Aspell problems with Squirrelmail
UltraIT
Post by UltraIT » 2010-09-15 09:38
Hi there,
We have Squirrelmail and Aspell installed on our hMailServer but I am having some problems configuring the dictionaries and I'm wondering if anyone with abit of experience in this area could guide me in the right direction. I have installed aspell 0.50.3 win32 on our server and also downloaded the EN directory which is located in /aspell/dict directory and when clicking spellcheck in Squirrelmail it does appear to know there is a dictionary there but I get the following error:
Unhandled Error: The file "/C:/Progra~2/Aspell/dict/en-only.rws" can not be
opened for reading.
...but the rws file does not exist. Please could someone advise? I have already searched Google for two hours now yesterday and can't figure it out.
dzekas
Re: Aspell problems with Squirrelmail
Post by dzekas » 2010-09-15 10:27
UltraIT wrote:We have Squirrelmail and Aspell installed on our hMailServer but I am having some problems configuring the dictionaries and I'm wondering if anyone with abit of experience in this area could guide me in the right direction. I have installed aspell 0.50.3 win32 on our server and also downloaded the EN directory which is located in /aspell/dict directory and when clicking spellcheck in Squirrelmail it does appear to know there is a dictionary there but I get the following error:
opened for reading.
Which aspell packages are installed on your setup? Aspell-0-50-3-3-Setup.exe installs only spellchecking engine. you need aspell-en-0.50-2-3.exe
Please note that this is not SquirrelMail support forum.
UltraIT
Post by UltraIT » 2010-09-16 12:33
I know it's not Squirrelmail forum I am mainly just here in regards to setting up an aspell dictionary since I couldn't find any forum on the aspell website.
I have aspell-en-0.50-2-3.exe installed on the server but I think I have to do something with the dictionary files to create an RWS file? As it seems I am lacking the en-only.rws which is what it is trying to find. I have an en-only.cwl however.
Thanks.
dzekas
Post by dzekas » 2010-09-16 12:45
UltraIT wrote: I know it's not Squirrelmail forum I am here for aspell support with setting up a dictionary.
you don't have to do anything else in aspell installation. Just install dictionaries that you want use. If you already messed up in aspell directory, uninstall everything, delete aspell directory and reinstall aspell and dictionaries. Make sure that you don't confuse aspell 0.5 and 0.6. Use windows aspell packages from same source.
Check if aspell is working in console
c:\aspell\bin\aspell.exe -d en -c some-text-file.txt
Post by Bill48105 » 2010-09-19 02:23
UltraIT wrote: Unhandled Error: The file "/C:/Progra~2/Aspell/dict/en-only.rws" can not be opened for reading.
Not sure if it's why it's not working but why is there a / before C:?
bescher
Post by bescher » 2010-09-19 09:43
While we are on the subject of aspell (Which I also run
I keep on getting a error No input file specified
I have been working on it for sometime and haven't been able to figure it out
dzekas
Post by dzekas » 2010-09-19 10:08
bescher wrote:While we are on the subject of aspell (Which I also run
You use aspell in command line mode or aspell in pipe mode (some webmail or html editor scripts)?
bescher
Post by bescher » 2010-09-19 18:30
Insquirrelmail (Actually nutsmail) I check on the checkbox for spelling I am presumin it is asspell
As I understand it
dzekas
Post by dzekas » 2010-09-19 18:44
bescher wrote:Insquirrelmail (Actually nutsmail) I check on the checkbox for spelling I am presumin it is asspell
As I understand it
You are checking email in html format or in plain text?
Do you see warnings in SquirrelMail configtest.php or everything is OK?
Please note that questions about "No input file specified" error in SquirrelMail or Nutsmail should be asked on SquirrelMail or Nutsmail support channels.
bescher
Post by bescher » 2010-09-23 09:40
It is in html and no warnings other than "input file not found"
dzekas
Post by dzekas » 2010-09-23 09:55
bescher wrote:It is in html and no warnings other than "input file not found"
Check plugins/html_mail/fckeditor/editor/dialog/fck_spellerpages/spellerpages/server-scripts/spellchecker.php
Set $tempfiledir to $attachment_dir
$aspell_opts = "-a --lang=$lang --encoding=utf-8 -H";   // by FredCK
$tempfiledir = $attachment_dir;
It is possible that current directory is not writable and PHP tempnam function can't find writable directory.
If SquirrelMail configtest.php shows warnings (I am thinking about one specific warning), turn that setting off for SquirrelMail. spellchecker.php script has programming mistake which might create problems in some PHP configurations.
If you ask such questions on SquirrelMail mailing list, you would get same answers from same person and you won't anger hMailServer forum moderators.
