black zero
- Normal user
Post
by black zero » 2009-03-16 03:21
It's awfully formatted on notepad.
The old hmail did a good job on formatting a backup log... Is there any specific step I need to take to fix the log format?
- Moderator
Post
by mattg » 2009-03-16 04:09
black zero
- Normal user
Post
by black zero » 2009-03-16 05:40
Thank you, will give it a try.
Just to clarify something, this script will
delete the log after it successfully sends an email, right?
EDIT:
It does not send any mail....
What happened? I've changed all values as specified in 'CHANGE ME' as instructed.
- Moderator
Post
by mattg » 2009-03-16 07:09
It sends an e-mail for me (and deletes the log).
What does your hmailserver error log say?
- Moderator
Post
by mattg » 2009-03-16 07:27
In your normal hmailserver log file
C:\Program files\hmailserver\logs\ in a standard installation
It will be called 'ERROR_Hmailserver_yyyy-mm-dd.log'
black zero
- Normal user
Post
by black zero » 2009-03-16 08:01
"ERROR" 388 "2009-03-16 10:36:27.085" "Script Error: Source: Microsoft VBScript compilation error - Error: 800A0409 - Description: Unterminated string constant - Line: 4 Column: 65 - Code: const g_sBNFromAddress = " 'CHANGE ME"
"ERROR" 2672 "2009-03-16 10:40:30.820" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01F4 - Description: Variable is undefined: 'MessageRecipientName' - Line: 33 Column: 3 - Code: (null)"
"ERROR" 224 "2009-03-16 11:02:25.492" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01F4 - Description: Variable is undefined: 'MessageRecipientName' - Line: 33 Column: 3 - Code: (null)"
"ERROR" 5132 "2009-03-16 11:07:30.226" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01F4 - Description: Variable is undefined: 'MessageRecipientName' - Line: 33 Column: 3 - Code: (null)"
"ERROR" 6112 "2009-03-16 11:26:26.195" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01F4 - Description: Variable is undefined: 'MessageRecipientName' - Line: 33 Column: 3 - Code: (null)"
- Moderator
Post
by mattg » 2009-03-16 08:21
black zero wrote:"ERROR" 388 "2009-03-16 10:36:27.085" "Script Error: Source: Microsoft VBScript compilation error - Error: 800A0409 - Description: Unterminated string constant - Line: 4 Column: 65 - Code: const g_sBNFromAddress = " 'CHANGE ME"
SO the change me at line 4 hasn't been changed correctly
Make sure that you have the address in double quotes ""
black zero
- Normal user
Post
by black zero » 2009-03-16 11:19
"ERROR" 4560 "2009-03-16 14:13:53.320" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01F4 - Description: Variable is undefined: 'MessageRecipientName' - Line: 33 Column: 3 - Code: (null)"
Now what's that?
- Moderator
Post
by mattg » 2009-03-16 13:10
Well what does it say.
Line 33 which is in the Sub OnBackupComplete()
Variable is undefined - 'MessageRecipientName' - Code: (null)
Again, this variable hasn't been set correctly. It should be something in double quotes like "something"
black zero
- Normal user
Post
by black zero » 2009-03-17 01:13
This is on line 33:
MessageRecipientName = "Evan"
Tell me what did I do wrong? T.T
- Site Admin
Post
by ^DooM^ » 2009-03-17 01:24
did you click the reload script button after making changes?
black zero
- Normal user
Post
by black zero » 2009-03-17 01:45
Yes.
And if I disable that line 33, the line 34 is the next error. The log shows the same thing.
- Moderator
Post
by mattg » 2009-03-17 02:25
I missed another line... Sorry
I have updated the script, or you can just add the following line under the const declarations at the top
dim MessageRecipientName, MessageRecipientAddress, MessageSubject
My eventhandlers.vbs is quite large - I was just cutting bits of it out for this script.
black zero
- Normal user
Post
by black zero » 2009-03-17 03:04
"ERROR" 5048 "2009-03-17 08:02:45.179" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01F4 - Description: Variable is undefined: 'ReadFileUnicode' - Line: 42 Column: 3 - Code: (null)"
I've applied your fix, and here's the new error log.
- Moderator
Post
by mattg » 2009-03-17 03:39
Ah, yep wrong function pasted at the bottom.
Replace the function ReadFile(sFile) with this
Function ReadFileUnicode(sFile)
dim fso, f
Set f = fso.OpenTextFile(sFile, 1, false, -1)
ReadFileUnicode = f.ReadAll
f.Close
Set f = Nothing
Set fso = Nothing
Again I have updated the post. Thanks for the debug help
black zero
- Normal user
Post
by black zero » 2009-03-17 04:25
Here you go. Apparently DeleteFile sub is missing lol.
"ERROR" 1384 "2009-03-17 09:23:19.851" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01F4 - Description: Variable is undefined: 'DeleteFile' - Line: 43 Column: 3 - Code: (null)"
- Moderator
Post
by mattg » 2009-03-17 04:32
You have the sub deletefile(sfile) included?
black zero
- Normal user
Post
by black zero » 2009-03-17 04:46
EDIT:
My bad, I forgot to include DeleteFile from the original script.
It's working properly now.
Next question: How do I make the script to send the notification to MORE than one recipient?
- Moderator
Post
by mattg » 2009-03-17 05:17
Good, glad that it is working for you.
By adding some of these
MessageRecipientName1 = "Mail Server" 'CHANGE ME
MessageRecipientAddress1 = "mailserver@domain.com" 'CHANGE ME
and these
oMessage.AddRecipient MessageRecipientName1, MessageRecipientAddress1
changing the number 1 each additional recipient
Let me know if you need further help.
Thanks for debugging for me.
black zero
- Normal user
Post
by black zero » 2009-03-17 08:17
Thank you!
I'll PM you if I encounter any problem with the edited script (with more than 1 recipient).
Finally I can sleep peacefully.
black zero
- Normal user
Post
by black zero » 2009-03-18 06:53
"ERROR" 2196 "2009-03-18 11:45:24.882" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01C2 - Description: Wrong number of arguments or invalid property assignment: 'oMessage.AddRecipient' - Line: 53 Column: 3 - Code: (null)"
Option Explicit
const g_sBNFrom = "zero" 'CHANGE ME
const g_sBNFromAddress = "postmasterzero@xxx.co.id" 'CHANGE ME
const g_sAdminPassword = "itsmeadmin" 'CHANGE ME
dim MessageRecipientName, MessageRecipientAddress,MessageRecipientName2, MessageRecipientAddress2, MessageSubject
Sub OnBackupFailed(sReason)
dim oApp, sBackupLog, oMessage
MessageRecipientName = "Vvvv" 'CHANGE ME
MessageRecipientAddress = "vvvv@xxx.co.id" 'CHANGE ME
MessageRecipientName2 = "yyyy" 'CHANGE ME
MessageRecipientAddress2 = "yyyy@xxx.co.id"
MessageSubject = "**** Backup FAILED ****"
' hMailServer settings.
sBackupLog = ReadFileUnicode(oApp.Settings.Backup.LogFile)
DeleteFile(oApp.Settings.Backup.LogFile)
oMessage.From = g_sBNFrom & " <" & g_sBNFromAddress & ">"
oMessage.FromAddress = g_sBNFromAddress
oMessage.AddRecipient MessageRecipientName2, MessageRecipientAddress2
oMessage.Body = "The backup DID NOT COMPLETE succesfully." & vbNewLine & "PLEASE INVESTIGATE" & vbNewLine & sBackupLog
Sub OnBackupCompleted()
MessageSubject = "Hmailserver Backup Completed"
oMessage.Body = "The backup completed succesfully." & vbNewLine & vbNewLine & sBackupLog
Sub DeleteFile(sFile)
Dim fso
fso.DeleteFile(sFile)
Set fso = Nothing
dim fso, f
f.Close
Set f = Nothing
Set fso = Nothing
Now what should I do?
- Moderator
Post
by mattg » 2009-03-18 07:24
Line 53 is " oMessage.Subject = MessageSubject" which is not the line that has caused the error.
Check that you have reloaded the scripts in hmailserver administrator, and have posted the correct script here please.
black zero
- Normal user
Post
by black zero » 2009-03-18 09:07
"ERROR" 4808 "2009-03-18 14:03:34.398" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01C2 - Description: Wrong number of arguments or invalid property assignment: 'oMessage.AddRecipient' - Line: 53 Column: 3 - Code: (null)"
It is the error log. I reloaded the script and rechecked my code up there, it's same.
And maybe it's a line break that caused you to miscalculate the line?
- Moderator
Post
by mattg » 2009-03-18 09:28
Yeah maybe, I was just trying to workout which of the addrecipient lines it was failing at...
Addrecipient needs two arguments and both need to be a string, ie a double quoted selection of letters, numbers and symbols.
I guess you could remark one or the other out to test. To remark out a line put a single apostrophe at the start of the line (')
like this
' oMessage.AddRecipient MessageRecipientName, MessageRecipientAddress
black zero
- Normal user
Post
by black zero » 2009-03-19 02:52
After several tests,
It's able to send a notification to one email address only. ~_~
- Site Admin
Post
by ^DooM^ » 2009-03-19 03:29
Send it to a distribution list then you can have as many recipients as you want.
black zero
- Normal user
Post
by black zero » 2009-03-19 05:38
lol that's brilliant. You should've told me that trick earlier...
