Cannot automate script, always stuck in running mode.
black zero
Post by black zero » 2015-03-10 04:32
The said script is here: viewtopic.php?f=20&t=15363&p=173161#p158795
Having been using this script for many days, I am certain it's good for me.
Now the question is, I can't seem to automate it every night with Windows' Task Scheduler. The script runs, but always stuck in 'running' mode and doesn't actually do anything when it's ran by scheduler.
When I double click the script myself, it runs just fine and ends just fine.
What gives?
Sorry for double post, I'll remove my post (if I could) in that thread pertaining the same problem.
Re: Cannot automate script, always stuck in running mode.
Post by mattg » 2015-03-10 05:52
This is very likely Windows permission related
If you run the script in the task manager, you can set the permissions for the task.
Does your install use network storage, UNC paths etc?
Does your hMailserver service run under the default user, or a custom user.
Post by jimimaseye » 2015-03-10 12:07
Do a simple test.
Start a fresh new VBS eqiuivalent to open a text file, write to it and close it.
Then set it in task scheduler to run.
Does it run?
If it doesnt then its your windows permissions. If it does, look at what is different and compare between the 2 task scheduler entries. (folder locations, permissions etc)
I suspect, however, you have the wrong program call. Make sure you are entering the program call correctly. It should be:
Program: cscript
Arguments: ..path..\YourEmailClearupScript.vbs //nologo
black zero
Post by black zero » 2015-03-12 04:11
Here's a bit more data to depict my situations.
I'm running everything on Administrator account.
The said script is located on: C:\Program Files (x86)\hMailServer\Addons\Utilities
Funny thing is, when I setup to Scheduler other script named "StartBackup.vbs", it runs just fine.
I compared StartBackup.vbs vs this problematic script (CleanOldMails.vbs) in question, the status in Scheduler is all the same! Including the path to the folder (obviously script name is different) and even the login information to run the scripts.
1. Run whether user is logged in or not is ticked.
2. Run with highest priveleges is ticked
3. Trigger - Daily 10 PM every day
4. Script being run: "C:\Program Files (x86)\hMailServer\Addons\Utilities\CleanOldMails.vbs" (booohooo not working) vs "C:\Program Files (x86)\hMailServer\Addons\Utilities\StartBackup.vbs" (yes working)
5. Conditions: both are Start the task only when AC Power
And yes, I've tried creating a new txt file from scratch (CleanOldMails.vbs) and saved it as vbs. I tested to run it with double mouse click and it ran just ok. When I scheduled CleanOldMails.vbs it... didn't work.
I'm out of ideas.
Post by mattg » 2015-03-12 07:07
Does the script try to open a Window or an echo?
Scripts run via Task Scheduler can't access the GUI generally
black zero
Post by black zero » 2015-03-12 08:53
Yes, single line
WScript.Echo "Removed a total of " & GrandTotal & " message(s)."
At the very bottom.
I'm going to remove it.
Post by jimimaseye » 2015-03-12 11:46
jimimaseye wrote: I suspect, however, you have the wrong program call. Make sure you are entering the program call correctly. It should be:
Program: cscript
Believe me.
Post by mattg » 2015-03-12 13:40
Program: cscript
Believe me.
I normally just select 'start a program', then just point to the .vbs
This has always worked for me.
Post by SorenR » 2015-03-12 15:02
I believe if you run this "cscript //h:cscript //s" in a CMD prompt, you set the default scripting engine to "Console".
If the default scripting engine is "wscript" all output will appear as message boxes. It's really hard to click OK on a message box if the script is running unattended :wink:
"cscript //?" will display help and parameters for your scripting engine.
When running unattended it may be more productive to use "//B" and not "//NoLogo".
Post by jimimaseye » 2015-03-12 15:54
I wa able to reproduce the OP's error exactly as he described.
I fixed the problem by doing what I said.
black zero
Post by black zero » 2015-03-13 04:33
jimimaseye wrote:I wa able to reproduce the OP's error exactly as he described.
Yes, your solution fixed mine as well. Thank you very much, really appreciate it.
But still, it doesn't explain why my other script works (simply by pointing out the .vbs file from Task Scheduler) while this one in question does not work (although your solution did fix it).
I'm puzzled.
Any technical explanation about that?
Post by jimimaseye » 2015-03-13 12:06
Nope. It baffles me too.
I also have another VBS script that works just fine by a direct call with Task Scheduler. The only difference is that that script (that works) doesnt have the Hmailserver ComAPI object being called (its a disk checking routine). Maybe thats the reason.
In any case, if you read up, it is always strongly recommended you call VBS scripts (from a calling script eg BAT file or scheduler) either with WSCRIPT or CSCRIPT rather than direct association to VBS.
Post by mattg » 2015-03-13 12:13
SorenR wrote:I believe if you run this "cscript //h:cscript //s" in a CMD prompt, you set the default scripting engine to "Console".
As Soren says, the default script engine on that system is probably wScript, and it should be cSrcipt to run theses scripts from a scheduled task.
Thinking about this, I do remember this issue a decade or more back.
Good pick up Jimimaseye
