awstats tutorial for your webserver
polarunion
Post by polarunion » 2004-07-07 19:32
I've just written a quick tutorial on how to integrate awstats - a web statistics machine, to run with your existing apache servers. see it at
http://learn.boxedout.com - step 7 at the bottom.
it's pretty awesome, everyone should try it out. Hopefully we can eventually change the log format so that hmail will be able to run with it..
Post by martin » 2004-07-07 19:35
Witch all other bugs?
Are you aware of a lot of bugs I'm not aware of? :)
