Regex problem
Regex problem
Post by palinka » 2019-05-23 20:40
I have seen a pattern for a type of spam that I've been receiving.
Example (actual received) From: "Lexie" <EdwardWhite@smolka.sk>
The pattern is the name in quotation marks is always a first name and is different from the first name in the email address AND the email address ALWAYS consists of capitalized letters in the first and last name AT whateverdomain.tld.
This is readily apparent to the human eye but if scripted could result in false positives, so at first I just want to test it by just sending myself a message containing the from address every time it hits global rule if From (regex) ^.*((([A-Z][a-z]+)([A-Z][a-z]+))(?=@)).*$
MY PROBLEM is that in testing the regex matching part of the script, the first name of the email address contains the first few letters of the last name.
Pieced together from Soren's scripts...
      .Pattern = strRegEx
      .Global = bGlobal
      .MultiLine = True
      .IgnoreCase = True
' Example:
' "Lexie" <EdwardWhite@smolka.sk>
' (([A-Z][a-z]+)(?=(\"\s\<|\"\<)))  finds Lexie
' (([A-Z][a-z]+)(?=([A-Z][a-z]+\@)))  finds Edward
oMessage_From = """Lexie"" <EdwardWhite@smolka.sk>"
Dim strRegEx, Match, Matches
Dim o_name, o_emailname, sMSG
' find first name outside of <>
strRegEx = "(([A-Z][a-z]+)(?=(\""\s\<|\""\<)))"
Set Matches = oLookup( strRegEx, oMessage_From, False )
For Each Match In Matches
   o_name = Match.Value
wscript.echo o_name
' find first name inside <>
strRegEx = "(([A-Z][a-z]+)(?=([A-Z][a-z]+\@)))"
   o_emailname = Match.Value
wscript.echo o_emailname
If (o_name = o_emailname) Then
	sMSG = "Hit on name mismatch. Check spam for " & oMessage_From
	sMSG = "No match"
wscript.echo sMSG
In this example, o_name returns "Lexie" which is correct. However, o_emailname returns "EdwardWhi" instead of "Edward" and because of that, I cannot compare it to "Lexie". I tried other email addresses of varying lengths and it still returns a few letters of the last name. Anyone see what I'm screwing up here? I tried in 2 different regex testers and the regex part is good so I can't figure out what's wrong.
Re: Regex problem
Post by SorenR » 2019-05-23 20:56
Use https://regex101.com/
Click on the 3 lines top left and choose ECMAScript...
Change .IgnoreCase = True to False :mrgreen:
One thing though... Copy oLookup to a new function or you will break all previous use of the function :!:
Re: Regex problem
Post by palinka » 2019-05-23 21:20
Boom! I knew it was something dumb. :mrgreen: Thanks!
And yea, I do use regex101. I like that they have examples and not just worky/no-worky.
Also added function xLookup. :D
