Check body/HTMLBody with InStr()...
Rainer
Post by Rainer » 2010-12-17 18:57
Hello, is it possible to convert the following text - with hex-characters - in a ascii-text?
<br=3E-- <br=3EASKUMA AG<br=3EP=
rager Ring 4-12<br=3E66482 Zweibr=FCcken<br=3E<br=3E Tel: (06332) 2 06 61 36=
<br=3EFax: (06332) 2 06 61 15<br=3E<br=3E Vorstand: Oliver Reinking<br=3EVor=
sitzender des Aufsichtsrates: R=FCdiger Burkart<br=3ESitz der Gesellschaft: =
Zweibr=FCcken<br=3EHandelsregister: Amtsgericht Zweibr=FCcken HRB 1678 Z<br=3E=
<br=3E Registrierungs-Nr: D-3S71-1VD5G-02<br=3Ezust=E4ndige Beh=F6rde: IHK P=
falz, Ludwigsplatz 2-4, 67059 Ludwigshafen<br=3E<br=3E USt-IdNr=2E: DE203848=
108<br=3ESteuernummer: 35=2E657=2E06239<br=3E
I want to test the presence of the signature!
Kind regards :)
Rainer Noa
Re: Check body/HTMLBody with InStr()...
Post by ^DooM^ » 2010-12-18 00:53
I'm surer there are some mime decode tools out there :)
Rainer
Post by Rainer » 2010-12-18 11:47
Hello ^DooM^, thx for your answer! :)
Tools to use with vbscript; ok I will google for it!
Kind regards :)
Rainer Noa
