Where is the best place to deny a message?
Nime
Post by Nime » 2016-02-01 09:56
I want to cut down the unnecessary traffic & disk usage. Currently I disable the account if it's inactive for a year. It's not a good solution for returning users. Now I decided to deny their incoming messages instead of making the account inactive.
So where is the best place in the events to check the last seen and deny the new messages of a user? OnDeliverMessage or OnAcceptMessage? What should I do if the message has multiple recipients? Can I remove a recipient from the list if it's not readonly?
Any suggestions?
Re: Where is the best place to deny a message?
Post by mattg » 2016-02-01 11:07
OnSMTPData will gine you a from address >> https://www.hmailserver.com/documentati ... onSMTPdata
Post by jimimaseye » 2016-02-01 13:53
Full order of execution (events) here: https://www.hmailserver.com/documentati ... ce_scripts
