Return-Path for Bounces
Hotlanta
Post by Hotlanta » 2008-08-09 22:53
I have a newsletter that my users subscribe to. To be in compliance with Yahoo Mail and other ISP's, I have to be sure to clean my bounces out after each mailing. This entails checking the returns to see if they are hard bounces or soft bounces, and then updating my database accordingly. If I keep sending to hard bounces, I will eventually be seen as a spammer.
Most mail lists use the "Return-Path:" header to set a dynamic bounce email address that includes an email ID for tracking the returns back to the specific records. When the mail server bounces the email, instead of returning it to the original sender, it returns it to the "bounce-123456@domain.com" address in the Return-Path. This is very helpful because it allows for an automated solution to managing bounces. Most subscriber lists use this method.
Unfortunately, for some reason, hMailserver doesn't appear to use the Return-Path for mail returns. Instead, it returns mail to the From address, even when the Return-Path has been set. Is there a setting to adjust this?
Re: Return-Path for Bounces
Post by martin » 2008-08-09 23:27
What type of "mail returns" do you mean? Can you given an example? What type of "mail returns" are generated by hMailServer when you send out your newsletter?
