How to block SMTP attacks for sending multiple mails...
ves
Post by ves » 2019-06-25 09:48
Hi all,
I'm getting hit by some spammers that try to send several mails to my server to not existing mailboxes (trying to guess the right ones)
SMTPD" 7896 52740 "2019-06-25 00:58:41.666" "185.222.211.13" "SENT: 550 Unknown user"
Does someone had same situation and is there a script that can be connected to Sub OnDeliveryFailed(oMessage, sRecipient, sErrorMessage) and block the sender IP (via standard hmailserver auto ban service) ?
Thanks is advance and sorry if my request is duplicated with other posts - I tried to search - but I didn't find exact answer (I found similar - but seems not working in my case) - here are the full logs for information
"SMTPD" 7884 52812 "2019-06-25 07:34:53.089" "185.222.211.13" "SENT: 220 mail.mydomain.com ESMTP"
"SMTPD" 7840 52812 "2019-06-25 07:34:54.021" "185.222.211.13" "RECEIVED: EHLO hosting-by.nstorage.org"
"SMTPD" 7840 52812 "2019-06-25 07:34:54.025" "185.222.211.13" "SENT: 250-mail.mydomain.com[nl]250-SIZE 50480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 7884 52812 "2019-06-25 07:34:54.583" "185.222.211.13" "RECEIVED: MAIL FROM:<0rw056rs1oqitd@vkd.cz>"
"SMTPD" 7884 52812 "2019-06-25 07:34:54.594" "185.222.211.13" "SENT: 250 OK"
"SMTPD" 7868 52812 "2019-06-25 07:34:55.618" "185.222.211.13" "RECEIVED: RCPT TO:<francois@mydomain.com>"
"SMTPD" 7868 52812 "2019-06-25 07:34:55.635" "185.222.211.13" "SENT: 550 Unknown user"
"SMTPD" 7856 52812 "2019-06-25 07:34:55.639" "185.222.211.13" "RECEIVED: RCPT TO:<falecom@mydomain.com>"
"SMTPD" 7856 52812 "2019-06-25 07:34:55.652" "185.222.211.13" "SENT: 550 Unknown user"
"SMTPD" 7868 52812 "2019-06-25 07:34:55.656" "185.222.211.13" "RECEIVED: RCPT TO:<jana@mydomain.com>"
"SMTPD" 7868 52812 "2019-06-25 07:34:55.669" "185.222.211.13" "SENT: 550 Unknown user"
"SMTPD" 7868 52812 "2019-06-25 07:34:55.672" "185.222.211.13" "RECEIVED: RCPT TO:<sven@mydomain.com>"
"SMTPD" 7868 52812 "2019-06-25 07:34:55.681" "185.222.211.13" "SENT: 550 Unknown user"
"SMTPD" 7884 52812 "2019-06-25 07:34:55.683" "185.222.211.13" "RECEIVED: RCPT TO:<ar@mydomain.com>"
"SMTPD" 7884 52812 "2019-06-25 07:34:55.691" "185.222.211.13" "SENT: 550 Unknown user"
"SMTPD" 7868 52812 "2019-06-25 07:34:55.693" "185.222.211.13" "RECEIVED: RCPT TO:<sabine@mydomain.com>"
"SMTPD" 7868 52812 "2019-06-25 07:34:55.701" "185.222.211.13" "SENT: 550 Unknown user"
"SMTPD" 7884 52812 "2019-06-25 07:34:55.703" "185.222.211.13" "RECEIVED: RCPT TO:<martina@mydomain.com>"
"SMTPD" 7884 52812 "2019-06-25 07:34:55.708" "185.222.211.13" "SENT: 550 Unknown user"
"SMTPD" 7884 52812 "2019-06-25 07:34:55.710" "185.222.211.13" "RECEIVED: RCPT TO:<eli@mydomain.com>"
"SMTPD" 7884 52812 "2019-06-25 07:34:55.714" "185.222.211.13" "SENT: 550 Unknown user"
"SMTPD" 7840 52812 "2019-06-25 07:34:55.716" "185.222.211.13" "RECEIVED: RCPT TO:<dominique@mydomain.com>"
"SMTPD" 7840 52812 "2019-06-25 07:34:55.720" "185.222.211.13" "SENT: 550 Unknown user"
"SMTPD" 7868 52812 "2019-06-25 07:34:55.722" "185.222.211.13" "RECEIVED: RCPT TO:<shelly@mydomain.com>"
"SMTPD" 7868 52812 "2019-06-25 07:34:55.726" "185.222.211.13" "SENT: 550 Unknown user"
"SMTPD" 7840 52812 "2019-06-25 07:34:55.728" "185.222.211.13" "RECEIVED: RCPT TO:<lynne@mydomain.com>"
"SMTPD" 7840 52812 "2019-06-25 07:34:55.733" "185.222.211.13" "SENT: 550 Unknown user"
"SMTPD" 7856 52812 "2019-06-25 07:34:55.734" "185.222.211.13" "RECEIVED: RCPT TO:<lea@mydomain.com>"
"SMTPD" 7856 52812 "2019-06-25 07:34:55.739" "185.222.211.13" "SENT: 550 Unknown user"
"SMTPD" 7868 52812 "2019-06-25 07:34:55.740" "185.222.211.13" "RECEIVED: RCPT TO:<smtp@mydomain.com>"
"SMTPD" 7868 52812 "2019-06-25 07:34:55.745" "185.222.211.13" "SENT: 550 Unknown user"
"SMTPD" 7840 52812 "2019-06-25 07:34:55.746" "185.222.211.13" "RECEIVED: RCPT TO:<123456@mydomain.com>"
"SMTPD" 7840 52812 "2019-06-25 07:34:55.751" "185.222.211.13" "SENT: 550 Unknown user"
"SMTPD" 7868 52812 "2019-06-25 07:34:55.752" "185.222.211.13" "RECEIVED: RCPT TO:<parts@mydomain.com>"
"SMTPD" 7868 52812 "2019-06-25 07:34:55.756" "185.222.211.13" "SENT: 550 Unknown user"
"SMTPD" 7868 52812 "2019-06-25 07:34:55.758" "185.222.211.13" "RECEIVED: RCPT TO:<dick@mydomain.com>"
"SMTPD" 7868 52812 "2019-06-25 07:34:55.762" "185.222.211.13" "SENT: 550 Unknown user"
"SMTPD" 7868 52812 "2019-06-25 07:34:55.764" "185.222.211.13" "RECEIVED: RCPT TO:<florence@mydomain.com>"
Re: How to block SMTP attacks for sending multiple mails...
Post by mattg » 2019-06-25 11:23
In Protocols >> SMTP >> RFC compliance
what do you have for 'Maximum number of invalid commands'?
Post by SorenR » 2019-06-25 12:08
185.222.211.13 is on the SpamHaus SnowShoe SPAM list (https://www.spamhaus.org/faq/section/Glossary#233) so may I suggest this to begin with...
The script below may not catch all of them but it's a start and something we can build on. The script is a subset of my own Eventhandler script.
The COM object used for DNS lookups is made by RvdH who also maintain the hMailServer code with extended Event triggers: https://www.hmailserver.com/forum/viewt ... 28#p196628
And the script part looks like this:
'   COM authentication
Private Const PASSWORD = "VerySecretPassword"
Function IsSnowShoe(strIP) : IsSnowShoe = False
   Dim a, strLookup
   a = Split(strIP, ".")
      strLookup = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".zen.spamhaus.org")
   If (InStr(1, strLookup, "127.0.0.3", 1) > 0) Then IsSnowShoe = True
   On Error Resume Next
   Dim oSecurityRange : Set oSecurityRange = oApp.Settings.SecurityRanges.ItemByName("(" & sReason & ") " & sIPAddress)
   If Err.Number = 9 Then
         .LowerIP = sIPAddress
         .UpperIP = sIPAddress
         .Priority = 20
         .Expires = True
         .Save
      AutoBan = True
   On Error Goto 0
   Set oApp = Nothing
Function LPad(str, length, pad)
   LPad = Left(CStr(str) & String(length, pad), length)
Sub OnClientConnect(oClient)
   '   SnowShoe SPAM detection, BAN for 1 month.
      EventLog.Write( LPad("SnowShoe", 15, " ") & vbTab & oClient.IPAddress )
      Call AutoBan(oClient.IPAddress, "SnowShoe", 1, "m")
      Result.Value = 1
      Exit Sub
ves
Post by ves » 2019-06-25 12:31
2019-06-25 11:23
:( - 100
I never look here :( I was thinning that default is something like 5-10
What do you will recommend as value ? I'm thinking that 5 should be ok ?
ves
Post by ves » 2019-06-25 12:37
2019-06-25 12:08
Thanks,
I forgot to add that I prefer solutions that are not depend from external sources, my idea was to write a script that on 3-5 attempts to ban IP with the default rules (for me ban is with duration 3 months :-)
What I'm missing is how to cash in memory list with IP's and access them via VB script - I was thinking to write a windows or web service for that - but seems too complicated :-)
Anyway - many thanks for the script - I will use if there is no other easy solution.
Post by SorenR » 2019-06-25 12:53
ves wrote:
2019-06-25 12:37
2019-06-25 12:08
Thanks,
If you manage to build a script to read the SMTP log you can use the AutoBan function in the example to ban the IP address.
I don't know why but for some reason the Unix tail -f keep popping up ;-)
EDIT: Have a look at this https://stujordan.wordpress.com/2012/09 ... -vbscript/
Post by SorenR » 2019-06-25 13:24
Playing with the tail.vbs script from the link above ... bloody genious and uses virtually no resources.
Could not make it run at first but when I added drive and path to the file it works as intended !!
ves
Post by ves » 2019-06-25 19:29
2019-06-25 12:53
ves wrote:
2019-06-25 12:37
2019-06-25 12:08
Thanks,
A very good idea - 10x for link I will try to make it and if is working - I will post it here.
Post by mattg » 2019-06-26 01:01
ves wrote:
2019-06-25 12:31
I run with 5 on my production machines
ves
Post by ves » 2019-07-01 13:14
2019-06-26 01:01
ves wrote:
2019-06-25 12:31
I changed to 5 too - but seems this does't help :( ?
Is it sure that 550 Unknown user is related to this option.
Post by SorenR » 2019-07-01 13:28
ves wrote:
2019-07-01 13:14
2019-06-26 01:01
ves wrote:
2019-06-25 12:31
Probably not as it is not an invalid command ... The user just don't exist.
One other thing you could do is to create a "catch-all" account. The "550 Unknown user" will go away and you will have a mailbox to use as a "HoneyTrap". A simple script to extract the IP address and issue an AutoBan on the IP address. :mrgreen:
Post by mattg » 2019-07-08 09:36
ves wrote:
2019-07-01 13:14
2019-06-26 01:01
ves wrote:
2019-06-25 12:31
Just saw this is fixed in RvdH's builds that I use
https://github.com/hmailserver/hmailserver/issues/160
ves
Post by ves » 2019-07-10 13:42
2019-07-08 09:36
ves wrote:
2019-07-01 13:14
2019-06-26 01:01
I just checked one of my installations - I'm with version 5.6.8 and seems this doesn't work :(. So I will go on parsing log files and ban.
Post by Dravion » 2019-07-10 14:13
Maybe this can help you out with your Problem
https://www.hmailserver.com/forum/viewt ... 81#p213281
Post by mattg » 2019-07-10 14:55
ves wrote:
2019-07-10 13:42
Correct
I use a custom build, this is not available in the main releases
ves
Post by ves » 2019-07-11 07:40
Dravion wrote:
2019-07-10 14:13
Wow - thanks - you save me some days - I was planning to do almost the same
