Message not displaying in SM 1.4.4 and HM4.0 B121
- Normal user
I have a an email that displays fine in OE and thunderbird but not in SM. What I don't know is if the email is not formatted properly or I have uncovered a bug in SM or HM. I have included the message below direct from the file in the HM data directory and replaced sensetive information.
I get the following PHP notice in SM: Notice: Array to string conversion in D:\Personal_Documents\websites\ghserver.co.uk\current\squirrelmail\functions\mime.php on line 400
and when I download it, it gets the extension .array but downloads OK.
Any ideas?
Regards Gabriel
Return-Path: <xxx@xxx.xxx>
Delivery-Date: Mon, 18 Jul 2005 20:32:11 +0200
Received: from [195.245.231.163] (helo=mail114.messagelabs.com)
by mxeu3.kundenserver.de with ESMTP (Nemesis),
id 0MKqIe-1DuaPT1uSh-000852 for xxx@xxx.xxx; Mon, 18 Jul 2005 20:32:11 +0200
X-VirusChecked: Checked
X-Env-Sender: xxx@xxx.xxx
X-Msg-Ref: server-8.tower-114.messagelabs.com!1121711530!11498868!1
X-StarScan-Version: 5.4.15; banners=-,-,-
X-Originating-IP: [80.169.1.81]
Received: (qmail 17376 invoked from network); 18 Jul 2005 18:32:10 -0000
Received: from unknown (HELO coloms.mpsgi.com) (80.169.1.81)
by server-8.tower-114.messagelabs.com with SMTP; 18 Jul 2005 18:32:10 -0000
Received: from colo-smtp.mpsgi.com (colo-smtp.mpsgi.com) by coloms.mpsgi.com
(Clearswift SMTPRS 5.1.4) with ESMTP id
<T7237d812d2c0a811c610cc@coloms.mpsgi.com> for
<xxx@xxx.xxx>; Mon, 18 Jul 2005 19:32:59 +0100
Received: by colo-smtp.mpsgi.com with Internet Mail Service (5.5.2657.72) id
<3CRLJ1XN>; Mon, 18 Jul 2005 19:32:09 +0100
Message-ID: <C61D22612EE38F44A5AA10CD2F6BCADE03A7A6E0@hilly.mpsgi.com>
To: "'xxx@xxx.xxx'" <xxx@xxx.xxx>
Subject: Private and Confidential: Automatic Notification from Modis Inter
national
Date: Mon, 18 Jul 2005 19:32:06 +0100
Return-Receipt-To: Modis Timesheet Invoice <xxx@xxx.xxx>
MIME-Version: 1.0
X-Mailer: Internet Mail Service (5.5.2657.72)
Content-Type: multipart/alternative; boundary=
"----_=_NextPart_001_01C58BC6.FFD8280E"
Envelope-To: xxx@xxx.xxx
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C58BC6.FFD8280E
Content-Type: text/plain; charset="us-ascii"
Body text
Content-Type: text/html; charset="us-ascii"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; charset=3Dus-ascii">
<META NAME=3D"Generator" CONTENT=3D"MS Exchange Server version 5.5.2657.73">
<TITLE>xxx</TITLE>
</HEAD>
<BODY>
message body
</BODY>
</HTML>
------_=_NextPart_001_01C58BC6.FFD8280E--
Any ideas?
Regards Gabriel
national
MIME-Version: 1.0
Body text
<HTML>
<HEAD>
<TITLE>xxx</TITLE>
</HEAD>
<BODY>
message body
</BODY>
</HTML>
- Normal user
I've just checked the SM HTML option and it doesn't make any difference so I'll try upgrading to the latest HM build later this week.
If that doesn't work I guess I'll just have to do some proper SM debugging! Can anyone confirm that the message format is OK?
cmurphy54 do you have the same problem with your automatic emails from modis?
Gabriel
Gabriel
- Normal user
I've just upgraded to the latest HM build and I get the same php notice and the message doesn't get displayed.
You also get a few more notices the first time you look at the message when loging in to SM. The notices are:
Notice: Undefined offset: 4 in D:\Personal_Documents\websites\ghserver.co.uk\current\squirrelmail\class\mime\Message.class.php on line 319
Notice: Undefined offset: 5 in D:\Personal_Documents\websites\ghserver.co.uk\current\squirrelmail\class\mime\Message.class.php on line 320
Notice: Undefined offset: 6 in D:\Personal_Documents\websites\ghserver.co.uk\current\squirrelmail\class\mime\Message.class.php on line 322
Gabriel
Gabriel
- Normal user
The email message you posted above, is that the entire contents of the eml-file?
Perhaps you can zip the eml file and send it to me at martin@hmailserver.com?
This is a bug in the MIME decoder hMailServer is using.
hMailServer apparantly do not handle one type of Content-Type header field properly. Content-type header fields normally looks like this:
But when they look like this, hMailServer can't parse it.
I would say that the MIME RFC is quite unclear on this. Using Google group search I found a couple of people wondering whether that syntax is allowed. This has never worked in hMailServer, so I assume that syntax is used almost never. Anyway, according to some guys in some forum I found, the syntax is valid...
In the mime-decoder there were lines that should handle this syntax, but they were commented out and not used. I've written in the forum for the MIME-decoder and asked them why the lines are commented out.
If they dont' reply to my question, I'll just fix it myself (since I got the source to the mime decoder)
boundary= "----_=_NextPart_001_01C58BC6.FFD8280E"
or
Content-Type: multipart/alternative; boundary= "Something"
"Something"
- Normal user
