Find rogue WiFi client
mikedibella
Post by mikedibella » 2020-05-04 21:44
I've got a rogue WiFi client attempting to access my local network. I see the attempts in my RADIUS logs and have captured the MAC address from calling-station-id.
Now I need software (hopefully freeware/freemium/low-cost) to "find" where this client is. I see there is a bunch of free software on the net that lets one walk around and generate heat maps of Access Points, but I 'm having trouble find a good solution to map clients, hopefully once that includes the ability to filter the list by a know MAC address.
Any suggestions?
Re: Find rogue WiFi client
Post by SorenR » 2020-05-04 22:04
mikedibella wrote:
2020-05-04 21:44
Any suggestions?
The only way to locate a "radio" is triangulation. So whatever solution you find you will need 2 mates to help you :mrgreen:
https://www.cisco.com/c/en/us/td/docs/s ... fich2.html
Post by SorenR » 2020-05-04 22:12
mikedibella
Post by mikedibella » 2020-05-04 23:31
Triangulation is one approach, but it requires more than just two reception points. You need a directional antenna or array to isolate the vector of reception in addition to the signal strength to derive a position. It is accurate but too complex for my needs.
Heat mapping, on the other hard, uses a single moving receiver to plot many, many, position/signal pairs and plot them on a map to generate a visual indication of where the strongest detected signal is. The collection process and analysis is a lot simpler. An exact position can only, at best, be inferred, but this is adequate for my needs since I am assuming the rogue device to be relatively static in position when it is in range of my network.
Post by jimimaseye » 2020-05-05 00:15
I reckon it's the bloke in the unironed shirt with the tablet in the white car parked outside.
Just a hunch. :mrgreen:
johang
Post by johang » 2020-05-07 00:31
try macadress block list in wifi accesspoints?
lower your signal strength on the accesspoints..
put up your own rogue wifi accesspoint preferably with a directional antenna.. get outside .. work it outwards from building.. south east north west where do you pick up taht interesting Macadress .. go visit.. ( or just leave the rouge station on .. sending funny packets .. giving him/her access to a honeypot .. lot of things to play with if you feel you have the time )
( make you own directional wifi accesspoint: take a cardboardbox "insulate" with tinfoil at sides and bottom, place wifiaccespoint inside and direct opening of box to where you want your signals to go )
