Save all EML no users
adrianp
Post by adrianp » 2019-03-30 15:03
I need to set up hMail as an SMTP gateway only, no users defined, only domains. It needs to receives all emails for the domains configured, still go through AV/Spam checks. I'd like to have all emails that make it through saved to a single folder as an EML file. For reference I'm currently using Microsoft SMTP server which is what I'm trying to mimic, but want the additional security that hMail has.
For reference, I was looking at this, but wasn't sure since it's dealing with accounts. I'm not sure if what I want to do would require a catch all account or not.
https://www.hmailserver.com/forum/viewt ... ml#p173970
Thank you,
Adrian
Re: Save all EML no users
Post by jimimaseye » 2019-03-30 17:18
Set the domains and a single catch all account. Then set up the catch all account in the domain settings. Ensure you have the correct authentication for external to local deliveries in your IP ranges.
Post by mattg » 2019-03-31 01:16
adrianp wrote:
2019-03-30 15:03
That can't happen with hMailserver, unless you specifically script it
adrianp
Post by adrianp » 2019-04-01 14:21
2019-03-31 01:16
adrianp wrote:
2019-03-30 15:03
Yes, I figured as much, hence me posting in the Scripting forum.
Post by mattg » 2019-04-02 02:41
Perhaps something like this (not tested)
Function SaveMessage(oMessage)
	dim oApp, OBJoutfile, FSO
	' hMailServer settings.
	Call oApp.Authenticate("Administrator", "TopSecretPassword")
	set OBJoutfile = FSO.CopyFile(oMessage.filename,"C:\SomeDirectory\" & oMessage.id & ".eml"
	set OBJOutFile = Nothing
With the function called from a Global rule, or as part of 'OnDeliverMessage'
Really depends on what other scripts / rules etc that you run
Post by Dravion » 2019-04-02 08:33
Interresting Solution.
IMHO
A free MTA like Postfix or Exim or even Sendmail doing pickup Directories per default.
Post by SorenR » 2019-04-02 11:38
There is one major issue that will break this project. It is a bug I have reported a long time ago, Martin looked at it but I believe nothing was done.
CatchAll address translation!
  • hMailServer translates recipient to Alias or CatchAll when receiving email. Thus the need for:
    • oMessage.Recipients(i).Address --> mail is delivered TO
    • oMessage.Recipients(i).OriginalAddress --> mail was intended FOR
  • Assuming originating server do not split the email like commercial servers mostly do - free GMail don't.
  • When hMailServer receive same email twice to same recipient - same recipient in To: and CC: there will be two identical items in oMessage.Recipients(i).Address and hMailServer will subsequently skip one. This is all fine BUT!
  • When hMailServer receive email to multiple recipients into a CatchAll account. ALL oMessage.Recipients(i).Address are translated into the CatchAll account - AND duplicates are skipped leaving only ONE recipient.
    • One email with three recipients ...
      CatchAll = daffy.duck@acme.inc
      Originating Server  -->  oMsg.Recipients.Address  -->  oMsg.Recipients().OriginalAddress
       wile.e.coyote@acme.inc   daffy.duck@acme.inc           wile.e.coyote@acme.inc
       road.runner@acme.inc     daffy.duck@acme.inc           road.runner@acme.inc
       elmer.fudd@acme.inc      daffy.duck@acme.inc           elmer.fudd@acme.inc
            ...-...             daffy.duck@acme.inc           wile.e.coyote@acme.inc
    • Consolidating recipients is usually fine, it will save space and time - However in this particular case we loose information about "the other two intended recipients". Codewise hMailServer consolidate recipients between OnSMTPData(oClient, oMessage) and OnAcceptMessage(oClient, oMessage) so it is not possible to catch this using scripts and rules are only performed later still.
    I have modified the script to include X-Envelope-To (based on .OriginalAddress) and X-Envelope-From as this information is NOT in the .eml file.
    The code is untested - DO NOT try this on a production server without first testing the code on a TEST server! This script WILL DELETE the original message in the process.
    Sub OnDeliveryStart(oMessage)
       ' Secure envelope sender and recipient(s)
       Dim i, strTo
          If (i = 0) Then strTo = oMessage.Recipients(i).OriginalAddress
          If (i > 0) Then strTo = strTo & ", " & oMessage.Recipients(i).OriginalAddress
       oMessage.HeaderValue("X-Envelope-To") = strTo
       ' Give this script permission to access all hMailServer settings.
       ' Copy message file to external directory.
          .CopyFile(oMessage.filename,"C:\SomeDirectory\" & oMessage.filename)
       ' Housekeeping
       oApp.Messages.DeleteByDBID(oMessage.ID)
       Set oApp = Nothing
adrianp
Post by adrianp » 2019-04-02 16:01
For this service, only emails with a single recipient are supported. I took both examples and combined it to the following:
dim oApp, oEMLFile, FSO
	FSO.CopyFile oMessage.filename, "D:\Data\Emails\drop\" & oMessage.Id & ".eml"
	Set FSO = Nothing
	 oApp.Messages.DeleteByDBID(oMessage.Id)
	 Set oApp = Nothing
There was compile error calling CopyFile.
Script Error: Source: Microsoft VBScript compilation error - Error: 800A0414 - Description: Cannot use parentheses when calling a Sub - Line: 22 Column: 77 - Code: 		FSO.CopyFile(oMessage.filename, "D:\Data\Emails\drop\" & oMessage.id & ".eml")"
I removed the parenthesis, but now I'm getting another error.
"Script Error: Source: Microsoft VBScript runtime error - Error: 800A01CA - Description: Variable uses an Automation type not supported in VBScript - Line: 22 Column: 1 - Code: (null)"
Post by mattg » 2019-04-02 16:41
can you please include all of your eventhandlers.vbs, so that we can see which is line 22
Remember to remove your password
Post by SorenR » 2019-04-02 16:58
adrianp wrote:
2019-04-02 16:01
	Set FSO = Nothing
	 Set oApp = Nothing
Since you took out the only code that can identify the recipient, how will you 112% know who the mail is for? The "To:" header can be faked just as easy as my name is "Elmer Fudd" <elmer.fudd@looney.tunes.inc>
adrianp
Post by adrianp » 2019-04-02 18:09
2019-04-02 16:41
The code is in the default EventHandler. Line 22 is FSO.CopyFile(oMessage.filename, "D:\Data\Emails\drop\" & oMessage.id & ".eml")"
adrianp
Post by adrianp » 2019-04-02 18:13
2019-04-02 16:58
I'm not using hMAIL as it would typically be used, meaning it's not an email sender to email recipient system. We are only using email to receive documents. We have specific measures in place to limit connections to this gateway as well as other mechanism.
Post by SorenR » 2019-04-02 21:47
adrianp wrote:
2019-04-02 18:13
2019-04-02 16:58
Documents as in attachments?
adrianp
Post by adrianp » 2019-04-02 21:49
Here's the contents of the complete file.
'   End Sub
'   Sub OnSMTPData(oClient, oMessage)
'   End Sub
'   Sub OnAcceptMessage(oClient, oMessage)
'   End Sub
'	Sub OnDeliveryStart(oMessage)
'	End Sub
	FSO.CopyFile oMessage.Filename, "D:\Data\Emails\drop\" & oMessage.Id & ".eml"
	Set FSO = Nothing
	 Set oApp = Nothing
'   End Sub
'   Sub OnBackupCompleted()
'   End Sub
'   Sub OnError(iSeverity, iCode, sSource, sDescription)
'   End Sub
'   Sub OnDeliveryFailed(oMessage, sRecipient, sErrorMessage)
'   End Sub
'   Sub OnExternalAccountDownload(oFetchAccount, oMessage, sRemoteUID)
'   End Sub
Where can I see the definition of oMessage ? I didn't see it in the online documentation.
adrianp
Post by adrianp » 2019-04-02 21:52
2019-04-02 21:47
adrianp wrote:
2019-04-02 18:13
2019-04-02 16:58
Does that have any impact in getting the EML file saved in a specified folder?
Post by SorenR » 2019-04-02 23:03
OK, this works as intended. "Housekeeping" was a long shot anyways and appears to violate functionality.
No worries, you can create a "Rule" to delete messages as they come in.
File is saved as "{ <GUID> }.eml" so NO duplicates ... EVER :mrgreen:
      .CopyFile oMessage.filename, "C:\SomeDirectory\" & Mid(oMessage.filename, InStr(oMessage.filename, "{")), True
The reason I asked about attachments is that you could wrap some code around this...
' Beginning of some code here
' For i = 0 To oMessage.Attachments.Count -1
'    strFile = "C:\SomeDirectory\" & oMessage.Attachments.item(i).Filename
'    oMessage.Attachments(i).saveas(strFile)
' Next
' Some more code here
Post by SorenR » 2019-04-02 23:32
adrianp wrote:
2019-04-02 21:49
https://www.hmailserver.com/documentati ... ct_message
Post by mattg » 2019-04-03 05:54
adrianp wrote:
2019-04-02 21:52
2019-04-02 21:47
I guess the question is do you want the email, or do you want the attachments saved to a set directory.
I save attachments sent from fax servers to a specific directory, for 'pickup' in another program
adrianp
Post by adrianp » 2019-04-03 14:37
2019-04-03 05:54
adrianp wrote:
2019-04-02 21:52
2019-04-02 21:47
No, I need them saved in the EML file. I have a service that processes the email and extracts the documents. I did a test last night with an attachment and that's coming through as expected.
adrianp
Post by adrianp » 2019-04-03 14:56
2019-04-02 23:03
Ok, it's working now with the code that doesn't try to access the ID property which seems isn't set at this stage.
Regarding housekeeping, I see the original emails inside the Data\[DOMAIN NAME]\[ACCOUNT] folder. I need to delete any message that was successfully saved in my event handler. I started looking at doing this in the rules as you mentioned.
What happens if an error occurs in my OnDeliverMessage? Highly unlikely, but I'm curious if there is a way to handle it so that the email isn't deleted.
What about emails marked as SPAM or VIRUS, where do those end up? I'm asking because I want to be able to monitor for when this happens and have the ability if needed to examine the text EML file.
Post by SorenR » 2019-04-03 15:46
adrianp wrote:
2019-04-03 14:56
2019-04-02 23:03
Well, the ID property IS set but that's not the problem, it's the other half of that statement that is not initialized properly - somehow I should have known that :roll:
Regarding the rest of your questions... Read the documentation, search the forum or hire a programmer. It is no longer a 5 minute task.
Housekeeping can be done with Rules and by using custom mailheaders you can pass parameters from script to Rules.
Errorhandling is a complex task and you need to know hMailServer and Microsoft COM/DCOM well. With VBScript you can control errorhandling inside the code and hMailServer have builtin errorhandling that can trigger additional scripting.
Regarding SPAM... Spammers change there MO all the time, I'm well into my 10'th year seriously fighting SPAM with hMailServer/SpamAssassin and have probably posted a couple thousand lines of script code on the forum for people to pick from or to become inspired from.
adrianp
Post by adrianp » 2019-04-16 00:26
I modified the script to add a header to indicate that it's been copied. I then added a rule to delete emails with this custom header. I'm seeing the email still in the data folder with the custom header added so I know that part is working. But for some reason the rule didn't delete the email.
I won't need to hire a developer, I am one :) I just want to see how much I can do with the scripting and with mechanisms that exist before I start digging through the COM interface.
SPAM isn't a huge concern as we block a lot of traffic at the edge as well as it's not actual email recipients that receive these emails. So anything that fails our proprietary verification ends up in a black hole anyways. I just thought it'd be something extra we can enable. Anyways, this is minor next to the main thing I'm trying to do. Right now if I can get the email deleted correctly I think I'm good.
Post by mattg » 2019-04-16 03:18
Try two separate rules, rather than adding to the existing rule.
Depends on what your rule does, it may actually make a copy of the message, and then delete one or the other not both.
Enable debug logging, it will show which rules fire, and what actions are taken
adrianp
Post by adrianp » 2019-04-16 03:58
2019-04-16 03:18
I didn't add to an existing rule. I added (only have 1 rule) which looks for my custom header (X-Cleanup) with value True and is set to delete the email.
The copying of the email is done in the event handler, OnDeliverMessage. This is where I copy the email to the specific folder that I need it to be and I add the custom header, X-Cleanup = True.
	oMessage.HeaderValue("X-Cleanup") = "True"
Anyways, you got me headed in the right direction. I hadn't noticed the rules at the account level and had created it as a global rule. The global rules seem to execute before the event handler. After I created it as an account rule it started working correctly.
"DEBUG" 1720 "2019-04-15 20:54:38.505" "Applying rules"
"DEBUG" 1720 "2019-04-15 20:54:38.505" "Executing event OnMessageDeliver"
"DEBUG" 1720 "2019-04-15 20:54:38.505" "Event completed"
"DEBUG" 1720 "2019-04-15 20:54:38.505" "Performing local delivery"
"DEBUG" 1720 "2019-04-15 20:54:38.505" "Applying rule Cleanup"
"DEBUG" 1720 "2019-04-15 20:54:38.505" "Performing rule action"
"DEBUG" 1720 "2019-04-15 20:54:38.505" "Local delivery completed"
"DEBUG" 1720 "2019-04-15 20:54:38.505" "Deleting message"
"DEBUG" 1720 "2019-04-15 20:54:38.505" "Deleting message file."
Thank you,
Adrian
