When clicking folders in Squirrel Mail I get a login error.
wally2255
Post by wally2255 » 2005-02-23 11:45
I am new to Squirrel and Hmail. When i go into my test account i have no folder on the left side and when i click on folder it gives me a logon error.
Whe I use the pops acount with outlook it downloads mail fine.
IIS, PHP, Hmail are installed.
"DEBUG" 1808 "2005-02-23 04:52:50.821" "SocketConnection::SocketConnection()"
"IMAPD" 1808 "2005-02-23 04:52:50.821" "127.0.0.1" "RECEIVED: A001 LOGIN "test@walts1.com" "test""
"IMAPD" 1808 "2005-02-23 04:52:50.841" "127.0.0.1" "SENT: A001 OK LOGIN completed[nl]"
"IMAPD" 1808 "2005-02-23 04:52:50.841" "127.0.0.1" "RECEIVED: A002 CAPABILITY"
"IMAPD" 1808 "2005-02-23 04:52:50.851" "127.0.0.1" "SENT: * CAPABILITY IMAP4 IMAP4rev1 QUOTA[nl]A002 OK CAPABILITY completed[nl]"
"IMAPD" 1808 "2005-02-23 04:52:50.861" "127.0.0.1" "RECEIVED: . LIST "INBOX" """
"IMAPD" 1808 "2005-02-23 04:52:50.861" "127.0.0.1" "SENT: * LIST (/NoSelect) "." ""[nl]"
"IMAPD" 1808 "2005-02-23 04:52:50.871" "127.0.0.1" "SENT: . OK LIST completed[nl]"
"IMAPD" 1808 "2005-02-23 04:52:50.881" "127.0.0.1" "RECEIVED: A003 LOGOUT"
"IMAPD" 1808 "2005-02-23 04:52:50.881" "127.0.0.1" "SENT: * BYE Have a nice day[nl]A003 OK Logout completed[nl]"
"DEBUG" 1808 "2005-02-23 04:52:50.891" "SocketConnection::~SocketConnection()"
"DEBUG" 1976 "2005-02-23 04:52:52.554" "SocketConnection::SocketConnection()"
"IMAPD" 1976 "2005-02-23 04:52:52.564" "127.0.0.1" "RECEIVED: A001 LOGIN "test@walts1.com" """
"IMAPD" 1976 "2005-02-23 04:52:52.574" "127.0.0.1" "SENT: A001 BAD Password incorrect.[nl]"
"DEBUG" 1976 "2005-02-23 04:52:52.634" "SocketConnection::~SocketConnection()"
"DEBUG" 1976 "2005-02-23 04:53:00.445" "SocketConnection::SocketConnection()"
"IMAPD" 1976 "2005-02-23 04:53:00.455" "127.0.0.1" "RECEIVED: A001 LOGIN "test@walts1.com" """
"IMAPD" 1976 "2005-02-23 04:53:00.465" "127.0.0.1" "SENT: A001 BAD Password incorrect.[nl]"
"DEBUG" 1976 "2005-02-23 04:53:00.535" "SocketConnection::~SocketConnection()"
Post by martin » 2005-02-23 13:29
What PHP version?
wally2255
Post by wally2255 » 2005-02-23 18:57
PHP v 3.0
Post by martin » 2005-02-23 21:23
According to the SquirrelMail requirements, you need at least php 4.1.2
http://www.squirrelmail.org/wiki/Squirr ... quirements
wally2255
Post by wally2255 » 2005-02-24 05:20
sorry i gave the wrong info i have PHP v 4.3.10.10
tourcd
Post by tourcd » 2005-07-22 14:07
I have v5.04 and have exactly the same problem. The SM server seems to be down as I can't navigate to the link above. Am I running a compatible version?
Post by martin » 2005-07-22 14:21
Have you turned on cookies?
Have you specified a valid writeable session.save_path in php.ini?
tourcd
Post by tourcd » 2005-07-22 15:21
I have edited the c:\winnt\php.ini to the following...
; where MODE is the octal representation of the mode. Note that this
; does not overwrite the process's umask.
session.save_path = "c:\temp"
Everyone has full control permissions on the temp directory.
Post by martin » 2005-07-22 15:28
And you have restarted Apache/IIS after doing that, right?
Is it still the exact same error?
tourcd
Post by tourcd » 2005-07-22 15:37
This is the error log...
I get nothing on the left-hand navigation pane.
"DEBUG" 1400 "2005-07-22 14:33:52.859" "SocketConnection::SocketConnection()"
"IMAPD" 1400 "2005-07-22 14:33:52.859" "192.168.10.4" "RECEIVED: A001 LOGIN "test@test.co.uk" "test""
"IMAPD" 1400 "2005-07-22 14:33:52.859" "192.168.10.4" "SENT: A001 OK LOGIN completed[nl]"
"IMAPD" 1400 "2005-07-22 14:33:52.875" "192.168.10.4" "RECEIVED: A002 CAPABILITY"
"IMAPD" 1400 "2005-07-22 14:33:52.875" "192.168.10.4" "SENT: * CAPABILITY IMAP4 IMAP4rev1 QUOTA[nl]A002 OK CAPABILITY completed[nl]"
"IMAPD" 1400 "2005-07-22 14:33:52.875" "192.168.10.4" "RECEIVED: . LIST "INBOX" """
"IMAPD" 1400 "2005-07-22 14:33:52.875" "192.168.10.4" "SENT: * LIST (/NoSelect) "." ""[nl]"
"IMAPD" 1400 "2005-07-22 14:33:52.875" "192.168.10.4" "SENT: . OK LIST completed[nl]"
"IMAPD" 1400 "2005-07-22 14:33:52.875" "192.168.10.4" "RECEIVED: A003 LOGOUT"
"IMAPD" 1400 "2005-07-22 14:33:52.875" "192.168.10.4" "SENT: * BYE Have a nice day[nl]A003 OK Logout completed[nl]"
"TCPIP" 1400 "2005-07-22 14:33:52.890" "IMAPD - Connection to client 192.168.10.4 closed."
"DEBUG" 1400 "2005-07-22 14:33:52.906" "SocketConnection::~SocketConnection()"
"TCPIP" 1868 "2005-07-22 14:33:53.187" "IMAPD - Connection from 192.168.10.4 accepted."
"DEBUG" 1404 "2005-07-22 14:33:53.187" "SocketConnection::SocketConnection()"
"IMAPD" 1404 "2005-07-22 14:33:53.187" "192.168.10.4" "RECEIVED: A001 LOGIN "test@test.co.uk" """
"IMAPD" 1404 "2005-07-22 14:33:53.203" "192.168.10.4" "SENT: A001 NO Invalid user name or password.[nl]"
"TCPIP" 1404 "2005-07-22 14:33:53.218" "IMAPD - Connection to client 192.168.10.4 closed."
"DEBUG" 1404 "2005-07-22 14:33:53.234" "SocketConnection::~SocketConnection()"
"TCPIP" 1868 "2005-07-22 14:33:53.312" "IMAPD - Connection from 192.168.10.4 accepted."
"DEBUG" 944 "2005-07-22 14:33:53.328" "SocketConnection::SocketConnection()"
"IMAPD" 944 "2005-07-22 14:33:53.328" "192.168.10.4" "RECEIVED: A001 LOGIN "test@test.co.uk" """
"IMAPD" 944 "2005-07-22 14:33:53.328" "192.168.10.4" "SENT: A001 NO Invalid user name or password.[nl]"
"TCPIP" 944 "2005-07-22 14:33:53.343" "IMAPD - Connection to client 192.168.10.4 closed."
"DEBUG" 944 "2005-07-22 14:33:53.343" "SocketConnection::~SocketConnection()"
tourcd
Post by tourcd » 2005-07-28 09:11
I'm still getting the above error, does anyone have any ideas?
Post by martin » 2005-07-28 11:28
Of some reason, SquirrelMail seems to forget the password you entered. Because in the log you posted, the first time it logs on using a password, the second time it doesn't provide a password.
If you look in your C:\Temp path, do you have files named sess_* in that path?
tourcd
Post by tourcd » 2005-07-28 16:18
No, nothing appears in that directory. The log is actually showing this now, perhaps I've changed something which has resulted in the following error...
"TCPIP" 3076 "2005-07-28 15:14:27.609" "IMAPD - Connection from 192.168.10.4 accepted."
"DEBUG" 2576 "2005-07-28 15:14:27.609" "SocketConnection::SocketConnection()"
"IMAPD" 2576 "2005-07-28 15:14:27.609" "192.168.10.4" "RECEIVED: A001 LOGIN "test@look4homes.co.uk" "test""
"IMAPD" 2576 "2005-07-28 15:14:27.609" "192.168.10.4" "SENT: A001 OK LOGIN completed[nl]"
"IMAPD" 2576 "2005-07-28 15:14:27.625" "192.168.10.4" "RECEIVED: A002 CAPABILITY"
"IMAPD" 2576 "2005-07-28 15:14:27.625" "192.168.10.4" "SENT: * CAPABILITY IMAP4 IMAP4rev1 QUOTA[nl]A002 OK CAPABILITY completed[nl]"
"IMAPD" 2576 "2005-07-28 15:14:27.625" "192.168.10.4" "RECEIVED: . LIST "INBOX" """
"IMAPD" 2576 "2005-07-28 15:14:27.625" "192.168.10.4" "SENT: * LIST (/NoSelect) "." ""[nl]"
"IMAPD" 2576 "2005-07-28 15:14:27.625" "192.168.10.4" "SENT: . OK LIST completed[nl]"
"IMAPD" 2576 "2005-07-28 15:14:27.625" "192.168.10.4" "RECEIVED: A003 LOGOUT"
"IMAPD" 2576 "2005-07-28 15:14:27.640" "192.168.10.4" "SENT: * BYE Have a nice day[nl]A003 OK Logout completed[nl]"
"TCPIP" 2576 "2005-07-28 15:14:27.656" "IMAPD - Connection to client 192.168.10.4 closed."
"DEBUG" 2576 "2005-07-28 15:14:27.656" "SocketConnection::~SocketConnection()"
cgountanis
Post by cgountanis » 2005-07-28 22:29
I get sess_3edcf8102960d4ec2dda7e1e5f07d247 and still no left menu? Same exact issue for me using PHP 4.4 and IIs 5.0 on Windows 2000 Server.
Post by martin » 2005-07-28 22:37
Turn on error_reporting in php.ini and post the error message here if you get any.
cgountanis
Post by cgountanis » 2005-07-28 22:43
On the user info page I get this:
Notice: Undefined index: REQUEST_URI in C:\WebMail\wwwroot\plugins\timeout_user\functions.php on line 109
Notice: Undefined offset: 1 in C:\WebMail\wwwroot\plugins\timeout_user\functions.php on line 110
But still nothing in left menu at all and seems like passwors is just not carring through.
cgountanis
Post by cgountanis » 2005-07-28 22:49
The funny thing is it does send the email in the compose section but with out the left menu you cant get current emails or do anything usefull :(
Post by martin » 2005-07-28 22:52
http://www.squirrelmail.org/wiki/en_US/ ... ailWindows
"IIS, PHP & SquirrelMail is a working combination however due to stability problems between PHP & IIS this combination is not recommended for a production environment. "
I'm pretty much out of good idéas here. Anyone else has any perhaps?
cgountanis
Post by cgountanis » 2005-07-28 23:58
do you have to run an install process or is it just ready to go with one config line change? Nay PHP plugins needed to be uncommented in php.ini?
ABX
Post by ABX » 2005-07-29 00:15
My problem:
1.Only the first login was successful.
2. Coudn't use folders
3. Left side pannel was empty.
Solution:
Found it somewhere on the net.
16. Next locate the text "header("Location: $redirect_url");" in redirect.php found in your SquirrelMail "src" directory and replace it with the following ;
echo "<html><head><META HTTP-EQUIV=\"Refresh\" CONTENT=\"0;
URL=$redirect_url\"></head><body><a href=$redirect_url>Enter</a></body></html>";
cgountanis
Post by cgountanis » 2005-07-29 00:47
Dude I seriously love you. That should be fixed in the main version! It works now..
tourcd
Post by tourcd » 2005-07-29 17:02
Thanks. Fixed mine too!! :D
Got another minor problem to solve, getting the following error at the top of the page...
Notice: Undefined index: REQUEST_URI in C:\Inetpub\wwwroot\squirrelmail\plugins\timeout_user\functions.php on line 109
But apart from that it's lookin' good.
cgountanis
Post by cgountanis » 2005-07-29 18:28
Just remove plugins that you dont need. I found the change password plugin has same refesh error for me. The plugin that is erroring is the timeout user. Also tweak php.ini so that it does not display warnings and notices for production server.
