Accessing API from another machine.
robcha
Post by robcha » 2008-06-03 18:20
I want to access the COM API from a different machine than where hmailserver is installed. By looking at the way the hMailserver Administrator connects to hMailServers, it leads me to believe that this is possible.
My instincts tell me that you would specify the hostname on the application.authenticate but alas there are no properties for hostname there. Am I missing something blatently or is this functionality not provided through the API.
Thanks,
Rob...
Re: Accessing API from another machine.
Post by SorenR » 2008-06-03 20:22
robcha
Post by robcha » 2008-06-03 20:30
Let me clarify. I want to use the COM API in a script running on a remote machine from the hMailServer machine.
Thanks,
Rob...
Post by martin » 2008-06-03 20:38
You create an instance of the hMailServer.Application in some way. It's when you do this you need to specify on which host the object is going to be created. How to do this depends on what development language you're using. I suggest you check the documentation for the COM object creation function you're using.
robcha
Post by robcha » 2008-06-03 20:47
OK that is the missing piece. I need to specify the hostname in the CreateObject statement
Set objApp = CreateObject("hMailServer.Application", "remotehost")
Thanks a bunch!!!!
Rob...
