Nasty virus/trojan in emails
Kendo
Post by Kendo » 2020-03-05 07:18
It has happened a few times now... my antiyvirus detects a trojan/virus in an email in my Thunderbord INBOX and fixes it almost immediately. Only problem with that is that it deletes the contents of all emails in the INBOX and just leaves the subject list. Of course all of those emails listed are blank.
I have lost a lot of current discussions over this and it all happens so quickly that I don't get to see anything about the infected email. Lucky I am only getting these emails on one email address.
So as to not lose any more emails that may be ongoing business, I now move all emails from that INBOX to a CURRENT folder so that if it happens again, I only lose what has just come in and can get anything else from the server.
Anyone else have this experience?
Re: Nasty virus/trojan in emails
Post by SorenR » 2020-03-05 12:43
Kendo wrote:
2020-03-05 07:18
Nope ... Then again I don't use Thunderbird ... I have Avast antivirus set to NEVER delete anything, just move it to quarantine and I'll deal with it later. I use Outlook2003 on an old XP and eM Client on my Win10.
I do have some script code that will forward a COMPLETE copy of an email to Postmaster in case one or more attachments are deleted by hMailServer.
Post by palinka » 2020-03-05 13:15
That doesn't sound right. Sounds more like a nasty antivirus than a nasty virus.
Better to handle this on the server. There's a tutorial for clamAV with sane security definitions. Server updates definitions hourly. The antivirus app on your client machine probably doesn't do that. Better to prevent the virus from getting transmitted to the client than to deal with crazy unexpected results from antivirus behavior on the client.
Post by mattg » 2020-03-06 01:36
2020-03-05 13:15
Yep, I agree
Kendo
Post by Kendo » 2020-03-06 02:42
Actually I find Microsoft Security Essentials best. It was not deleted... quarantined. But without a means to see subject or who the sender/recipient was.
Segregating new mail does the trick.
Post by SorenR » 2020-03-06 13:59
Kendo wrote:
2020-03-06 02:42
You may want to switch to a different product. MSE is dangerous!
If their commandline scan behave like this then what about their real-time scan?
https://answers.microsoft.com/en-us/pro ... bfc2657ff6
Post by RvdH » 2020-03-06 17:46
2020-03-06 13:59
I completely forgot about that topic.... well 6 years further and nothing is done with an additional returncode....i ditched mse as a virusscanner for hmailserver use long time ago because of this
Kendo
Post by Kendo » 2020-03-06 23:14
MSE is dangerous!
Maybe for command-line... 6 years ago. But I don't use it with CMD or use it with any other apps. Just runs in the background and does a fantastic trouble-free job.
Have tried all the others. Was an agent for one of them at one time. They are so busy plagiarising each other that they incorporate the same mistakes.
Post by SorenR » 2020-03-06 23:33
Kendo wrote:
2020-03-06 23:14
MSE is dangerous!
Return code on command-line has not changed...
Post by mattg » 2020-03-17 16:57
Henry22 wrote:
2020-03-17 16:11
Do I need to installed a Antivirus to protect my PC again Virus?
Really??
Post by RvdH » 2020-03-17 17:25
2020-03-17 16:57
Henry22 wrote:
2020-03-17 16:11
Really??
I don't have anything scanning e-mails handled by hmailserver, I do block attachments and inspect content inside zip files however
Basically it does what sanesecurity foxhole definitions do without needing to reserve around 600mb just to run ClamAV and it's signatures
And this is my list of blocked extensions in hmailserver:
7-Zip Archive (*.7z)
Microsoft Access Project Extension File (*.ade)
Microsoft Access Project File (*.adp)
ARJ Archive (*.arj)
Batch processing file (*.bat)
Compiled HTML Help File (*.chm)
Command file for Windows NT (*.cmd)
Command (*.com)
Windows Control Panel extension (*.cpl)
CSH script (*.csh)
Word 2007-2016 document with macro (*.docm)
Executable file (*.exe)
HTML Application File (*.hta)
Setup file (*.inf)
Internet Settings File (*.ins)
Internet Service Provider Settings File (*.isp)
Java Archive (*.jar)
JavaScript File (*.js)
Java Server Page File (*.jsp)
Windows link file (*.lnk)
Windows Installer file (*.msi)
Windows Installer patch (*.msp)
Program Information File (*.pif)
PowerShell Script (*.ps1)
WinRar Archive (*.rar)
Registration key (*.reg)
Windows Explorer command (*.scf)
Windows Screen saver (*.scr)
VBScript Encoded Script File (*.vbe)
VBScript Script File (*.vbs)
Virtual Device Driver (*.vxd)
Windows Script Components (*.wsc)
Windows Script File (*.wsf)
Windows Script Host (*.wsh)
Post by SorenR » 2020-03-17 20:25
2020-03-17 16:57
Henry22 wrote:
2020-03-17 16:11
Really??
I use attachment blocking (with a script to CC Postmaster the complete mail if an attachment is removed)
I moved ClamD checking to SpamAssassin as it turned out to be more efficient in finding "stuff", more than ClamD directly from hMailServer (no idea why)
