Move emails to top of the queue based on certain priority header flags
cblaze22
Post by cblaze22 » 2019-05-05 02:59
Where can we move emails that come in to the top of the queue to be processed first based on a priority flag found in the header of the email?
Where is the best place to do this with scripting and is there anyone we can hire to do this for us?
Re: Move emails to top of the queue based on certain priority header flags
Post by jimimaseye » 2019-05-05 12:15
You can't. Not by any method.
cblaze22
Post by cblaze22 » 2019-05-05 14:06
Work with me here. The message below, is it executed before it gets into the queue?
OnAcceptMessage(oClient as hMailServer.Client, oMessage as hMailServer.Message)
If so how is the queue sorted and how does the "send now" button work in the queue to make emails go right away?
cblaze22
Post by cblaze22 » 2019-05-07 05:53
Anything?
Post by SorenR » 2019-05-07 12:54
It appears that the "Send Now" button in the Delivery Queue window resets delivery time for the specific oMessage.ID and then restarts the delivery engine.
        private void menuItemSendNow_Click(object sender, EventArgs e)
            WaitCursor waitCursor = new WaitCursor();
            hMailServer.DeliveryQueue deliveryQueue = GetDeliveryQueue();
            foreach (ListViewItem item in listDeliveryQueue.SelectedItems)
                string messageID = (string)item.Tag;
                deliveryQueue.ResetDeliveryTime(Convert.ToInt32(messageID));
            deliveryQueue.StartDelivery();
            Marshal.ReleaseComObject(deliveryQueue);
Interesting project ... It just may be possible to script such an event :idea:
cblaze22
Post by cblaze22 » 2019-05-07 13:31
Ok work with me here. I have posted that exact code you did multiple times without much luck on a good response.
If I wanted to use that code to send something right away, based on say a header, where would I put it? The OnAcceptMessage doesnt have a ID and that is when its placed in the queue right?
Also what does resetting the delivery time even do? Shouldnt that take it to the end of the line of the queue, nothing else?
Post by SorenR » 2019-05-07 15:42
cblaze22 wrote:
2019-05-07 13:31
OnDeliverMessage is when it is placed into the queue.
Everything revolves around the queue and the way in is via OnDeliverMessage for both incoming and outgoing messages.
cblaze22
Post by cblaze22 » 2019-05-07 16:15
Ok I feel like I am getting contradictory responeses with these methods. So OnDeliverMessage is when it goes INTO the queue. Meaning it has a Message ID, meaning I can run the code below to put it at the top of the queue. Please confirm.
Post by SorenR » 2019-05-07 16:46
cblaze22 wrote:
2019-05-07 16:15
That is is C# code... hMailServer is written in C++ and uses VBScript or JScript for eventhandling. Also what is your background for dealing with all this code? Are you a programmer?
cblaze22
Post by cblaze22 » 2019-05-07 17:07
Im a programmer, already programmed a VBScript to remove bounced messages within HMailServer so I know what I am doing.
I however dont know the logistics of how HMailServer flows. You just said its written in c++ but the admin panel IS NOT written in just c++,
https://github.com/nberardi/hMailServer ... cStatus.cs
Again can the code be convered to VBScript to do the same thing.
Post by SorenR » 2019-05-07 17:44
cblaze22 wrote:
2019-05-07 17:07
The Admin code is C# and uses the COM API... You would know that already as a programmer.
cblaze22
Post by cblaze22 » 2019-05-07 18:08
Ok so I have no idea what the point was of stating its C# code. VBScript can also use the COM API, so the statement was irrelevant. So again, can that code be used in the OnDeliverMessage method. I dont see why not?
Post by SorenR » 2019-05-07 23:22
Just mocking something together... This should list the content of the delivery queue.
VBScript stand-alone script to test on server in CMD window.
   Dim Match, Matches, Done
   Call oApp.Authenticate("Administrator", "VERY SECRET")
'  Preliminary data ...
'  status.UndeliveredMessages = 1041428   2019-05-07 22:45:40     soren@localdomain.tld soren@otherdomain.tld     1901-01-01 00:00:00     C:\hMailServer\Data\{26C0D5B5-7B5A-41A7-A720-42D8FF38A915}.eml  1       0
'                          oMessage.ID    Created                 From                  To (list with ',')        Next try                Filename                                                        ??      #retries ??
   Done = False
   Do Until Done
      Matches = Split(oApp.status.UndeliveredMessages, vbNewLine)
      For Each Match in Matches
         WScript.Echo "Match = " & Match
      WScript.Sleep(1000)
   Loop
   WScript.Quit 0
cblaze22
Post by cblaze22 » 2019-05-07 23:37
Well that is neat, but where do you think the best place to call this?
Post by SorenR » 2019-05-07 23:53
cblaze22 wrote:
2019-05-07 23:37
From a CMD window in Windows... On the server... It's a test... It does not really do anything but list the messages in queue - I hope - I usually never have any messages in my queue so I have only done limited testing.
It's a continous loop with a 1 second wait... Ctrl+C to stop it.
cblaze22
Post by cblaze22 » 2019-05-08 01:14
So you cant run that say on OnAcceptMessage as a polling strategy?
cblaze22
Post by cblaze22 » 2019-05-08 04:38
I think we are getting somewhere. Below I am able to grab the MessageIds in the queue on a delivery start.
Next I need a way to read the email so I can view the headers in it for a certain flag? Is the best way to do that to read in the the .eml filepath and if so is there some reusable code someone already has used.
After that I need to figure out this SetDeliveryTime on the Queue For That Message ID if the Flag is found.
Sub OnDeliveryStart(oMessage)
	Dim Match, Matches, Match2, Matches2
   	Call oApp.Authenticate("Administrator", "test")
	EventLog.Write("On Delivery Start")
         	EventLog.Write("Match = " + Match)
		Matches2 = Split(Match, vbTab)
		For Each Match2 in Matches2
		EventLog.Write(Match2)
		Exit For
Post by mattg » 2019-05-08 12:56
building on What SorenR started I may have something
This extracts the messageID from the Match, and then resets the deliverytime for that message, and then starts delivery
PLEASE TEST TEST TEST FIRST
   Dim Match, Matches, Done, ID
   Call oApp.Authenticate("Administrator", "Top_Secret_Password")
   Done = False
   Do Until Done
	     ID = Left(Match,InStr(Match," ")-12)
		 oApp.GlobalObjects.DeliveryQueue.ResetDeliveryTime(ID)
		 oApp.GlobalObjects.DeliveryQueue.StartDelivery
      WScript.Sleep(10000)
   Loop
   WScript.Quit 0
It doesn't give a higher priority to any message (we don't believe that this can be done).
It does however get messages that have failed and are awaiting re-delivery to be processed NOW
You would need to find the messages that you want to attempt redelivery of - or more correctly remove from the queue, and process just those IDs
Use Remove(int iMessageID) instead of the ResetDeliveryTime(int iMessageID) to remove a particular ID from the queue
cblaze22
Post by cblaze22 » 2019-05-08 13:39
You stated
But that doesnt mean just failed, but anything in the queue correct? Is oApp.status.UndeliveredMessages items in the queue or failed items in the queue?
Post by mattg » 2019-05-08 14:00
cblaze22 wrote:
2019-05-08 13:39
correct
cblaze22 wrote:
2019-05-08 13:39
Both
It is ALL items in the queue
But if you want a way to remove specific dud messages from the queue, this is the way to find them
cblaze22
Post by cblaze22 » 2019-05-08 15:18
I like this
Can you explain how it works real quick. If I want to grab the .eml column, I assume that would work the same way.
Post by SorenR » 2019-05-08 16:17
cblaze22 wrote:
2019-05-08 15:18
I like this
Hey Programmer !! Done that already for you in the thread about reading eml's from disk. And it works too...
cblaze22
Post by cblaze22 » 2019-05-08 16:27
I saw that nice job. So we know we can get messages in the queue, read the headers from them from disk. Then we know we can reset delivery time to send the email right away.
The last thing is where exactly should we put this code. Now I know you have a command window, which does a loop. I really dont want to have that unless I have too. I assume I could create that and have a Task Scheduler run it every 2 minutes.
My question is do you think there is a performance impact on this if there is 39,000 queue emails on HMailServer itself.
Also I assume there is NO other place in HMailServer where this code could live, CMD window outside of it is best place. Ive never done a VBScript stand alone, how do you run it within a command window? Just call the vbs file in the command window and it just runs?
Post by SorenR » 2019-05-08 17:12
I believe this should do it... Try it out on a test system first and if it breaks something - Hey, I warned you!
Filename: queue.vbs
Dim b, Match, Matches, oMail
Dim oApp : Set oApp = CreateObject( "hMailServer.Application" )
Call oApp.Authenticate( "Administrator", "BIG SECRET" )
Matches = Split( oApp.status.UndeliveredMessages, vbNewLine )
   b = Split( Match, vbTab )
   Set oMail = CreateObject( "hMailServer.Message" )
   strFilename = oMail.Filename
   With CreateObject( "Scripting.FileSystemObject" )
      .CopyFile b(5), strFilename, True
   oMail.RefreshContent
   If oMail.HeaderValue( "VIP" ) <> "" Then oApp.GlobalObjects.DeliveryQueue.ResetDeliveryTime( CInt( b(0) ) )
   Set oMail = Nothing
Windows Scheduler:
Run: CScript C:\hMailServer\Events\queue.vbs
Start in: C:\hMailServer\Events <=== That's where I installed hMailServer, your path may be different!
RunAs: Administrator (on my system!)
Schedule: Daily
Start Time 00:00
[Advanced] Repeat task: 1 minutes, Duration: 24 hours.
If HeaderValue("VIP") is not blank (it exists) then mail is reset and moved to top of queue.
You can find and tag messages in e.g. OnAcceptMessage and use:
If something Then
   oMessage.HeaderValue("VIP") = "YES"
All the code used here can be found in the forum if you search intelligently. All I have done is connect the dots.
Post by SorenR » 2019-05-08 18:10
New version, no need to restart delivery if nobody is moved ...
Dim b, Match, Matches, oMail, LiveVIP : LiveVIP = False
      LiveVIP = True
   Set oMail = Nothing
If LiveVIP Then oApp.GlobalObjects.DeliveryQueue.StartDelivery
cblaze22
Post by cblaze22 » 2019-05-08 21:30
Awesome Ill let you know how it goes. Anyway I can donate to your skills.
cblaze22
Post by cblaze22 » 2019-05-09 05:42
Set up and will see how it works this weekend when loads of emails come in. Final code is below, needed CLng and updated header name. You said to put a value for StartIn in Task Scheduler. If nothing is in there would it hurt anything? I put my VBScript file is a customer folder and pointed the StartIn folder to that which contains my VBScript but I didnt know if you pointed to inside the HMailServer directory for any specific reason other then the Events folder that has the trigger VBScripts.
Dim b, Match, Matches, oMail, Priority : Priority = False
   Set oMail = CreateObject("hMailServer.Message")
   If oMail.HeaderValue("X-Priority") = "1" Then
      oApp.GlobalObjects.DeliveryQueue.ResetDeliveryTime(CLng( b(0)))
      Priority = True
   Set oMail = Nothing
If Priority Then oApp.GlobalObjects.DeliveryQueue.StartDelivery
Post by SorenR » 2019-05-09 09:12
I hold all my hMailserver script/shell script code in the Events folder.
CInt (16bit) or CLng (32bit) dont care. It should really be LongLong (64bit) but VBScript is weird that way.
cblaze22
Post by cblaze22 » 2019-05-10 02:51
I got a file not found error. Probably ran at the same time it was being deleted and the .eml was already deleted. I havent tested the code below, but do you believe its right?
The error shows in a pop up on the server and doesn’t run again. Is there a way to do try catch so it will run next minute? I dont know much about VBScript error handling, especially in a CMD window like this on how it should end. If there is an Error on anything the program should either continue or just stop. If they are in the match loop its probably best just to go to the next item. Any thoughts from your experience?
Dim column, fso, Match, Matches, oMail, Priority : Priority = False
   column = Split( Match, vbTab )
   If fso.FileExists(column(5)) Then
   	fso.CopyFile column(5), strFilename, True
      		oApp.GlobalObjects.DeliveryQueue.ResetDeliveryTime(CLng(column(0)))
      		Priority = True
   Set oMail = Nothing
cblaze22
Post by cblaze22 » 2019-05-10 03:34
My code seems to work. Would the code below be something to do with any type of error?
On Error Resume Next
mikedibella
Post by mikedibella » 2019-05-10 03:38
I don't think this code will work.
I see the code is getting the stored message filename by parsing the UndeliveredMessages property, and that a Message object is created to parse the message.
This line:
Creates a new message object instance.
But this line:
Assigns the filename for the new message to the strFilename variable. It does not load the the contents of the message in the queue to the instance. So the subsequent inspection is acting on an empty message. The header will never be found.
Forget using the Message object and just open the file and iterate lines. The RFC delimits the headers and body with a blank line, so you only have to read until you reach the first blank. For each line, look for the string "X-Priority: 1" and trigger the re-prioritization using the QueueID in the first field of the UndeliveredMessages tab-delimited line.
cblaze22
Post by cblaze22 » 2019-05-10 06:21
I was skeptical of that line also, but my friend it does work and has long been working before my updated code.
Post by mattg » 2019-05-10 06:55
doesn't the FSO.copyfile copy the file contents a couple of lines down
Post by mattg » 2019-05-10 06:56
cblaze22 wrote:
2019-05-10 03:34
That is VB for
If there is an error, then ignore it and just keep going
Post by Dravion » 2019-05-10 07:47
I think it all comes down to the DB-Field "messagenexttrytime" for delaying outgoing mails.
UPDATE `hmailserver`.`hm_messages`
SET
	messagenexttrytime = '2019-05-10 08:03:59'
WHERE
	messagefilename = '{C6C3D5C8-8820-4BE0-923B-CD4C02708AD8}.eml';
If you run it via COM API Database Object, you can trigger it for example by incrementing messagenexttrytime (for example 33 Minutes, or any Dattime you want) after messagecreatetime.
PS: If you want to avoid instant delivery you can set all outgoing messages by messagelocked = 1, recalculate messagenexttrytime and unlock
the message.
Post by SorenR » 2019-05-10 11:47
Dravion, that is food for thought ... Good point but very risky if you are not 112% certain of what you are doing! I am actually already using the COM DB object for updating a custom table in the hm database so maybe I should have a look at it.
The rest of you!
Windows can present multiple errors from accessing a file, "do not exist", "is locked", "file already exists" and what not...
This is using "On Error Resume Next" and proceeds ONLY if no error whatsoever.
Dim column, oFSO, Match, Matches, oMail, Priority : Priority = False
	On Error Resume Next ' Switch ON errorhandling (if NO error found)
	Err.Clear
	oFSO.CopyFile column(5), strFilename, True
	If Err.Number = 0 Then
		On Error Goto 0 ' Switch OFF errorhandling
			Priority = True
		On Error Goto 0 ' Switch OFF errorhandling (if error found)
	Set oMail = Nothing
Set oFSO = Nothing
Err.Number = ...
https://docs.microsoft.com/en-us/office ... ble-errors
Post by SorenR » 2019-05-10 12:11
mikedibella wrote:
2019-05-10 03:38
This line:
But this line:
You are missing this:
The found message filename (column(5)) is copied to this new message filename (strFilename) and the command is simply repopulating ALL the message objects FROM FILE and thus you made a clone.
Post by SorenR » 2019-05-10 15:18
Dravion wrote:
2019-05-10 07:47
SET
WHERE
the message.
Well... Doesn't work :(
   If oMessage.FromAddress = "wile.e.coyote@acme.inc" Then
      ' Strictly MySQL due to date handling.
      strSQL = "UPDATE hmailserver.hm_messages SET messagenexttrytime = DATE_ADD(NOW(), INTERVAL 1 HOUR) WHERE messagefilename = '" & oMessage.Filename & "';"
      Call oDB.ExecuteSQL(strSQL)
      Set oDB = Nothing
Function GetDatabaseObject()
   Set GetDatabaseObject = oApp.Database
   Set oApp = Nothing
I had to create a fake non-existing SMTP relayer in order to keep the message on queue long enough to actually see it :wink:
I tried setting messagelocked = 1 ... did not stay in my system long enough for me to see it :mrgreen:
Using SQLyog to change messagenexttrytime manually works perfectly if you can delay the message long enough. If all goes well I have a message on queue until tomorrow 14:56:37 my time 8)
Re: Move emails to top of the queute based on certain priority header flags
Post by Dravion » 2019-05-10 15:32
Cool, good Job!
Maybe you can try to SQL insert a createdate in the future first and nexttrydate a bit longer than createdate?
I guess Createdate is the instant trigger which fires a new outgoing message right away because it is taken from the current Datetime if ithe message is qued via sql insert into hm_messages.
PS: Maybe you need to change createdate only and let hMailServer automaintain nexttrydate itself.
cblaze22
Post by cblaze22 » 2019-05-10 15:33
Here is my most updated code. Big test this weekend to see how it works. Worried about pulling ALL messages while doing this. Again doing this in a trigger with the incoming message is so ideal.
   Err.Clear
		On Error Goto 0
      			Priority = True
   		On Error Goto 0
   Set oMail = Nothing
Set fso = Nothing
Post by Dravion » 2019-05-10 15:42
Why do you compare this?
cblaze22 wrote:
2019-05-10 15:33
Do you manipulate the Headers externaly so you can rely on it?
mikedibella
Post by mikedibella » 2019-05-10 15:53
I missed the FileCopy and RefreshContent methods being used as a work-around for the missing load-from-file method on the Message object.
I'd also suggest you run the code using the cscript.exe interpreter and not the default wscript.exe interpreter. As you've seen, wscript will throw a modal dialog on error and remain resident. Cscript writes errors to the console error device and terminates.
I'll offer a few edits for readability:
const QueueID = 0
const QueueFile = 5
QueueMessages = Split(oApp.status.UndeliveredMessages, vbNewLine)
For Each QueueRecord in QueueMessages
   QueueMessage = Split( QueueRecord, vbTab )
   Err.Clear
   If fso.FileExists(QueueMessage(QueueFile)) Then
   	fso.CopyFile QueueMessage(QueueFile), oMailFilename, True
		On Error Goto 0
      			oApp.GlobalObjects.DeliveryQueue.ResetDeliveryTime(CLng(QueueMessage(QueueID)))
      			Priority = True
   		On Error Goto 0
   Set oMail = Nothing
Set fso = Nothing
Post by SorenR » 2019-05-10 16:25
mikedibella wrote:
2019-05-10 15:53
const QueueID = 0
const QueueFile = 5
Set fso = Nothing
If you go back this thread you'll notice I specified cscript for windows scheduler. It's been taken care of.
Well... Use comments and do a description header. Comments are ignored by the interpretor when running the binary "compiled" code. This other way the code just gets longer and longer and longer to no use ... and there is NO garantee you'll have a clue what it does in 6 months anyways.
cblaze22
Post by cblaze22 » 2019-05-12 02:42
Well its been a success. Had a log of 250 items, sent my priority email and got it within seconds. I always do. I thought this thing ran every minute, which I setup, but it seems its kinda instant, not sure why. In any case we have successfully moved items up the queue! Nice job guys!
cblaze22
Post by cblaze22 » 2019-05-12 03:44
Dravion wrote:
2019-05-10 15:42
cblaze22 wrote:
2019-05-10 15:33
Yes I set this externally.
Post by SorenR » 2019-05-12 10:49
cblaze22 wrote:
2019-05-12 02:42
You just got lucky and placed a message in the queue at the right time. Worst case scenario is 1 full minute - which is also the default for internal "autoreply" and "forward by rule".
