Is this right?
Is this right?
Post by RvdH » 2019-07-05 16:22
Have been fiddling around with the IP ranges, when I disallow Deliveries from External to External for a IP Range but do not uncheck External to External in Require SMTP authentication the error message displayed is:
"530 SMTP authentication is required."
Only if I also uncheck External to External in Require SMTP authentication the error message is correct. eg:
"550 Delivery is not allowed to this address."
This seems incorrect to me...Don't you think?
I think settings in Allow deliveries must always be the preferred and appointed criteria above settings in Require SMTP authentication, in Administrator GUI this looks to be the case as the Require SMTP authentication checkbox is greyed-out/readonly as soon you uncheck Allow deliveries, but in the code it seems to function visa versa
https://github.com/hmailserver/hmailser ... n.cpp#L681
Re: Is this right?
Post by jimimaseye » 2019-07-05 19:30
I agree.
You logged a github issue (fwiw)?
Although the error 'authenticating required' is enough to confuse the determined unwanted as they may think that (guessing) authentication is their way in When in actual fact they will never succeed, whereas the 'delivery not allowed to this address' simply gives away the real truth and tells them they can try something else (which, if they are lucky, they might succeed with).
It's like giving them a bucket of orange balls and telling them they can come in if they can find the green one.
Perhaps for these undesirables the rejection should simply be
500 Nah. Jog on!
Re: Is this right?
Post by RvdH » 2019-07-05 19:53
I think it is the other way around, I suspect these are bots/infected systems trying to relay...those expect SMTP error 550 (Non-existent email address) or 551 (Relaying not allowed), but hmailserver returns 530, so they keep trying...over and over again, 551 doesn't exist on hmailserver though
Re: Is this right?
Post by SorenR » 2019-07-05 23:39
The logical flow should be to disregard "Require SMTP authentication" if "Allow deliveries from" is unselected.
I have not yet looked in the code (other than I found Martin can't spell "deliveries") but it's somewhere in the SMTP logic. The priority of option checking needs to be altered.
Re: Is this right?
Post by jimimaseye » 2019-07-05 23:43
2019-07-05 23:39
I agree. (From a logic procedural point of view)
Re: Is this right?
Post by RvdH » 2019-07-06 00:17
I have already made a test build *.21
I reversed the logic in that build, lines 681 till 699 and line 662 till 679 are switched
