hmailserver vacation responder plugin does not work
black zero
Post by black zero » 2009-04-26 06:27
Here's the script, I only changed the hmail password as asked.
<?php
// If you have some problems with a plank page or something like that,
// pleasy temporary uncamment the following line:
//ini_set('error_reporting', E_ALL);
 * This configuration variable is used in hMailServer 4.3 authentication
 * If you are using 4.3 or later, you should set it to your main hMailServer
 * administrator password.
$admin_password = "itsmeadmin";
 * If you are using a default domain, you need to specify this domain here.
 * Otherwise the script won't work since it does not know what domain the
 * user is on.
$default_domain = "xxxx.co.id";
 * Settings for the calendar-popup:
$countdown_length = 20;					// Time until the calendar-popup-window closes automatically in seconds
$calendar_width 	= 180;				// Width of the calendar-popup-window
$calendar_height 	= 200;				// Height of the calendar-popup-window
$font_size = 'auto';						// Fontsize for the calendar-popup-window; possible values: 'auto', any integer
$type_of_datefield = 'auto';		// The type of the datefield; possible values: 'auto' or '', 'text', 'selectbox'
When I call the function via Squirrelmail, I only get a blank page.
The other one, password changer, works like a charm. -_- I have no idea what I did wrong... I installed this plugin in exactly the same way I installed password changer for SM.
Re: hmailserver vacation responder plugin does not work
Post by martin » 2009-04-26 11:03
What hMailServer version are you using_
black zero
Post by black zero » 2009-04-26 11:56
5.0 b 326
