Add Date Header if None Exists
Do you need this feature?
Yes
4
100%
No
0
No votes
Total votes: 4
PeterK2003
Post by PeterK2003 » 2009-07-24 14:44
I get a decent amount of mail(mostly SPAM but some legit stuff) that has no date header. This causes me grief when sorting by date in both Thunderbird and Roundcube. Could a feature be implemented that if a message lacks the date field the server adds one with the date and time that the message was received by the server? Or is there a better way to handle this?
Thanks,
~Peter
Re: Add Date Header if None Exists
Post by mattg » 2009-07-24 16:26
Pretty easily done with a script.
see this for an example - http://www.hmailserver.com/forum/viewto ... te+#p48185
PeterK2003
Post by PeterK2003 » 2009-07-24 16:48
if that works that would satisfy my needs but it would sorta be nice if it was just a check box in admin console.
Thanks!
Keba
Post by Keba » 2009-07-25 10:32
PeterK2003 wrote:I get a decent amount of mail(mostly SPAM but some legit stuff) that has no date header. This causes me grief when sorting by date in both Thunderbird and Roundcube. Could a feature be implemented that if a message lacks the date field the server adds one with the date and time that the message was received by the server? Or is there a better way to handle this?
Thanks,
~Peter
Greylisting is your friend.
Any moronic spammer script that forgets to put in a date header will also fail greylisting.
I've yet to see any spam through without a date header. My average statistics over the last few months are:
3% legit email
96% rejected spam
1% spam that gets through the various checks
0% legit email rejected
greylisting enabled
catchall enabled
several domains targeted for random address spam
Keba
PeterK2003
Post by PeterK2003 » 2009-07-25 13:40
nearly 100% of my spam is caught but I do have some legit messages that don't have date header.
The script trick posted above seems to work so i am satisfied with that.
