HeaderValue Case Sensitive?
porcupine
Post by porcupine » 2017-07-13 10:07
Can you confirm for the Message object Property:
string HeaderValue(string FieldName)
FieldName is not case sensitive for reading or writing?
thanks
Re: HeaderValue Case Sensitive?
Post by jimimaseye » 2017-07-13 10:54
Worth doing a little test maybe?
porcupine
Post by porcupine » 2017-07-13 11:11
thanks, I know how it appears (case insensitive). I would like it confirmed, as its not documented.
Post by jimimaseye » 2017-07-13 11:17
Im afraid that as it isnt documented you will be relying on peoples experience only. And for those that dont know from personal experience (as I am) a test would need to be done to gain the knowledge.
My suggestion was just to help you get your answer a lot quicker than waiting for the off-chance that someone with the knowledge may come on to the forum and answer you at some point in the future. (And any test I would do to gladly answer you is easy enough for you to do yourself).
porcupine
Post by porcupine » 2017-07-13 11:22
thanks, I have tested it, which is how I know it appears to be case insensitive. I can wait.
Post by mattg » 2017-07-14 00:45
Please suggest amendments to the documentation if that is the goal...?
porcupine
Post by porcupine » 2017-07-14 06:18
Sure, here are two suggested amendments for the Message object documentation:
 Value of the first occurrence of the given header field. FieldName is not case sensitive.
string FromAddress
 The sender address of the message, taken from "mail from" during the SMTP conversation and then inserted as the first occurrence of Return-Path.
Post by mattg » 2017-07-15 02:20
How is this??
https://www.hmailserver.com/documentati ... ct_message
@jimimaseye
Did I do all of the changes that you sent a few months back? I can't remember if got to finishing them or not
porcupine
Post by porcupine » 2017-07-15 04:28
thanks, looks good :)
Post by jimimaseye » 2017-07-15 10:38
mattg wrote:@jimimaseye
I will take a look and let you know.
