HMS Backup Script
HMS Backup Script
Hello!
I have been trying to make the HMS Backup Script run unattended for several months and cannot seem to make it 100%. I use it with Task Scheduler to run every hour. The error I normally get is:
BACKUP ERROR: Backup or restore operation is already started
I do not have any spaces in the path names etc., put delays in the script to insure services run as expected, but no luck. It runs between 1x to 10x normally but then I get the error. I have searched here several times and cannot find anything very illuminating.
In TS I have all the correct options set such as "run with highest permissions", etc. Just for some reason sooner or later the script fails with above error.
I must reset the HMS service to get HMS backup to work again.
The script here is exaggerated but what I have tried lately.
Dim oApp
Dim iElapsed
Dim iStartTime
' Authenticate the client.
Call oApp.Authenticate ("Administrator", sAdminPassword)
oApp.Stop
iElapsed = 0
iStartTime = Now
Do While iElapsed < 5
iElapsed = DateDiff("s", iStartTime, Now)
Loop
Call oApp.BackupManager.StartBackup()
iElapsed = 0
iStartTime = Now
Loop
oApp.Start
iElapsed = 0
iStartTime = Now
Do While iElapsed < 3
Loop
Set oApp = Nothing
Dim oApp
Dim iElapsed
Dim iStartTime
oApp.Stop
iElapsed = 0
iStartTime = Now
Loop
iElapsed = 0
iStartTime = Now
Loop
oApp.Start
iElapsed = 0
iStartTime = Now
Loop
Set oApp = Nothing
Thanks,
Thomas
Thomas
Re: HMS Backup Script
That means that the previous backup is still running....tohare wrote:I have been trying to make the HMS Backup Script run unattended for several months and cannot seem to make it 100%. I use it with Task Scheduler to run every hour. The error I normally get is:
Mine typically takes a couple of hours backing up to a NAS using a custom script.
I robocopy the data directory to the NAS
I add the ini file and "\hMailserver\PHPWeAdmin\include_versioncheck.php" file
I backup MySQLdatabse and then zip the lot using 7Zip
Matt
Right, then how can I stop the previous Backup process? There is "plenty" of time between backups and obviously something hung for whatever reason.
Yes, I do a weekly MySQL Data dump as I trust the DB more than HMS with constant stream of attempted unauthorized logins, etc. MySQL is protected, HMS is exposed to the wild west.
Thanks,
Thomas
Thomas
In Task scheduler advanced options there is an option to stop all previous instances of this task before commencingtohare wrote: I use it with Task Scheduler to run every hour.
You can also limit the amount of time by setting the task scheduler to stop it running after say 45 minutes
Matt
I did all of that and it either is not working or something else is going on. I set every switch I thought possible to make Backup work. Only thing that resets it is to manually reset the HMS service switch in "Services" in the Management Console.
Thanks,
Thomas
Thomas
What do the hmailserver backup logs say before you stop the service?
Are you sure that it takes less than an hour to do the backup
Logs have nothing unusual. Even on a test server with limited emails, same results. Going to run Robocopy also as a safeguard. Thanks for idea.
Thanks,
Thomas
Thomas
Untested, built from memory. It should run....
NOTE: There is no point in having the code wait for the backup to finish when you already have that trigger in hMailServer
oApp.ServerState =
1: Stopped
2: Starting
3: Running
4: Stopping
NB: There is no check if hMailServer SERVICE has been stopped
EDIT: It appears that "Option Explicit" have a bad influence on running this script for some reason - removed...
oApp.ServerState =
1: Stopped
2: Starting
3: Running
4: Stopping
****** RunBackup.vbs ******
Dim oApp, EventLog, t
' Set up COM environment
Call oApp.Authenticate ("Administrator", sAdminPassword) ' <== CHANGE !!
Set EventLog = CreateObject("hMailServer.EventLog")
If oApp.ServerState = 1 Then
EventLog.Write("Backup already running or server has been stopped manually.")
EventLog.Write("Stopping server for Backup")
Call oApp.Stop
EventLog.Write("Waiting for server to stop")
Do While oApp.ServerState = 4
EventLog.Write("Waiting...")
t = Timer
Do While ((Timer - t) < 5) Xor (Timer < t)
Loop
Loop
EventLog.Write("Starting backup")
****** EventHandlers.vbs ******
Sub OnBackupFailed(sReason)
Dim oApp
EventLog.Write("Starting server AFTER backup FAILED! Error: " & sReason)
Call oApp.Start
Sub OnBackupCompleted()
Dim oApp
EventLog.Write("Starting server after backup COMPLETED.")
Call oApp.Start
- jimimaseye
- Moderator
Thomas check the backup destination doesn't have a DATA folder in it. Better still ensure the backup destination is completely empty (and with full write permissions).
You get this message when a previous backup fails leaving ruminants in them.
I think I messed up here... I inserted a statement before "Option Explicit" and that was the reason it failed...SorenR wrote:EDIT: It appears that "Option Explicit" have a bad influence on running this script for some reason - removed...
Anyways...
3004 "2016-08-21 16:29:00.615" "Stopping server for Backup"
3004 "2016-08-21 16:29:01.412" "Waiting for server to stop"
3004 "2016-08-21 16:29:01.412" "Starting backup"
720 "2016-08-21 16:56:15.167" "Starting server after backup COMPLETED."
There is a specific hMailserver backup log if you use the built in backup...tohare wrote:Logs have nothing unusual.
Jimmy,
Backup Destination is a folder with the data as the name -- we keep 1 BU file for each day (folder) for 1 week. All that is in that folder is the BU file for each BU operation.
The NAS software backups every new entry as they are added to the NAS remote device.
We do several simultaneous archive operations (completely separate) as a preventative and the hope is we do not lose more than 1 hours worth of email (should 30 minutes or less) in case of a catastrophe.
We could do instantaneous backups but we may get severe data bloat if we do that.
Thanks,
Thomas
Thomas
Soren,
Like I said, the script I had was "greatly exaggerated" to try to cover any "possible" problem. I have abandoned my script and running yours to see how that does. I really appreciate a great pointer in the right direction.
Thanks,
Thomas
Thomas
OK, seems more stable after ~10x of testing. Once in a while the temp BU dir is not deleted but the next round seems to delete it. If it works fine in 24+ hours I will post the script here.
BTW, any reason why the Temp dir is not deleted? Just curious as it does not seem to be a problem.
Thanks,
Thomas
Thomas
OK, I have documented an infinite loop in the code Soren posted. After more testing I will post new code.
Here is the error that caused the loop:
"Severity: 3 (Medium), Code: HM4203, Source: MySQLRecordset::Close, Description: An unknown error occurred while closing recordset."
In the Backup log I have:
4380 "2016-08-22 11:00:00.168" "Stopping server for Backup."
3144 "2016-08-22 11:00:00.231" "Stopping server for Backup."
3144 "2016-08-22 11:00:00.231" "Waiting for server to stop."
3144 "2016-08-22 11:00:00.231" "Waiting..."
3144 "2016-08-22 11:00:05.238" "Waiting..."
3144 "2016-08-22 11:00:10.246" "Waiting..."
... Infinite loop...
2972 "2016-08-22 11:14:56.591" "Waiting..."
2972 "2016-08-22 11:15:00.242" "Stopping server for Backup." <== Task Scheduler is set to retry on failure in 15 minutes.
2972 "2016-08-22 11:15:00.242" "Waiting for server to stop."
2972 "2016-08-22 11:15:00.242" "Waiting..."
2972 "2016-08-22 11:15:01.599" "Waiting..."
2972 "2016-08-22 11:15:05.249" "Waiting..."
Code that hangs on ServerState:
My Fix to end infinite loop (I used "30" as that is the normal network default timeout):
iElapsed = 0
iStartTime = Now
Do While oApp.ServerState = 4 and iElapsed < 30
Will post final (?) code in ~24 hours. Good news is the backups seem to run well otherwise.
iElapsed = 0
iStartTime = Now
Thanks,
Thomas
Thomas
Perhaps you should investigate WHY your server is taking so long to stop
OK, this has been working very well for a number of Backups. There is really no more problems with Backup. It is over commented for clarification.
' This scripts creates a hMailServer backup using the settings
' specified in hMailAdmin. You can double-click on the file to
' run the script.
' To use the script you need to update the sAdminPassword
' setting below to reflect your own hMailServer Administrator
' password. If you want to run automatic backups, please
' start this script using Windows Scheduled Tasks.
' Important to read server state.
' hStateStopped = 1, Server is stopped.
' hStateStarting = 2, Server is starting.
' hStateRunning = 3, Server is running.
' hStateStopping = 4, Server is stopping.
' BlowFish Hash of Admin Password.
Const sBlowFishPW = "b54084c9e4d33189"
' All vars declared here.
Dim oApp
Dim iStartTime, iElapsed, iStart, iTimer
' Create Application Object.
' Derypt BlowFish Encrypted PW.
sAdminPassword = oApp.Utilities.BlowfishDecrypt(sBlowFishPW)
' Authenticate the user.
' Create EventLog Object.
Set oEventLog = CreateObject("hMailServer.EventLog")
' Write a beginning block to log file.
oEventLog.Write("v--STARTING Backup Operation.--v")
' Start actual code to do Backup Operation.
' If server already stopped we have a problem.
oEventLog.Write("*** Backup already running or server has been stopped manually. ***")
' A problem exists, let's see if we can manually clear the problem.
oEventLog.Write("Resetting server.")
Call oApp.Stop
' Stop the server service so we can do the Backup cleanly.
oEventLog.Write("Stopping server for Backup.")
Call oApp.Stop
' Now we monitor the service to be sure it stopped.
oEventLog.Write("Waiting for server to stop.")
' Start main loop and prepare for actual Backup.
' This loop is to help insure server service is actually stopped.
iElapsed = 0
iStartTime = Now
' Loop while Server State is Stopping and Elapsed Time is < 30 seconds.
oEventLog.Write("Waiting...")
' Set the Timer Start Time var to Seconds Since Midnight (SSM) value.
iStartTime = Timer
' A local loop to insure log file is not flooded.
iTimer = 0
iStart = Now
' Sub-Loop to idle while Server is Stopping.
' 30/3 = 10 iterations/cycle log entries max written to log file.
Do While iTimer < 3 and oApp.ServerState = 4
iTimer = DateDiff("s", iStart, Now)
Loop
' Set main timer var for main loop.
Loop
' Check for Stopped Server.
oEventLog.Write("Server Stopped.")
' We assume all is ready so do the actual Backup Operation.
oEventLog.Write("Starting backup.")
oEventLog.Write("Backup COMPLETE.")
oEventLog.Write("*** Server did not stop, CANNOT BACKUP. ***")
' Clean up and re-start server service.
oEventLog.Write("Starting Server.")
Call oApp.Start
' Check Server State and write it to the Backup Log File.
If oApp.ServerState = 3 Then
oEventLog.Write("Server Started.")
oEventLog.Write("*** Server is in an UNDETERMINED STATE.***")
' Write an ending block to log file.
oEventLog.Write("^--ENDING Backup Operation.--^")
' EoF: StartBackup.Vbs.
' run the script.
Dim oApp
Call oApp.Stop
Call oApp.Stop
iElapsed = 0
iStartTime = Now
iStartTime = Timer
iTimer = 0
iStart = Now
Loop
Loop
Call oApp.Start
Thanks,
Thomas
Thomas
One major flaw with your script...
"Call oApp.BackupManager.StartBackup()" does NOT wait for the backup to complete
Why do you think I use "Sub OnBackupCompleted()" from EventHandlers.vbs in my example ??
PS.. What's with the Blowfish encryption ??
Soren,
Whoops! I am used to other environments and spaced out. Will change that and I appreciate your feedback.
The BlowFish thingy is because I got paranoid of having the HMS Admin PW in plain text in a text file. Seemed like a security issue so I encrypted it, then copied it into StartBackup.Vbs.
Back to the editor and apply what I have learned.
Thanks,
Thomas
Thomas
Several issues...
I had a "file not found" error during a backup and it caused HMS to stop SMTP services (minimum). The file was in MySQL and on disk. It may have been in the wrong place. I believe it should have been in a different Domain and was a week or two old (and "just" showed up today). Just trying to figure out why a MySQL (data) error caused SMTP to be unreachable.
Also, learned the "Process already started" error message was because the "WScript.Exe" program "hung" in memory. I had about a dozen instances in memory and had to manually clear them out. I ended up running a command in a BAT file in Task Scheduler at a time when I know the Backup process would be completed. Just as a "better safe than sorry" thingy. Command I use is:
TaskKill /IM WScript.Exe /f
Anyone have a cleaner solution? Or better yet, know why it hangs? 90%+ plus of the time there is not a problem with WScript.Exe, just a one time during 24+ hour period.
Thanks,
Thomas
Thomas
You may have put yourself in that position with your previous script...
Roadmap:
1: Script to start backup (remember it is STATELESS)
2: Resume backup handling in EventHandlers.vbs by using "Sub OnBackupFailed(sReason)" and "Sub OnBackupCompleted()"
I looked thru your last script and you are overcomplicating things. AND... You can leave the password in the script as cleartext. If some hacker manages to get access to your server you are doomed regardless
Now, handling errors may be a challenge since the scripted backup is stateless, so if you already started the backup and try to start it a second time, it will fail and trigger "Sub OnBackupFailed(sReason)" - later, when the initial backup completes, it will trigger "Sub OnBackupCompleted()"...
This is work in progress...
Roadmap:
Option Explicit
' CheckState.vbs Version 0.9
Dim FSO, oApp, EventLog, sAdminPassword : sAdminPassword = "MyVerySecretPassword"
If (FSO.FolderExists(oApp.Settings.Backup.Destination & "\DataBackup")) Then
EventLog.Write("Server is currently doing backup...")
EventLog.Write("Server was stopped for no reason, starting...")
Call oApp.Start
Soren, et. al.,
I am supposed to be notified when a reply is given here but lately it does not work. Maybe you are Anonymous?
So, sorry for the delay.
I will be looking at what you have just above soon. And I "really" appreciate the feedback.
I encrypted the HMS PW not so much for hackers, but for any legitimate user on the system. I am sure they are OK, but if they do not have the PW then they cannot cause problems. IOW, I can eliminate them from suspicion if I see something not quite right in the HMS arena. I even tell people to "not" give me info so I can remain out of suspicion if something odd happens. So encrypted PW is to protect the guilty -- uh, I mean innocent!
The "big" problem right now is the procedure below in EventHandlers.Vbs script does "not" appear to be firing -- at all!!! The same code runs fine in StartBackup.Vbs. That is the correct name, in the same dir as StartBackup.Vbs, and has two subroutines named: OnBackupCompleted(), OnBackupFailed(sReason).
Dim oApp, oEventLog
Dim sBlowFishPW, sAdminPassword
sBlowFishPW = "sg498jd92u8dh"
oEventLog.Write("Sub OnBackupCompleted() firing.")
I am having problems with BU but I highly suspect it is because the code above is not firing -- none of it!
The only suspect I can think of is in the INI file. The paths listed are correct but do not have "quote marks" around the actual paths. Which is not so suspect as the StartBackup.Vbs (in same dir) fires just fine.
I suspect either a very dumb mistake I am overlooking or for some reason HMS is not firing the code to execute code contained in EventHandlers.Vbs. One SUB seems to fire OK but second (Sub OnBackupCompleted()) does not.
Any ideas?
Soren -- Yes the code is overdone but I posted a disclaimer.
I said it was "exaggerated" which means I know it is over done. I spent many years writing code and tend to make it as "bulletproof" as possible. And over commented is usually less problems with other coders than under commented.
Dim oApp, oEventLog
Any ideas?
Thanks,
Thomas
Thomas
OK, there is a rouge record/email again (seems to happen 1x a day) and blowing BU operations out of the water. Yes, it may be caused by the current scripts still not 100% but I feel it is off that a misplaced record/email causes so much havoc in HMS.
"ERROR" 6280 "2016-08-24 17:00:01.128" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-BackupTask', Error code: 80, Message: boost::filesystem::copy_file: The file exists: "C:\Program Files (x86)\hMailServer\Data\RedTile.Com\Thomas\17\{17C83931-A86C-46B3-A843-62D261618514}.eml", "D:\Files\hMailserver\Mail_Server_BU\160824\DataBackup\RedTile.Com\Thomas\17\{17C83931-A86C-46B3-A843-62D261618514}.eml""
Thanks,
Thomas
Thomas
Hmm... "D:\Files\hMailserver\Mail_Server_BU\160824" is your backup path, hMailServer append "\DataBackup" and this is the directory I search for in my CheckState.vbs based on the assumption that once the backup is finished and compressed, hMailServer will delete this directory again.tohare wrote:OK, there is a rouge record/email again (seems to happen 1x a day) and blowing BU operations out of the water. Yes, it may be caused by the current scripts still not 100% but I feel it is off that a misplaced record/email causes so much havoc in HMS.
But it will only work if you have "compression" selected.
Soren,
Compression is set ON and creates the temp BU dir as expected. I will look at your CheckState.Vbs.
I had to disable the scheduled backup as the other problem -- The after backup SUB -- is not firing which can cause problems. The BU is not reliable now and has taken HMS offline at least 2x because the BU cleanup code will not fire.
Thanks,
Thomas
Thomas
Still trying to get the EventHandlers.OnBackupCompleted() SUB to fire. I had to disable it until I can figure out why the cleanup is not firing -- which is causing HMS to fail.
The first SUB OnBackupFailed(sReason) fires just fine. Here is the code:
Dim oApp, oEventLog
sBlowFishPW = "6f4015a66b98e17c65cd2fbed19f6b74"
Call oApp.Start
Dim oApp, oEventLog
Call oApp.Start
Thanks,
Thomas
Thomas
Why disable it?tohare wrote:Still trying to get the EventHandlers.OnBackupCompleted() SUB to fire. I had to disable it until I can figure out why the cleanup is not firing -- which is causing HMS to fail.
If OnBackupCompleted() does not fire and OnBackupFailed(sReason) fire OK then you have a problem with your backup.
Best way to monitor is if the backup folder hMailServer create (DataBackup) is removed after backup completes.
A couple of indicators can be...
- Compression must be selected, otherwise the folder stays until manually deleted.
- Permissions allow hMailServer to create, overwrite and delete files/folders.
- hMailServer crash...
On my server (Win 2003 Server, Core2 Duo 2.33 MHz, 2 GB RAM) backup of 21.000 emails (2.4 GB) take about 28 minutes.
Soren,
This is what has me confused. I cannot get a good log as to what actually happens during backup, especially with Task Scheduler. I have the HMS logs but they just have an over view of the operation.
The BU can run 3 or 6 times fine then WHAM! It will fail due to prior service still running or temp folder still there. I just ran BU and the temp dir still remained but on 1 message was in the 1 account folder (was not deleted). It was an old message also.
But the biggest problem is OnBackupCompleted() not firing at all, the Temp BU dir deleting/not deleting randomly, no way to see the process to see what happens. As stated, the HMS logs give an overview but low level operations (especially via Task Scheduler) cannot be viewed.
What user permissions do you use for your BU folders?
The system uses a Citrix XenCenter 6.5 VM box with a 10k RPM WD 1 terabyte drive, 4 - 1 Gbps NICs, liquid cooled and pictured:
Thanks,
Thomas
Thomas
My hMailServer sits on top of a cubbord next to my central heating, fuse box and home automation (IHC) so physically protected from intruders and it's only doing mail - webmail is on a 'Nix box sitting next to it. So... It's got admin rights.tohare wrote:Soren,
I remember some time back I got some weird results including some IOCP errors using "NT AUTHORITY\SYSTEM" so I changed all (ClamAV, SpamAssassin & hMailServer) jobs to <servername>/ADMINISTRATOR.
I set the permissions on the Scripts dir and the BU file dir to "EVERYONE" and enabled ALL permissions. I ran 6 test runs from the Task Scheduler dialog. 2 runs left the temp BU dir with only 1 message in them (different emails). 1 left what appeared as all emails. 3 ran fine and temp dir was deleted.
On all the runs the "Sub OnBackupCompleted()" never appeared to fire.
I gather from this test permissions is not the problem with my install. Basically same result I have consistently had.
Thanks,
Thomas
Thomas
I think that OnBackupCompleted will ONLY fire if the inbuilt backup is triggered
You guys really need to start reading from the top and not just shoot off answers.mattg wrote:I think that OnBackupCompleted will ONLY fire if the inbuilt backup is triggered
OK Sorry
Well come to find out that "neither" of the SUBS in EventHandlers.Vbs is firing. I am running latest version of HMS 5.6.5. I have set "full" permissions to "everyone". If anyone can confirm that VBS is firing and maybe any additional info for the VBS file that will be appreciated.
Thanks,
Thomas
Thomas
