Change Password Script
aehimself
Post by aehimself » 2008-11-11 17:37
I was a little bit disappointed to see that there are no stand-alone change password scripts available for hMail Server, so I decided to write one by myself.
The working scheme is easy to understand: it works in and updates directly the SQL table.
The script was written in Perl and needs the Digest::MD5 and DBI packages to run. Easy to modify to generate the page what you need :)
change_password.zip
(1.2 KiB) Downloaded 851 times
(O.o)
(} {)o
This is Bunny. Copy Bunny into your signature to help him on his way to world domination.
gaganuiit
Re: Change Password Script
Post by gaganuiit » 2009-07-01 10:30
How to use this script.
I mean where to put it and let hMailServer and Horde both know where it is so that all of em communicate.
And any additional configurations that may be required.
I am using XAMPP 1.7.0, hMailServer 4.4.2 B275, Horde Webmail 1.2.3 and Windows 2003 Server.
Post by ^DooM^ » 2009-07-01 11:32
This is a standalone script meaning it does not communicate with horde or any other software, all it does is update the password in the database, nothing more.
