Hi Nico: I like your post of Clamav very much. I also liked and have used David Fitch's instructions on how to use clamav with Ewall as I send notification of a virus by a template to me so I can help keep track. Everything has been working fine until I upgraded to version 96 (using the installer and overwriting the older version. It appears to be working (according to ewall log files) but I no longer get the notification.
Any ideas on why
Clamav ver .96 and ewall
- tBB
- Senior user
- Contact:
Re: Clamav ver .96 and ewall
No sorry. I don't know Ewall and in which way it uses ClamAV. If it calls Clam(D)Scan, the errorlevel it returns in case of a found infection didn't change since 0.95.3 so I see no reason why reports shouldn't work anymore (even less if Ewall recognizes the infection).bescher wrote:Any ideas on why
Best regards,
Nico
