FTP Server
renleon
Guru
Guru
FTP Server
Post by renleon » 2006-10-25 16:57
Can someone recommend a free/opensource FTP server.
I just wondered what other people were using and could recommend.
mbreitba
Post by mbreitba » 2006-10-25 17:22
I beleive WarFTP is open source.
gmouse
Post by gmouse » 2006-10-25 18:21
I use slimftpd. It consumes extremely little RAM (2MB at the moment, noone connected), but needs to be restarted for every change in configuration.
renleon
Guru
Guru
Post by renleon » 2006-10-25 20:10
Thanks, ill take a look at them both.
Im looking for an FTP server where I can add accounts using the command line or config files.
I just checked out Filezilla Server, it also uses a config file for user accounts.
CraigHarris
Post by CraigHarris » 2006-10-26 00:25
I recomend FileZilla - there's a decent server and a fully featured client - see http://filezilla.sourceforge.net/
renleon
Guru
Guru
Post by renleon » 2006-10-26 00:56
I think im going to go with filezilla.
You can update the config xml file then run a command to tell filezilla to reload the config, without restarting.
Perfect :)
deagled
Post by deagled » 2006-10-31 00:25
I've used filezilla a couple of times over the last year and it works pretty good.
westdam
Post by westdam » 2006-10-31 15:26
filezillla server and if you use filezilla as client it's very reliable and fast
cveillon
Post by cveillon » 2006-11-09 07:32
I used to use WarFTP, but switched to Filezilla. Much better.
