Com Properties.
timex163
Com Properties.
Post by timex163 » 2014-10-23 03:18
Greetings,
Is there a full documentation on the Com API of hmailserver.
Right now, I found that i can call the version by using the version property but can't find it in the documentation api page. Is there like a better reference then the documentation.
Re: Com Properties.
Post by percepts » 2014-10-23 04:06
if you have a script editor with an object browser then you can load the COM library "Hmailserver Type Library" into it and view all the com api object, methods and variables.
Visual Studio Express can do this or the Microsoft Script editor (MSEn.exe) which comes with microsoft office.
Its not documentation but rather a much easier way of finding everything in com api.
timex163
Re: Com Properties.
Post by timex163 » 2014-10-23 06:21
Thank you for the reply.
I just installed Hmailserver on my local machine since i have VB express installed and i can't get the com browser to open it.
I even tryed to see if com was working with this :
   Dim obApp
   ' Authenticate. Without doing this, we won't have permission
   ' to change any server settings or add any objects to the
   ' installation.
   Call obApp.Authenticate("Administrator", "testar")
   ' Locate the domain we want to add the account to
   Dim obDomain
   Set obDomain = obApp.Domains.ItemByName("example.com")
   Dim obAccount
   Set obAccount = obDomain.Accounts.ItemByAddress("account@example.com")
   ' Set the password to "secret"
   obAccount.Password = "secret"
   obAccount.Save
And
nada.
On VB express it tells me : The selected property cannot be browsed.
Even the version parameter is not working.
Any clue on what i may be missing ?
Re: Com Properties.
Post by SorenR » 2014-10-23 11:39
timex163 wrote:Thank you for the reply.
   Dim obApp
   ' installation.
   Dim obDomain
   Dim obAccount
   obAccount.Save
And
nada.
The code you show is for VBScript... Are you trying to make VB code?
I was mocking around with some VB code (not VBScript) a while back...
hMailDiag-0.0.1.rar
(21.65 KiB) Downloaded 69 times
Re: Com Properties.
Post by percepts » 2014-10-23 13:39
save the file as .vbs and then double click it.
We aren't here to teach you how to code. You must figure it out yourself.
timex163
Re: Com Properties.
Post by timex163 » 2014-10-25 01:05
Thanks for the post.
The thing is, everything works well on my windows server 2012 installation but in my windows 8.1 machine it does not work.
I can't run the script.
Re: Com Properties.
Post by SorenR » 2014-10-25 01:20
timex163 wrote:Thanks for the post.
If your Admin GUI works - then COM is installed correct...
On my laptop - where I have a "play" hmailserver installed - I must select from the GUI which hMail to administer.. The same you have to do with the VBS script...
Set obApp = CreateObject("hMailServer.Application", "server")
or
Set obApp = CreateObject("hMailServer.Application", "laptop")
http://www.w3schools.com/vbscript/func_createobject.asp
timex163
Re: Com Properties.
Post by timex163 » 2014-10-25 01:57
You where right thanks !
That made it work !!
SorenR you the best !
Has for you " percepts ", from now on, please refrain from posting on my topics. Every-time you intervene there's an insult with it.
Re: Com Properties.
Post by mattg » 2014-10-25 12:18
timex163 wrote:as for you " percepts ", from now on, please refrain from posting on my topics. Every-time you intervene there's an insult with it.
I don't think that was warranted.
I don't think that was very nice either.
Be thankful that anyone responds. After all we are all volunteers.
