phpwebadmin on remote server
megad
Post by megad » 2005-10-20 16:02
I'm using the new 4.2 beta, seems to work great so far
I had the 4.0 webadmin working, our webserver is separate from our email server.
When I upgraded the webserver's code to 4.2 webadmin, I can get the login prompt, but it hangs out.
Running the admin tool works ok, I have to select the servername, if I select localhost it hangs until I kill it
I think the website is defaulting to localhost, I didnt see any option to specify another hostname
did I miss something in the config file?
