Migrating from Rockliffe Mailsite 6 to hMail
marcottej
Post by marcottej » 2007-12-05 18:13
Hi folks,
We're using Rockliffe Mailsite for an educational portal system and would like to migrate to hMail. Currently, we're looking for a tool to migrate the users (and passwords) and mails in hMail ?
Any one have any scripts to do this ?
Jonathan
danny6167
Post by danny6167 » 2007-12-05 18:55
Do you know how Rockliffe stores email and settings?
marcottej
Post by marcottej » 2007-12-05 22:10
Rockliffe store the email like hmail: in a directory with each email with a .MSG extension. The mail look like an eml, I need to do some testing to be sure.
The user information is stored in the Windows registry and I can dump then in a text file with an utility. The only problem I see is that the password is encrypted... Don't know a way to decrypt it to use it for creating the user... It's currently my main problem...
Jonathan
