Fighting hackers and help to stop gsmtp powered mailers
nikkoid
Post by nikkoid » 2019-03-17 08:42
I have a hacker who is DDOS my server with millions of hacking attempts. I cannot bloc his IP because he is using proxies, and his local provider that is in the USA
However it is easy to spot him because of that:
"74.125.133.26"	"SENT: EHLO mail.xxx.com"
"SMTPC"	4308	923762	"2019-03-17 00:00:00.270"	"74.125.131.26"	"RECEIVED: 250 2.1.0 OK q10si4479680ljc.23 - gsmtp"
"SMTPC"	4308	923762	"2019-03-17 00:00:00.350"	"74.125.131.26"	"SENT: RCPT TO:<xxxxxx@gmail.com>"
"SMTPC"	4384	923763	"2019-03-17 00:00:00.273"	"74.125.133.26"	"SENT: MAIL FROM:<>"
"SMTPC"	4604	923756	"2019-03-17 00:00:00.274"	"74.125.131.26"	"RECEIVED: 250 2.1.0 OK s14si4388567lji.137 - gsmtp"
"SMTPC"	4604	923756	"2019-03-17 00:00:00.355"	"74.125.131.26"	"SENT: RCPT TO:<xxxxxx@gmail.com>"
"SMTPC"	4532	923755	"2019-03-17 00:00:00.276"	"74.125.68.26"	"SENT: STARTTLS"
gsmtp
I would like to have a script that could block anything received from gsmtp
How to do it?
Re: Fighting hackers and help to stop gsmtp powered mailers
Post by jimimaseye » 2019-03-17 10:17
Those messages are connecting to gmail services (not proxies). If you were able (which you are not) to block based on gsmtp then you would be blocking ALL in bound mail from everyone that uses gmail as their provider (included hosted services). And that could be a LOT.
Anyway.....
Your log shows that you are SENDING out this spam, not receiving them. Run this and post the results: https://www.hmailserver.com/forum/viewt ... 20&t=30914 so we can see if you are secure. Also check this https://www.hmailserver.com/documentati ... d_for_spam
Post by mattg » 2019-03-17 12:31
2019-03-17 10:17
Anyway.....
Yep
nikkoid
Post by nikkoid » 2019-03-18 19:20
Here is the diagnostic
2019-03-18   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - doxxxxxxxxxxxxxxxx.com         Enabled: True
                   Max size of accounts:    0
        Greylisting:     False
   "Domain2.com" - esxxxxx.com                    Enabled: True
        Greylisting:     False
   "Domain3.com" - soxxxxxxxxxx.com               Enabled: True
        Greylisting:     False
IP RANGES
     POP3:   True                              Antivirus:  False
     External To Local    - False
     External To External - False
   !!  Warning:  DEFAULT DOMAIN is SET  !! - "Domain2.com"
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
  Autoban Enabled: True       Max invalid logon attempts:     10
                              Minutes Before Reset:          300  (5.00 hours, 0.21 days)
                              Minutes to Autoban:          30000  (500.00 hours, 20.83 days)
There is a total of 2 auto-ban IP ranges.
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
No. Connections:  0  No Retries:  1 Mins:  1   Plain Text:         True  Bind: 144.76.75.87
                                               Max number commands:  20  Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
  Spam Mark:                  8       Use SPF:            True - 5    Use Spamassassin:    True
  Add X-HmailServer-Subject: False    Verify DKIM:        True - 5    Use SA score:        True
  Spam delete threshold: 8         Maximum message size: 1024
DNSBL ENTRIES:
                    bl.spamcop.net      Score: 100   Result: 127.0.0.2
                combined.njabl.org      Score: 10    Result: 127.0.0.*
            b.barracudacentral.org      Score: 5     Result: 172.127.0.2
SURBL ENTRIES:
   No 'enabled' entries
GREYLISTING:
  Greylisting:   True       Defer mins: 30       Days Unused: 1      Days Used: 36
                            Bypass SPF: True     Bypass A/MX: True
Greylist WHITELIST ENTRIES:
   IP Address: 85.25.235.237
Greylist DOMAINS enabled:
  !! No active domains enabled - GREYLISTING INEFFECTIVE !!
WHITELISTING
   No entries
  Block Attachments: True
               *.com             Command
               *.csh             CSH script
               *.inf             Setup file
SSL CERTIFICATES
   sonicreality
       Certificate: C:\Program Files (x86)\hMailServer\Bin\sonicreality.cert
       Private key: C:\Program Files (x86)\hMailServer\Bin\sonicreality.key
SSL/TLS
             SSL 3.0 :   True
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2019-03-18.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2019-03-18.log - !! ERRORS PRESENT !!
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -    True
                        DEBUG       -    True
                        AWSTATS     -      .
SYSTEM TESTS
Database type: MSSQL Compact
Backup directory d:\emails is writable.
HMAILSERVER.INI
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
Post by jimimaseye » 2019-03-18 20:44
My guess is you have a compromised account password. Follow the link previously posted in the troubleshooting section to track it down.
Also, remove the default domain that you have set (That only makes it easier for spambots. )
Post by mattg » 2019-03-19 03:02
ALSO your error log is populated
Please show the contents of C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2019-03-18.log
or a newer one if it exists
nikkoid
Post by nikkoid » 2019-03-19 15:39
I think the problem was the password as you said.
I have changed it and the spam stopped.
I have told the user to run an anti-virus...
Thanks for your feedback
