Need help in scripting
Murashid.Rhaman
Post by Murashid.Rhaman » 2009-09-29 09:40
can some one help me in righting a script or a way to find out
the number of users in a domain and the amount of storage thay have used for reporting purposes please.
iam not very good in scripting
Re: Need help in scripting
Post by mattg » 2009-09-29 16:18
This will report total number of users for a domain, and the total amount of disk space used by the e-mails of that domain, in bytes
Copy this to notepad, and then save as with a .vbs extension. Double click on the saved fiile to run.
Option Explicit
Dim fso, f, DomName
DomName = "yourdomain.com"   ' CHANGE ME
set f = fso.getfolder("C:\Program Files\hMailServer\Data\" & DomName & "\")
wscript.Echo "Number of users is " & cstr(f.subfolders.count)
wscript.Echo "Amount of disk space used is " & cstr(f.size)
Is that what you need?
elizb
Post by elizb » 2011-06-27 23:36
How it can be possible to do with script, we cannot track others information by the above script, it will be treated as hcak...
Stacey
www.KiwiServices.com
