IMAP folder to another, and it works fine.
However, I cannot figure out how to get the Outlook Client (OL 2007) to refresh to reflect the update. The copied messages show up correctly in the destination folder in Outlook, but the original messages, which have been deleted on the server, are still sitting in the Inbox on the client.
Of course I tried both "Send/Receive" and "Purge Marked Items", but neither removes the messages from the client's Inbox. Closing and restarting Outlook does the trick, but that's not a viable option. I really need to have the effect of the server-side script visible on the client so the user knows the script is doing its job.
Any suggestions?
Re: Client won't update to reflect message deletion on serve
Post by mattg » 2010-11-03 07:04
Outlook + IMAP isn't very good unfortunately...
Which versions of hMailserver and Outlook do you use?
duhpuck
Post by duhpuck » 2010-11-03 07:17
The latest version of hMailServer (5.3.3, build 1879), and Outlook 2007.
Post by mattg » 2010-11-03 07:28
What happens in thunderbird or any other mail client?
duhpuck
Post by duhpuck » 2010-11-04 23:31
I downloaded Thunderbird but was unable to quickly figure out how to connect to my local test hMailServer install. I would have spent more time on it but opted instead to try a completely different approach which doesn't involve using IMAP folders. Sorry that leaves the question unanswered. If I get a chance to try later I'll post the result.
Thanks for the assistance.
RubenT
Post by RubenT » 2010-12-03 09:40
I have an account rule to run function that delete the email, the delete method don´t work (or I don´t know how to do it)
Sub DeleteMessage(oMessage)
     oMessage.delete
     oMessage.save
end Sub
with this function can´t delete too
     address=oMessage.Recipients(0).Address
     vaddress=Split(address,"@")
     domainaddress=vaddress(1)
     Dim obApp
     Call obApp.Authenticate("Administrator", "xxxxx")
     Set obCuenta = obApp.Domains.ItemByName(domainaddress).Accounts.ItemByAddress(address)
     obCuenta.Messages.itembydbid(oMessage.ID).DeleteByDBID(oMessage.ID)
     Set obCuenta=Nothing
     Set obApp = Nothing
end Sub
what is the problem?
In an account rule, can I delete the message with scriptting? the email don´t delete from db, if I set oMessage.ID manually in script, I can delete a old message, but don´t work with the real time email.
