Forwarding Plugin for Roundcube
tunis
Post by tunis » 2017-03-05 16:32
One more plugin for roundcube. This is for editing forwarding of mail.
More info on my GitHub.
Latest release
Re: Forwarding Plugin for Roundcube
Post by RvdH » 2019-07-14 12:08
@tunis
Attached you find hms-autoban plugin, basically it takes hMailServer Autoban functionality to roundcube
I derived this plugin from MyRoundCube (payed subscription) which no longer exist, I changed a few bits and bytes to make it work with current roundcube version (1.3.9 at time of posting)
Are you willing to maintain this plugin? (PHP isn't really my thing)
hms_autoban.zip
(17.34 KiB) Downloaded 89 times
Post by RvdH » 2019-07-14 18:19
@btw, I own all hmailserver related myRoundcube plugins, a bunch of them you have covered in your hms-* plugins but if you like to have a look at them I happy to share them with you as i got f****d by myRoundcube devs as they seized operation, just after I purchased a year subscription. I doubt they will work flawlessly with latest version of roundcube, but it could give you inspiration :)
