Backup log is messed up after upgrading to v5 from v4.
black zero
Post by black zero » 2009-03-16 03:21
It's awfully formatted on notepad. :(
The old hmail did a good job on formatting a backup log... Is there any specific step I need to take to fix the log format?
Re: Backup log is messed up after upgrading to v5 from v4.
Post by mattg » 2009-03-16 04:09
black zero
Post by black zero » 2009-03-16 05:40
Thank you, will give it a try.
Just to clarify something, this script will delete the log after it successfully sends an email, right?
EDIT:
It does not send any mail.... :( What happened? I've changed all values as specified in 'CHANGE ME' as instructed.
Post by mattg » 2009-03-16 07:09
It sends an e-mail for me (and deletes the log).
What does your hmailserver error log say?
black zero
Post by black zero » 2009-03-16 07:23
Where's the error log located? :(
Post by mattg » 2009-03-16 07:27
In your normal hmailserver log file
C:\Program files\hmailserver\logs\ in a standard installation
It will be called 'ERROR_Hmailserver_yyyy-mm-dd.log'
black zero
Post by black zero » 2009-03-16 08:01
"ERROR" 388 "2009-03-16 10:36:27.085" "Script Error: Source: Microsoft VBScript compilation error - Error: 800A0409 - Description: Unterminated string constant - Line: 4 Column: 65 - Code: const g_sBNFromAddress = " 'CHANGE ME"
"ERROR" 2672 "2009-03-16 10:40:30.820" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01F4 - Description: Variable is undefined: 'MessageRecipientName' - Line: 33 Column: 3 - Code: (null)"
"ERROR" 224 "2009-03-16 11:02:25.492" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01F4 - Description: Variable is undefined: 'MessageRecipientName' - Line: 33 Column: 3 - Code: (null)"
"ERROR" 5132 "2009-03-16 11:07:30.226" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01F4 - Description: Variable is undefined: 'MessageRecipientName' - Line: 33 Column: 3 - Code: (null)"
"ERROR" 6112 "2009-03-16 11:26:26.195" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01F4 - Description: Variable is undefined: 'MessageRecipientName' - Line: 33 Column: 3 - Code: (null)"
Post by mattg » 2009-03-16 08:21
black zero wrote:"ERROR" 388 "2009-03-16 10:36:27.085" "Script Error: Source: Microsoft VBScript compilation error - Error: 800A0409 - Description: Unterminated string constant - Line: 4 Column: 65 - Code: const g_sBNFromAddress = " 'CHANGE ME"
SO the change me at line 4 hasn't been changed correctly
Make sure that you have the address in double quotes ""
black zero
Post by black zero » 2009-03-16 11:19
"ERROR" 4560 "2009-03-16 14:13:53.320" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01F4 - Description: Variable is undefined: 'MessageRecipientName' - Line: 33 Column: 3 - Code: (null)"
Now what's that?
Post by mattg » 2009-03-16 13:10
Well what does it say.
Line 33 which is in the Sub OnBackupComplete()
Variable is undefined - 'MessageRecipientName' - Code: (null)
Again, this variable hasn't been set correctly. It should be something in double quotes like "something"
black zero
Post by black zero » 2009-03-17 01:13
This is on line 33:
MessageRecipientName = "Evan"
Tell me what did I do wrong? T.T
Post by ^DooM^ » 2009-03-17 01:24
did you click the reload script button after making changes?
black zero
Post by black zero » 2009-03-17 01:45
Yes.
And if I disable that line 33, the line 34 is the next error. The log shows the same thing.
Post by mattg » 2009-03-17 02:25
I missed another line... Sorry
I have updated the script, or you can just add the following line under the const declarations at the top
dim MessageRecipientName, MessageRecipientAddress, MessageSubject
My eventhandlers.vbs is quite large - I was just cutting bits of it out for this script.
black zero
Post by black zero » 2009-03-17 03:04
"ERROR"	5048	"2009-03-17 08:02:45.179"	"Script Error: Source: Microsoft VBScript runtime error - Error: 800A01F4 - Description: Variable is undefined: 'ReadFileUnicode' - Line: 42 Column: 3 - Code: (null)"
I've applied your fix, and here's the new error log.
Post by mattg » 2009-03-17 03:39
Ah, yep wrong function pasted at the bottom.
Replace the function ReadFile(sFile) with this
Function ReadFileUnicode(sFile)
	dim fso, f
	Set f = fso.OpenTextFile(sFile, 1, false, -1)
	ReadFileUnicode = f.ReadAll
	f.Close
	Set f = Nothing
	Set fso = Nothing
Again I have updated the post. Thanks for the debug help
black zero
Post by black zero » 2009-03-17 04:25
Here you go. Apparently DeleteFile sub is missing lol.
"ERROR"	1384	"2009-03-17 09:23:19.851"	"Script Error: Source: Microsoft VBScript runtime error - Error: 800A01F4 - Description: Variable is undefined: 'DeleteFile' - Line: 43 Column: 3 - Code: (null)"
Post by mattg » 2009-03-17 04:32
You have the sub deletefile(sfile) included?
black zero
Post by black zero » 2009-03-17 04:46
EDIT:
My bad, I forgot to include DeleteFile from the original script.
It's working properly now.
Next question: How do I make the script to send the notification to MORE than one recipient?
Post by mattg » 2009-03-17 05:17
Good, glad that it is working for you.
By adding some of these
   MessageRecipientName1 = "Mail Server"  'CHANGE ME
   MessageRecipientAddress1 = "mailserver@domain.com"  'CHANGE ME
and these
   oMessage.AddRecipient MessageRecipientName1, MessageRecipientAddress1
changing the number 1 each additional recipient
Let me know if you need further help.
Thanks for debugging for me.
black zero
Post by black zero » 2009-03-17 08:17
Thank you!
I'll PM you if I encounter any problem with the edited script (with more than 1 recipient).
:D Finally I can sleep peacefully.
black zero
Post by black zero » 2009-03-18 06:53
"ERROR"	2196	"2009-03-18 11:45:24.882"	"Script Error: Source: Microsoft VBScript runtime error - Error: 800A01C2 - Description: Wrong number of arguments or invalid property assignment: 'oMessage.AddRecipient' - Line: 53 Column: 3 - Code: (null)"
Option Explicit
const g_sBNFrom = "zero"  'CHANGE ME
const g_sBNFromAddress = "postmasterzero@xxx.co.id"  'CHANGE ME
const g_sAdminPassword = "itsmeadmin"  'CHANGE ME
dim MessageRecipientName, MessageRecipientAddress,MessageRecipientName2, MessageRecipientAddress2, MessageSubject
Sub OnBackupFailed(sReason)
   dim oApp, sBackupLog, oMessage
   MessageRecipientName = "Vvvv"   'CHANGE ME
   MessageRecipientAddress = "vvvv@xxx.co.id"   'CHANGE ME
   MessageRecipientName2 = "yyyy"   'CHANGE ME
   MessageRecipientAddress2 = "yyyy@xxx.co.id"
   MessageSubject = "**** Backup FAILED ****"
   ' hMailServer settings.
   sBackupLog = ReadFileUnicode(oApp.Settings.Backup.LogFile)
   DeleteFile(oApp.Settings.Backup.LogFile)
   oMessage.From = g_sBNFrom & " <" & g_sBNFromAddress &  ">"
   oMessage.FromAddress = g_sBNFromAddress
   oMessage.AddRecipient MessageRecipientName2, MessageRecipientAddress2
   oMessage.Body = "The backup DID NOT COMPLETE succesfully." & vbNewLine & "PLEASE INVESTIGATE" & vbNewLine & sBackupLog
Sub OnBackupCompleted()
   MessageSubject = "Hmailserver Backup Completed"
   oMessage.Body = "The backup completed succesfully." & vbNewLine & vbNewLine & sBackupLog
Sub DeleteFile(sFile)
   Dim fso
   fso.DeleteFile(sFile)
   Set fso = Nothing
   dim fso, f
   f.Close
   Set f = Nothing
   Set fso = Nothing
Now what should I do?
Post by mattg » 2009-03-18 07:24
Line 53 is " oMessage.Subject = MessageSubject" which is not the line that has caused the error.
Check that you have reloaded the scripts in hmailserver administrator, and have posted the correct script here please.
black zero
Post by black zero » 2009-03-18 09:07
"ERROR" 4808 "2009-03-18 14:03:34.398" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01C2 - Description: Wrong number of arguments or invalid property assignment: 'oMessage.AddRecipient' - Line: 53 Column: 3 - Code: (null)"
It is the error log. I reloaded the script and rechecked my code up there, it's same.
And maybe it's a line break that caused you to miscalculate the line?
Post by mattg » 2009-03-18 09:28
Yeah maybe, I was just trying to workout which of the addrecipient lines it was failing at...
Addrecipient needs two arguments and both need to be a string, ie a double quoted selection of letters, numbers and symbols.
I guess you could remark one or the other out to test. To remark out a line put a single apostrophe at the start of the line (')
like this
' oMessage.AddRecipient MessageRecipientName, MessageRecipientAddress
black zero
Post by black zero » 2009-03-19 02:52
After several tests,
It's able to send a notification to one email address only. ~_~
Post by ^DooM^ » 2009-03-19 03:29
Send it to a distribution list then you can have as many recipients as you want.
black zero
Post by black zero » 2009-03-19 05:38
lol that's brilliant. You should've told me that trick earlier...
