New kinda spammers?
New kinda spammers?
Post by RvdH » 2019-06-08 13:28
I noticed one of my servers is being hit with spam mails where the HELO and From-address only differ one char,
example:
HELO/EHLO: eisentraut.zachariaszels.com
MAIL FROM: eisentraut@zachariaszels.com
To catch these early i did this:
	If (oMessage.FromAddress <> "") Then
		If StrComp(ereg_replace(oClient.HELO, "[\@\.]", Empty, true),ereg_replace(oMessage.FromAddress, "[\@\.]", Empty, true),1)=0 Then
			Eventlog.Write("OnSMTPdata: HELO " & oClient.HELO & " FROM " & oMessage.FromAddress & " (" & oClient.IPAddress& "). 542 Rejected" )
			Result.Message= "5.7.1 Your access to this mail system has been rejected due to "  &_
							"the sending MTA's poor reputation. If you believe that this failure is " &_
							"in error, please contact the intended recipient via alternate means."
			Result.Value = 2
			Call AutoBan(oClient.IPAddress, oMessage.FromAddress, 1, "d")
			Exit Sub
		End if
	End if
' Function replaces pattern with replacement
' varIgnoreCase must be TRUE (match is case insensitive) or FALSE (match is case sensitive)
' from http://www.addedbytes.com/asp/vbscript-regular-expressions/
function ereg_replace(strOriginalString, strPattern, strReplacement, varIgnoreCase)
	dim objRegExp : set objRegExp = new RegExp
	With objRegExp
		.Pattern = strPattern
		.IgnoreCase = varIgnoreCase
		.Global = True
	ereg_replace = objRegExp.replace(strOriginalString, strReplacement)
	set objRegExp = nothing
end Function
What it basically does, it strips all dots (.) and AtSign (@) and then compares if the two strings are identical, in this case the strings to be compared are both 'eisentrautzachariaszelscom' which result in a 554 rejection (and auto-ban)
"SMTPD" 6132 187452 "2019-06-08 13:13:11.886" "64.44.61.130" "SENT: 220 mail.domain.com ESMTP"
"SMTPD" 7692 187452 "2019-06-08 13:13:11.980" "64.44.61.130" "RECEIVED: EHLO eisentraut.zachariaszels.com"
"SMTPD" 7692 187452 "2019-06-08 13:13:12.027" "64.44.61.130" "SENT: 250-mail.domain.com[nl]250-SIZE 51200000[nl]250-STARTTLS[nl]250 HELP"
"SMTPD" 7572 187452 "2019-06-08 13:13:12.120" "64.44.61.130" "RECEIVED: STARTTLS"
"SMTPD" 7572 187452 "2019-06-08 13:13:12.120" "64.44.61.130" "SENT: 220 Ready to start TLS"
"SMTPD" 7692 187452 "2019-06-08 13:13:12.466" "64.44.61.130" "RECEIVED: EHLO eisentraut.zachariaszels.com"
"SMTPD" 7692 187452 "2019-06-08 13:13:12.497" "64.44.61.130" "SENT: 250-mail.domain.com[nl]250-SIZE 51200000[nl]250 HELP"
"SMTPD" 7572 187452 "2019-06-08 13:13:12.606" "64.44.61.130" "RECEIVED: MAIL FROM:<eisentraut@zachariaszels.com>"
"SMTPD" 7572 187452 "2019-06-08 13:13:12.606" "64.44.61.130" "SENT: 250 OK"
"SMTPD" 6544 187452 "2019-06-08 13:13:12.715" "64.44.61.130" "RECEIVED: RCPT TO:<info@******.nl>"
"SMTPD" 6544 187452 "2019-06-08 13:13:12.715" "64.44.61.130" "SENT: 250 OK"
"SMTPD" 6132 187452 "2019-06-08 13:13:12.825" "64.44.61.130" "RECEIVED: DATA"
"SMTPD" 6132 187452 "2019-06-08 13:13:12.887" "64.44.61.130" "SENT: 554 5.7.1 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
Re: New kinda spammers?
Post by palinka » 2019-06-08 14:53
I haven't seen that yet but if it's going around I'm sure I'll see it sooner or later, so i implemented your script already. :D
Post by RvdH » 2019-06-08 16:20
I've got a single one auto-banned that shouldn't have been banned, using: mail.something.com as HELO/EHLO with From-address: mail@something.com
you can come by this, by adjusting it like:
	Dim oRegEx
	oRegEx.IgnoreCase = True
	oRegEx.Global = False
	oRegEx.Pattern = "^(mail\.).+$"
	If (oMessage.FromAddress <> "") And Not oRegEx.Test(oClient.HELO) Then
		If StrComp(ereg_replace(oClient.HELO, "[\@\.]", "", true),ereg_replace(oMessage.FromAddress, "[\@\.]", "", true),1)=0 Then
			Result.Value = 2
			Exit Sub
		End if
	End if
	Set oRegEx = Nothing
Post by palinka » 2019-06-09 00:03
I imagine that's a pretty rare case. :mrgreen:
Post by SorenR » 2019-06-09 01:01
2019-06-09 00:03
I reject alle mails where oMessage.FromAddress is "^(return\@.*)$". Not had a false positive in over 1 year... :mrgreen:
