Run function with regexp processing doesn't work
Darxton
Post by Darxton » 2019-07-24 19:28
Hi everyone,
I'm trying to replace From field with value taken from body of message. I wrote the code below
Function Email(strRegEx, strMatch)
     Email = ""
        .Global = True
        .Pattern = strRegEx
        .IgnoreCase = True
	Set objMatches = .Execute(strMatch)
	if objMatches.Count > 0 then
		For i=0 To objMatches.Count-1
		    Set objMatch = objMatches.Item(i)
		    Email = "" & objMatch.SubMatches(0)
Sub ForOnlineShopOrders(oMessage)
	Dim NewEmail
	Dim Pattern
	Pattern = "Email:\s*([^ ""(\,>:</\\@¶]+@[^, >¶]+\.[0-9a-zA-ZрфРФ-]{2,8})"
	NewEmail = Email(Pattern, oMessage.Body)
'	NewEmail = "KLSHLAHF"
	oMessage.From = NewEmail
	oMessage.FromAddress = NewEmail
	oMessage.Save()
but the result is only errors in log when calling this function in rule:
"ERROR" 12988 "2019-07-24 20:26:33.269" "Script Error: Source:
It definetely do not like the string With CreateObject("VBScript.RegExp"), but i don't understand why, because following script saved as .vbs works fine on the same machine.
      Email = ""
         .Global = True
         .Pattern = strRegEx
         .IgnoreCase = True
Dim BodyText
Dim NewEmail
Dim Pattern
NewEmail = Email(Pattern, "Email: 	 email@gmail.com")
MsgBox NewEmail
Any ideas?
Darxton
Re: Run function with regexp processing doesn't work
Post by Darxton » 2019-07-24 23:45
Found the issue. In hmail script ALL variables must be declared before use, and execution fails at
Post by jimimaseye » 2019-07-25 08:13
Darxton wrote:
2019-07-24 23:45
Only if you happen to have OPTION EXPLICIT set at the top of the script. As you didnt show us your full eventshandler, we couldnt have advised on that.
But well done on figuring it out.
