API download
kevin@wine.co.za
API download
Post by kevin@wine.co.za » 2013-04-17 17:15
In hmail 4.x I used the great API to manage passwords, vacation messages etc.
But can find no reference to an API for 5.x
Is there an API - and if so, can someone please point me at it ?
Re: API download
Post by Bill48105 » 2013-04-17 20:26
Re: API download
Post by mattg » 2013-04-18 00:07
And there were significant changes in the API from 4.X to 5.X
http://www.hmailserver.com/documentatio ... _changelog
kevin@wine.co.za
Re: API download
Post by kevin@wine.co.za » 2013-04-18 09:29
Sorry guys - I am still missing something
In 4.x I needed to download a com wrapper that I could use in asp.net ( Interop.hMailServer.dll) and then happily made the API calls once this was in my bin folder / referenced in Visual Studio - but I see no-where to download a version for 5.x
Is there something similar for 5.x?
Or what do I need to do to reference hMailServer.Application in my project ?
Re: API download
Post by mattg » 2013-04-18 09:49
kevin@wine.co.za wrote:In 4.x I needed to download a com wrapper that I could use in asp.net
Really?
What specific version of hMailserver 4.X was that?
I started about 8 years ago with 4.2 I think, and I don't remember having to do that.
If your ASP is on the same server as hMailserver, the COM API should already be there.
kevin@wine.co.za
Re: API download
Post by kevin@wine.co.za » 2013-06-21 09:37
Sorry - went away for a while but now need to resolve this.
I am trying to set up a web interface to change passwords etc. Using .net 4.0 (so not vbs) and hmail 5.3
In .net 2.0 I used to do this by installing Interop.hMailServer in my bin folder for the website , and then I could happily make calls against the API - But I just upgraded to hmail 5.3 and .net 4 and now get 'Cannot create ActiveX component' error.
<%@ Register TagPrefix="hMailServer" Namespace="hMailServer" Assembly="Interop.hMailServer" %>
Dim obApp = CreateObject("hMailServer.Application")
What I think I need to do is wrap the COM API / register the dll - but I don't know which one I need to register / place in my bin folder ?
Or if anyone else has suggestions on a web based password change system using .net
Any help very much appreciated
Re: API download
Post by percepts » 2013-06-21 10:07
the COM API is installed with 5.3.x by default. However, I would suggest you install the very latest 5.4.x beta version of hmail server which is about to be released any day. i.e. its fully tested and ready to go live with over 1000 downloads already.
Then take a look at following ASP script which should show/provide you with code and how to access com api from ASP
http://www.hmailserver.com/forum/viewto ... 20&t=20186
If you have PHP on your server you could just run PHPWebAdmin and save yourself a lot of work. You will find folder PHPWebAdmin in your hmailserver folder. Just copy the whole PHPWebAdmin folder into your webserver, change a line in the config file and it should work providing you have PHP installed. The Above ASP light version may do what you want so check that first if you must use ASP.
p.s. in your script editor object browser, you should be able to load the com api and view all the classes, methods and properties. Its called "hMailserver Type Library" on my windows 7 system.
p.p.s. In VS Express 2012 object browser / custom component set / COM / hMailserver Type Library
bmanager
Re: API download
Post by bmanager » 2013-06-21 15:18
I have the same problem accessing API COM via ASP page.
I get this error
Microsoft VBScript runtime error '800a01ad'
ActiveX component can't create object
/LM/W3SVC/26/ROOT/global.asa, line 88
Using W2008R2 and IIS 7.5
Is the API COM 32bit or 64bit?
kevin@wine.co.za
Re: API download
Post by kevin@wine.co.za » 2013-06-21 15:25
I am assuming 32 bit
There are a number of articles on the web about running 32 bit under IIS7
Bottom line is you need to change your Pool to 32 bit and the theory says it should work
In Application Pool for the site - in Advanced Settings look for Enable32-Bit applications
bmanager
Re: API download
Post by bmanager » 2013-06-21 15:44
Yep. It's 32 bit.
If I run this code on .asp page
    On error resume next
    if isObject(Createobject("hMailServer.Application")) then
        response.write "hMS is installed."
    else
        response.write "hMS is not installed."
    end if
I get this response "hMS is installed."
