SMTP Authentication Problem in Netscape 7.1
Several new users are complaining that they can't send mail using Netscape 7.1 (Mail & News.) I've walked through the SMTP server settings to make sure they are correct (they are!)
Here's what shows up in the HMS log:
"SMTPD" 896 "2005-04-04 13:11:21.109" "66.93.113.102" "RECEIVED: AUTH PLAIN AGppbUB0aW1lc2hhcmV0cmF2ZWwuY29tAGJlYWNo"
"SMTPD" 896 "2005-04-04 13:11:21.109" "66.93.113.102" "SENT: 504 Authentication mechanism not supported."
"SMTPD" 896 "2005-04-04 13:11:21.218" "66.93.113.102" "RECEIVED: AUTH LOGIN amltQHRpbWVzaGFyZXRyYXZlbC5jb20="
"SMTPD" 896 "2005-04-04 13:11:21.218" "66.93.113.102" "SENT: 504 Authentication mechanism not supported."
"SMTPD" 896 "2005-04-04 13:11:21.343" "66.93.113.102" "RECEIVED: AUTH PLAIN AGppbUB0aW1lc2hhcmV0cmF2ZWwuY29tAGJlYWNo"
All the settings in Netscape are fine. How do I fix this problem?
Martin:
I tried disabling that option and had the same problem.
You should also know the I can't send mail using Mozilla Thunderbird (version 1.0.2.) It doesn't seem like Thunderbird gets as far as Netscape did during the connection and authentication phase. Here's the log file output for that:
"SMTPD" 768 "2005-04-04 15:37:50.671" "192.168.0.5" "SENT: 220 You'd better be legit!"
"SMTPD" 768 "2005-04-04 15:37:50.718" "192.168.0.5" "RECEIVED: EHLO [192.168.0.5]"
"SMTPD" 768 "2005-04-04 15:37:50.718" "192.168.0.5" "SENT: 250-hmailserver[nl]250 AUTH LOGIN PLAIN"
You'll notice the Thunderbird client doesn't get past the SENT: 250...
Can you download the new build and confirm that it solves the netscape problem for you?
http://dev.hmailserver.com/hMailServer- ... ild-84.exe
