problem with DNSResolver
associates
Post by associates » 2008-01-24 02:11
I've got HMailServer 4.4 B270 version running on my mail-server machine. I've been getting error files in the logs as follows
"ERROR" 2580 "2008-01-22 02:38:35.228" "Source: DNSResolver::_Resolve, Code: HM10081, Description: DNS query failure. Treating as temporary failure. Query: elemental-artistry.com, Type: 15, DnsQuery return value: 9002."
"ERROR" 2560 "2008-01-22 05:19:38.087" "Source: DNSResolver::_Resolve, Code: HM10081, Description: DNS query failure. Treating as temporary failure. Query: connecthouston.com, Type: 15, DnsQuery return value: 9002."
"ERROR" 2580 "2008-01-22 10:53:06.509" "Source: DNSResolver::_Resolve, Code: HM10081, Description: DNS query failure. Treating as temporary failure. Query: connecthouston.com, Type: 15, DnsQuery return value: 9002."
"ERROR" 2584 "2008-01-23 19:28:09.369" "Source: DNSResolver::_Resolve, Code: HM10081, Description: DNS query failure. Treating as temporary failure. Query: plastmarket.com, Type: 15, DnsQuery return value: 9002."
"ERROR" 2544 "2008-01-24 04:43:27.978" "Source: DNSResolver::_Resolve, Code: HM10081, Description: DNS query failure. Treating as temporary failure. Query: alloutsupply.com, Type: 15, DnsQuery return value: 1460."
"ERROR" 2600 "2008-01-27 17:18:13.218" "Source: DNSResolver::_Resolve, Code: HM10081, Description: DNS query failure. Treating as temporary failure. Query: 1.0.0.127.relays.ordb.org, Type: 1, DnsQuery return value: 1460."
"ERROR" 2608 "2008-01-27 17:18:13.218" "Source: DNSResolver::_Resolve, Code: HM10081, Description: DNS query failure. Treating as temporary failure. Query: 1.0.0.127.relays.ordb.org, Type: 1, DnsQuery return value: 1460."
"ERROR" 2596 "2008-01-27 17:23:15.203" "Source: DNSResolver::_Resolve, Code: HM10081, Description: DNS query failure. Treating as temporary failure. Query: 1.0.0.127.relays.ordb.org, Type: 1, DnsQuery return value: 1460."
"ERROR" 2596 "2008-01-27 17:23:28.062" "Source: DNSResolver::_Resolve, Code: HM10081, Description: DNS query failure. Treating as temporary failure. Query: 1.0.0.127.relays.ordb.org, Type: 1, DnsQuery return value: 9002."
"ERROR" 2600 "2008-01-27 17:24:19.328" "Source: DNSResolver::_Resolve, Code: HM10081, Description: DNS query failure. Treating as temporary failure. Query: 1.0.0.127.relays.ordb.org, Type: 1, DnsQuery return value: 9002."
"ERROR" 2600 "2008-01-27 17:24:36.187" "Source: DNSResolver::_Resolve, Code: HM10081, Description: DNS query failure. Treating as temporary failure. Query: 1.0.0.127.relays.ordb.org, Type: 1, DnsQuery return value: 1460."
I have deactivated relays.ordl.org from DNS blacklists while having the following activated
sbl-xbl.spamhaus.org
bl.spamcop.net
multi.surbl.org
Are these errors to do with one of those activated ones?
Thank you in advance
Post by ^DooM^ » 2008-01-24 03:44
relays.ordb.org was shut down a long time ago.
http://www.hmailserver.com/forum/viewtopic.php?t=7018
Unsure why the others are failing though. can you manually lookup using a cmd prompt elemental-artistry.com?
I just tried it from here and it failed
*** DMZ.hellscream can't find elemental-artistry.com: Server failed
associates
Post by associates » 2008-01-25 08:27
Hi ^Doom^,
Nope, it failed here too. Do you have the same issue with your Hmailserver also?
Post by SorenR » 2008-01-25 10:41
I get a lot of these too but have resigned and accepted that "it's just one of those things".
What I do see when investigating the domains in error, the domains do exist (using WhoIs) but no IP address is assigned to them.
Post by ^DooM^ » 2008-01-25 10:41
If by issue you mean it cannot resolve those domains then yes those domains DNS are broken this is not a problem with your setup.
