Newbie: send Quota-Message to Client
Lengen1971
Post by Lengen1971 » 2010-05-10 12:45
lately startet with scripting the hMailServer.
So, may you help with starting up a script, that tells the User, when its mailbox-quota is to high.
1. the script must reside in EventHandlers.vbs
2. which Event can I use?
3. how to identify the user currrently fetches mail?
w/regards
Michael
Re: Newbie: send Quota-Message to Client
Post by ^DooM^ » 2010-05-10 14:19
Have you checked out the user contributed scripts section? There maybe something in their for you to use.
Lengen1971
Post by Lengen1971 » 2010-05-10 14:54
Hi and thanx for your answer,
do you mean Support-Scripts here in this forum? I can´t find something useful for my problem.
Or where do I find this Script-Section you talk about?
regards
Michael
Post by ^DooM^ » 2010-05-10 15:19
ras07
Post by ras07 » 2010-05-10 21:10
I recently looked for such a script; there was a v4 one, but it was rather involved. It looked like it would be a lot easier in v5, so I wrote one:
Sub WarnQuotaMiscreants(MiscreantName, MiscreantAddress)
'  Sends a warning email if this user is are approaching their mailbox quota.
'  Can be triggered when the potential miscreant sends email, receives email, on a nightly
'  or weekly schedule, etc.
Const hMSAuthUser		= "user"			' Username of hMailServer administrator
Const hMSAuthPass		= "password"	' Password of hMailServer administrator
Const WarnFrom      = "Administrator"
Const WarnFromAddr  = "postmaster@yourdomain.com"
Const WarnThreshold = 85		' Percent quota used that will trigger warning email
Const WarnMsgSubj   = "WARNING: You are close to exceeding your mailbox quota!"
Dim WarnMsgBody
WarnMsgBody = "Your mailbox is now at $$PCTCAPACITY$$% capacity. " & _
	    " If you exceed your mailbox capacity, you will not be able to receive email, " & _
	    "and incoming email to your account will be rejected. Reduce your mailbox size " & _
	    "by deleting old emails or moving them to local folders. " & vbCRLF & vbCRLF & _
	    "Note that your mailbox quota includes all folders - Inbox, Sent, etc. - and even " & _
	    "the Trash folder, if it isn't routinely emptied automatically by your email " & _
	    "client or manually by you. "
	Dim WarnMsg
	Set WarnMsg = CreateObject("hMailServer.Message")
	Call WarnMsg.AddRecipient(MiscreantName, MiscreantAddress)
	If Not WarnMsg.Recipients(0).IsLocalUser Then
		Exit Sub 	' don't bother if it's not a local address
	Dim oApp, oAcct
	Call oApp.Authenticate(hMSAuthUser, hMSAuthPass)
	'	This small bit of convolution is necessary to handle aliases.
	Dim DomainName
	DomainName = LCase(Mid(WarnMsg.Recipients(0).Address, _
			InStr(WarnMsg.Recipients(0).Address, "@")+1))
	Set oAcct = oApp.Domains.ItemByName(DomainName).Accounts.ItemByAddress(WarnMsg.Recipients(0).Address)
	'	Check the quota used, and send the message if it's over the threshold.
	If (oAcct.QuotaUsed >= WarnThreshold) Then
		LogStr("Sending mailbox quota warning to " & WarnMsg.Recipients(0).Address & _
				" (" & oAcct.QuotaUsed & "%)")
		warnMsg.From = WarnFrom
		warnMsg.FromAddress = WarnFromAddr
		warnMsg.Subject = WarnMsgSubj
		warnMsg.Body = Replace(WarnMsgBody, "$$PCTCAPACITY$$", CStr(oAcct.QuotaUsed))
		warnMsg.Save
End Sub 'WarnQuotaMiscreants(MiscreantName, MiscreantAddress)
This goes in EventHandlers.vbs and is called from OnAcceptMessage. I call it when a user sends email, like so:
	Call WarnQuotaMiscreants(oMessage.From, oMessage.FromAddress)
It could just as easily be called when the user receives email. It would be trickier to trigger it when a user checks their email. This works for me.
I suppose I should get around to posting this in the user contributed script section ...
Hope this helps
ras
Lengen1971
Post by Lengen1971 » 2010-05-11 09:33
Hi everybody,
thanx a lot for your messages and solutions. I will now try this out and look forward to understand
the code.
regards
Michael
Lengen1971
Post by Lengen1971 » 2010-05-11 09:58
@rus07: Thank you a lot. Your script works fine, that was what I´m looking for.
Only this line throws an error:
Error:
"ERROR" 480 "2010-05-11 09:48:17.543" "Script Error: Source: Laufzeitfehler in Microsoft VBScript - Error: 800A000D - Description: Typen unverträglich: 'LogStr' - Line: 42 Column: 6 - Code: (null)"
I think this means: Type mismatch
w/regards
Michael
ras07
Post by ras07 » 2010-05-11 17:50
Lengen1971 wrote:Hi,
Error:
Oops, I missed that ... you can just delete that line, it just writes to a log file - doesn't do anything for the script
coby
Post by coby » 2011-02-20 17:13
could someone help me to get this script working?
i have added this to the EventHandlers.vbs
   'Sub OnAcceptMessage(oClient, oMessage)
   'End Sub
and where the other code comes? in a *. vbs file or in the EventHandlers.vbs ?
i got no error message
and i delete the whole line for logging
*sorry for my bad english*
Post by mattg » 2011-02-21 01:31
coby wrote:could someone help me to get this script working?
   'End Sub
You need to un-comment the sub and the end sub lines
(remove the leading ')
coby
Post by coby » 2011-02-21 17:38
done.
and where does the other code comes in? in a new *. vbs file or in the EventHandlers.vbs ?
coby
Post by coby » 2011-02-21 18:17
done.
i got this script to in my eventhandlers.vbs
http://www.hmailserver.com/forum/viewto ... 20&t=14280
Post by mattg » 2011-02-22 02:17
I didn't write it, but I expect that it also gets added to your eventhandlers.vbs file. This is the ONLY file loaded by hMailserver.
You will need to re-load the scripts and test for the expected outcomes...
